madmaxed
Wolfenstein 3D (Original).
Fri Oct 12, 2012 3:22 pm
I am trying to find any information on porting the original Wolfenstein to PI. It would think it should be playable. I'd like to play it naively instead of through DosBox or anything else.
Have done a few searches and I'm coming up empty.
Thanks,
jon
billb
Re: Wolfenstein 3D (Original).
Fri Oct 12, 2012 3:54 pm
I haven't had a chance to try this yet, but it seems to be what you're looking for:
http://www.chaos-software.de.vu/
You'd need to download the source code and build it ... looks like you'd need to install libsdl-mixer1.2-dev, at least (going from memory, not sure if that's exactly the right name).
billb
Sat Oct 13, 2012 6:53 am
Argh. :?
No trouble building this one, but I haven't been able to get it running. It complains about not finding the data files (which, from the readme, should be in the same directory as the wolf3d binary).
Its a little odd in that you have to compile a different version for each release of Wolfenstein 3D -- as in demo 1.1, 1.4, full Apogee 1.4, id 1.4, Spear of Destiny demo / full, and so on. You do that by editing version.h.
I've tried both the 1.4 demo and full versions, as well as the spear demo, changing version.h and rebuilding for each, but it always says it can't find the data files.
RaTTuS
Contact: Twitter YouTube
Sat Oct 13, 2012 7:06 am
you'll need the data from the original disks
the source code is free but the WAD files are not
Covfefe
billb
Sat Oct 13, 2012 3:35 pm
Perhaps I wasn't clear. I've tried the data files from the wolf3d 1.4 demo, downloaded from the 3D Realms site here:
http://www.3drealms.com/downloads.html
As well as the data files (*.WL6) from the full version purchased here:
http://www.buy3drealms.com/
Using the Windows, this version works with my data files from the full version above:
"Win32 binary for Full 1.4 Apogee version (132 kB, not tested)"
But it always says "NO WOLFENSTEIN 3-D DATA FILES to be found!" on Linux.
:idea: ... looked at the source ... it looks for lowercase filenames only (*.wl6 instead of *.WL6).
OK so got it working finally, no thanks to the documentation. :twisted:
If you're using the full version of Wolf3D 1.4 from 3D Realms (the registered download for purchase here) then you edit version.h and only leave this line uncommented under the "Defines used for different versions" section:
#define CARMACIZED
And all the filenames (*.WL6 in this case) need to be changed to all lowercase and placed in the same directory as your wolf3d binary.
madmaxed
Wed Oct 17, 2012 12:34 am
Thanks for the input. I have successfully gotten it compiled and running. Wife will be happy. Her all time favorite game.
antiriad
Contact: Twitter
Fri Dec 27, 2013 4:25 pm
unfortunately the source files in the first post are no more available... any mirror or alternative?
(or directly a binary :)
Thank you very much!
billb
Wed Mar 05, 2014 5:04 pm
antiriad wrote:unfortunately the source files in the first post are no more available... any mirror or alternative?
Old post, I know, but for posterity the source may be found on the internet archive:
http://web.archive.org/web/201309010612 ... are.de.vu/
or on github:
https://github.com/mozzwald/wolf4sdl
alb85
Mon Jan 19, 2015 3:51 pm
I downloaded wolf4sdl but I'm not familiar with linux.
Can you explain how to install wolf4sdl for raspberry?
Thanks!
dudleydes
Tue Jan 20, 2015 3:38 pm
alb85
I have published a tutorial on installing wolf4sdl at the link below.
http://dosonthepi.blogspot.co.uk/2015/0 ... f4sdl.html
I have found a way of changing the source code to configure a game controller. If you're interested, then let me know.
alb85
Tue Jan 20, 2015 3:54 pm
Thank you dudleydes!
This evening I'll try your tutorial.
Yes I'm interested to configure the controller as well!
alb85
Wed Jan 21, 2015 8:37 am
I followed your tutorial but I have a problem with the command "make":
SDL_mixer.h: no such file or directory.....
dudleydes
Wed Jan 21, 2015 10:32 am
It appears that you may not have the SDL development libraries installed on your system. Try the following.
sudo apt-get install libsdl1.2-dev libsdl-image1.2-dev libsdl-mixer1.2-dev libsdl-ttf2.0-dev
I've updated the tutorial. Apologies, I assumed most folk would be using Retropie which has the libraries pre-installed.
alb85
Fri Jan 23, 2015 9:29 am
Thanks dudleydes!
I tested wolf3D and it works now!
Can you explain me how to configure the joypad please??
dudleydes
Fri Jan 23, 2015 5:07 pm
I have published the tutorial describing how to configure game controllers in Wolf4sdl.
Please let me know how you get on, especially if you are using controllers other the PS3 dualshock.
Return to “Gaming”
