Full screen at 1280x720, on my slightly overclocked Pi3, with Cornfield Crossing I'm getting FPS 19/30/52 (I guess that's min,current,max?)
stdout.log :
[info ] [FileManager]: Data files will be fetched from: '../../data/'
[info ] [FileManager]: Data files will be fetched from: '../../data/../../stk-assets/'
[info ] [FileManager]: User directory is '/home/pi/.config/supertuxkart/0.8.2/'.
[info ] [FileManager]: Addons files will be stored in '/home/pi/.local/share/supertuxkart/addons/'.
[info ] [FileManager]: Screenshots will be stored in '/home/pi/.local/share/supertuxkart/screenshots/'.
[info ] [FileManager]: User-defined grand prix will be stored in '/home/pi/.local/share/supertuxkart/grandprix/'.
[info ] [FileManager]: Asset 0 will be loaded from '../../data/challenges/'.
[info ] [FileManager]: Asset 1 will be loaded from '../../data/gfx/'.
[info ] [FileManager]: Asset 2 will be loaded from '../../data/grandprix/'.
[info ] [FileManager]: Asset 3 will be loaded from '../../data/gui/'.
[info ] [FileManager]: Asset 4 will be loaded from '../../data/../../stk-assets/library/'.
[info ] [FileManager]: Asset 5 will be loaded from '../../data/../../stk-assets/models/'.
[info ] [FileManager]: Asset 6 will be loaded from '../../data/../../stk-assets/music/'.
[info ] [FileManager]: Asset 7 will be loaded from '../../data/replay/'.
[info ] [FileManager]: Asset 8 will be loaded from '../../data/../../stk-assets/tracks/'.
[info ] [FileManager]: Asset 9 will be loaded from '../../data/../../stk-assets/sfx/'.
[info ] [FileManager]: Asset 10 will be loaded from '../../data/shaders/'.
[info ] [FileManager]: Asset 11 will be loaded from '../../data/skins/'.
[info ] [FileManager]: Asset 12 will be loaded from '../../data/../../stk-assets/textures/'.
[info ] [FileManager]: Asset 13 will be loaded from '../../data/ttf/'.
[info ] [FileManager]: Asset 14 will be loaded from '../../data/po/'.
[verbose ] translation: Env var LANGUAGE = 'en_GB.UTF-8'.
[verbose ] translation: Language 'English (Great Britain)'.
[warn ] tinygettext: jbo.po: warning: ignoring, unknown language
[warn ] tinygettext: no.po: warning: ignoring, unknown language
[warn ] tinygettext: no_NO.po: warning: ignoring, unknown language
[warn ] tinygettext: sc.po: warning: ignoring, unknown language
[warn ] tinygettext: sco.po: warning: ignoring, unknown language
[info ] IrrDriver: OpenGL version: 2.1
[info ] IrrDriver: OpenGL vendor: Broadcom
[info ] IrrDriver: OpenGL renderer: Gallium 0.4 on VC4 V3D 2.1
[info ] IrrDriver: OpenGL version string: OpenGL ES 2.0 Mesa 13.0.6
[info ] GLDriver: EXT texture format BGRA8888 Present
[warn ] irr_driver: Driver doesn't support shader-based pipeline. Re-creating device to workaround the issue.
[warn ] irr_driver: Using the fixed pipeline (old GPU, or shaders disabled in options)
[info ] HTTPRequest: Downloading
http://addons.supertuxkart.net/dl/xml/news.xml
[info ] addons: Using cached addons.xml.
http://addons.supertuxkart.net/dl/image ... 517f49.png
http://addons.supertuxkart.net/dl/image ... 3e4cd1.jpg
[info ] GrandPrixManager: Loading Grand Prix files from ../../data/grandprix/
[info ] GrandPrixManager: Loading Grand Prix files from /home/pi/.local/share/supertuxkart/grandprix/
[warn ] OpenGL: OpenGL version is too old!
[verbose ] RaceManager: Nb of karts=4, ghost karts:0 ai:3 players:1
[warn ] material: Track uses deprecated texture 'redwhite.png'
[info ] Singleton: Destroyed singleton.
