hi, actually got it working with 108 fps benchmarked on 720p on a new sd card. don`t know why i am not seeing more fps, but i really dont care. it feels good playing against 6 or more players, so i am pretty satisfied. but my next question is i am having a hard time with the resolution "fix for having 720p ingame and 1080p in desktop. i made this change to the file.
#!/bin/bash
# Copyright (C) 2016-2017 cdev-tux - github.com/cdev-tux
# This file is part of Q3lite source code.
# See COPYING.txt for license details.
q3dir="/home/pi/Games/q3lite"
logged_in_user=$(who | grep -m 1 "." | awk '{print $1}')
if [ -z "$logged_in_user" ]; then
q3l_user="pi"
else
q3l_user="$logged_in_user"
fi
q3l_userhome=$(sudo -u $q3l_user -H -s eval 'echo $HOME')
q3l_homepath="$q3l_userhome/.q3a"
current_res="$(tvservice -s)"
# Disable keyboard input to the desktop x11 server if it's running (fixes SDL2 keypress leakage issue).
# This script will try to determine the correct keyboard ID's to disable, but if the auto-detection
# fails then you can determine the ID's manually by using the instructions below.
# Enter "xinput" in a terminal window to show a list of all input devices. Change the line below to use
# the id number(s) of your keyboard from the "xinput" command. Use the ID numbers from each line
# that does NOT contain the word "Virtual". If your keyboard uses ID 6, 7, and 8
# then set the following line to: xinput_id="6 7 8". See the Q3lite FAQ for details.
xinput_id=""
# The following line that begins with "settings=" contains the command line arguments supplied
# to the game when it starts. Change these settings to match your desired settings. Don't modify
# the line that begins with "timedemo=" or it may break the timedemo function.
# Settings for vm_ui and vm_cgame:
# +set vm_* 0 = .dll files are used (Windows)
# +set vm_* 1 = .so files are used (Linux, Mac)
# +set vm_* 2 = .qvm files are used (Quake Virtual Machine, default)
settings="+set com_hunkMegs 192 +set com_zoneMegs 24 +set com_soundMegs 16 +set fs_homepath $q3l_homepath +set vm_ui 2 +set vm_cgame 2 +set com_introplayed 1 +set com_protocol 68"
timedemo="$settings +set timedemo 1 +demo four"
if [ $(uname -m) = armv7l ]; then
arch="armv7l"
else
arch="arm"
fi
# Check to see if the GUI is running.
if systemctl is-active graphical.target > /dev/null; then
gui="yes"
# Attempt to auto-detect the keyboard ID's to disable keyboard input to the desktop x11 server.
if [ "$xinput_id" = "" ]; then
xinput_id=$(xinput | grep -i "id=" | grep -i -v "Virtual" | grep -Po 'id=\K[^=[]' | tr '\n' ' ' | sed 's/[ ]*$//')
fi
# Echo the xinput keyboard ID's for troubleshooting purposes.
echo -e "\nxinput_id=$xinput_id\n"
# Uncomment the xinput_id="" line below to prevent xinput from disabling keyboard input to the x11 server.
# Caution, this will allow keystrokes to leak back to the desktop which can cause all sorts of mayhem.
# Leave a text editor like gedit open and in focus on the desktop to catch keystrokes. This is used for
# troubleshooting.
#xinput_id=""
# Disable keyboard input to the x11 server for each keyboard id.
if [ "$xinput_id" != "" ]; then
for xid in $xinput_id;
do
xinput --disable $xid;
echo -e "xinput disabled keyboard ID=$xid";
done
else
echo -e "\nUnable to determine xinput ID to disable keyboard input to the x11 server."
echo -e "This may allow keyboard keypresses to leak back to the desktop per an SDL2 issue."
echo -e "See the Q3lite FAQ for details.\n"
fi
fi
# Set Q3lite video resolution mode. Enter "tvservice -m DMT" and
# "tvservice -m CEA" in a terminal window to list available video modes.
# Uncomment the following line and set your in-game resolution if desired.
#tvservice -e "DMT 85"
# Start Q3lite under the user account.
if [ "$1" = "timedemo" ]; then
if [ -f $q3dir/quake3.$arch ]; then
sudo -u $q3l_user $q3dir/quake3.$arch $timedemo
else
echo -e "Unable to find $q3dir/quake3.$arch binary, exiting...\n"
exit 1
fi
else
sudo -u $q3l_user $q3dir/quake3.$arch $settings
else
exit 2
fi
fi
# If the game resolution is different than the desktop resolution then enable
# flipping the virtual terminal to 1 and back to 7, otherwise go strait to desktop.
if [ "$current_res" != "$(tvservice -s)" ]; then
flipvt="yes"
fi
Reset desktop video resolution mode. Enter "tvservice -m DMT 82"" and
# Uncomment the following line and set the desired desktop video resolution mode.
tvservice -e "DMT 6"
# Return to the desktop if it's running, otherwise restart tty1 console.
if [ "$gui" = "yes" ]; then
# Re-enable keyboard input to the desktop x11 server if it's running.
do
xinput -enable $xid;
echo -e "xinput enabled keyboard ID=$xid";
done
fi
if [ "$flipvt" = "yes" ]; then
sudo chvt 1
sudo chvt 7
fi
else
sudo chvt 2
sudo chvt 1
sudo systemctl restart getty@tty1.service
fi
exit 0
when i made these changes, when i click on the shortcut. the raspberry freezes util i manually restart it.
i must say that the shortcut in the games folder never started the game for me as i have it in a directory /home/pi/Games/q3live.
because when i had it in the src folder when following the install/compile guide it didnt work neither. maybe bad luck. but im actually extatic over getting over the 100fps mark. i am planning to hold a local tournament for the quake veterans and maybe introduce a epic game for all the fortnite kids in my city.
