gzdoom on raspberry pi
I've heard that gzdoom has been ported to openpandora.Can it be ported to Pi
Re: gzdoom on raspberry pi
People who think they know everything are a great annoyance to those of us who do
It is zdoom and it runs choppy.gzdoom uses gpu but zdoom uses cpu.
I have ported GZdoom to he Pandora. I used an old version of GZdoom because newer ones need shaders and I didn't want to port to GLES2 (I use gl4es on the Pandora to provide GPU acceleration).
If you want to try something on the RPi, I suggest you try Zandronum. Use my bitbucket repo there: https://bitbucket.org/ptitSeb/zandronum
I think it has been compiled on a ODroid, so it should work on RPi too.
I'm happy to join this conversation because I'm still searching for the "definitive" source port of (not-vanilla) DOOM on Raspberry Pi.
Currently the scene, IMHO, is a bit confused on RPi, with A LOT of "untapped potential": in Raspbian repos there is PrBOOM that seems GLES accelerated but old and a bit buggy (no way to enable Vsync). I tested ZDOOM from RetroPie script: it's easy to install and OK on low resolutions, but at 1280x1024 frames drop consistently (probably being rendered in software mode).
I constantly read about "spontaneous" portings by/for skilled users, but at the end binaries are not updated or are not "officially" tested on RPI (some do work only under X11, some are extremely difficult to compile, some are not HW accelerated, some are outdated etc.). I understand that this is "part of the game" on Raspberry, but IMHO it's also unfortunate to see so many projects and efforts left "pending" without a real source port optimized and maintained.
I've tried yet to raise awareness on Doomworld Forums, and I write also here: if someone of good will has ported yet a DOOM engine (not vanilla) successfully on RPi with GLES acceleration, please "love" the same project putting it on Github (or SourceForge) and keep it updated, or even better propose a merge with an main source port (like GZDoom).
Thanks! ;D
Thanks! ;D
when i am compiling i get the following error:
-- The C compiler identification is GNU 4.9.2
-- The CXX compiler identification is GNU 4.9.2
-- Check for working C compiler: /usr/bin/cc
-- Check for working C compiler: /usr/bin/cc -- works
-- Detecting C compiler ABI info
-- Detecting C compiler ABI info - done
-- Detecting C compile features
-- Detecting C compile features - done
-- Check for working CXX compiler: /usr/bin/c++
-- Check for working CXX compiler: /usr/bin/c++ -- works
-- Detecting CXX compiler ABI info
-- Detecting CXX compiler ABI info - done
-- Detecting CXX compile features
-- Detecting CXX compile features - done
-- Could NOT find BZip2 (missing: BZIP2_LIBRARIES BZIP2_INCLUDE_DIR)
-- Found JPEG: /usr/lib/arm-linux-gnueabihf/libjpeg.so
-- Found ZLIB: /usr/lib/arm-linux-gnueabihf/libz.so (found version "1.2.8")
-- Could NOT find GME (missing: GME_LIBRARIES GME_INCLUDE_DIR)
-- Using system zlib
-- Using system jpeg library
-- Using internal bzip2 library
-- Using internal gme library
-- Performing Test HAVE_NO_ARRAY_BOUNDS
-- Performing Test HAVE_NO_ARRAY_BOUNDS - Success
-- Performing Test __LIBGME_TEST_VISIBILITY
-- Performing Test __LIBGME_TEST_VISIBILITY - Success
-- Performing Test CAN_DO_CPP14
-- Performing Test CAN_DO_CPP14 - Success
-- Looking for strnicmp
-- Looking for strnicmp - not found
-- SQLite: downloading the archive...
CMake Error at sqlite/CMakeLists.txt:30 (message):
SQLite: download failed. Reason: "Couldn't connect to server"
-- Configuring incomplete, errors occurred!
See also "/home/pi/Downloads/ptitSeb-zandronum-56791949b0cf/CMakeFiles/CMakeOutput.log".
See also "/home/pi/Downloads/ptitSeb-zandronum-56791949b0cf/CMakeFiles/CMakeError.log".
For this compile issue. I never had this issue. Is you RPi on network?
Also, you can probably install sqlite from some sudo apt-get or compile it from source and that should fix the issue.
*EDIT* : I rechecked the CMAkeList and no, it needs to be downloaded.
It should download v3.14.1 and inside sqlite/ you should see that file: sqlite-86bfed5752783fb24c051f3efac5972ce11023f0.tar.gz
I keep my repo of Zandronum petty much up-to-date with upstream (that is also on bitbucket). I test it on Pandora and can do some test on ODroid (that is very similar to RPi), but I cannot test on RPi (I don't have any). This version has no GLES port, I rely on GL wrapper for hardware acceleration. my gl4es wrapper (on guthub there: https://github.com/ptitSeb/gl4es ) works on RPI and so can be use, but I think there is also a beta OpenGL driver on the RPi that can probably be used too.antiriad wrote:Hi,
Thanks! ;D
This forum post is from my RPi 2.I changed to wired but it dos'ent work
Ah, ok. Let me try again on a vm, I'll clean the build folder to be sure.
It works on my side.
You can download it manually.
get
https://www.sqlite.org/2016/sqlite-auto ... 100.tar.gz
rename it to sqlite-774a05b8e7c9318111228bd5ad6bf65272f3fe38.tar.gz
and put that archive inside sqlite subfolder. The cmake process should then complete.
get
Now this error:
-- Looking for strdup
-- Looking for strdup - found
-- Looking for strndup
-- Looking for strndup - found
-- Looking for sys/types.h
-- Looking for sys/types.h - found
-- Looking for stdint.h
-- Looking for stdint.h - found
-- Looking for stddef.h
-- Looking for stddef.h - found
-- Check size of char
-- Check size of char - done
-- Check size of short
-- Check size of short - done
-- Check size of int
-- Check size of int - done
-- Check size of long
-- Check size of long - done
-- /usr/include
-- /home/pi/Downloads/ptitSeb-zandronum-56791949b0cf/bzip2
-- /home/pi/Downloads/ptitSeb-zandronum-56791949b0cf/lzma/C
-- Looking for itoa
-- Looking for itoa - not found
-- Performing Test DUMB_CAN_USE_SSE
-- Performing Test DUMB_CAN_USE_SSE - Failed
CMake Warning (dev) at gdtoa/CMakeLists.txt:25 (get_target_property):
Policy CMP0026 is not set: Disallow use of the LOCATION target property.
Run "cmake --help-policy CMP0026" for policy details. Use the cmake_policy
command to set the policy and suppress this warning.
The LOCATION property should not be read from target "arithchk". Use the
target name directly with add_custom_command, or use the generator
expression $<TARGET_FILE>, as appropriate.
This warning is for project developers. Use -Wno-dev to suppress it.
CMake Warning (dev) at gdtoa/CMakeLists.txt:34 (get_target_property):
The LOCATION property should not be read from target "qnan". Use the
CMake Warning (dev) at CMakeLists.txt:29 (get_target_property):
The LOCATION property should not be read from target "zipdir". Use the
Call Stack (most recent call first):
wadsrc/CMakeLists.txt:3 (add_pk3)
wadsrc_bm/CMakeLists.txt:3 (add_pk3)
CMake Warning (dev) at wadsrc_st/CMakeLists.txt:3 (get_target_property):
wadsrc_st/CMakeLists.txt:5 (add_pk3)
-- Found PkgConfig: /usr/bin/pkg-config (found version "0.28")
-- Found OpenGL: /usr/lib/arm-linux-gnueabihf/libGL.so
-- Found PythonInterp: /usr/bin/python3 (found suitable version "3.4.2", minimum required is "3")
-- Checking for module 'gtk+-2.0'
-- No package 'gtk+-2.0' found
-- Checking for module 'openal'
-- Found openal, version 1.15.1
-- Looking for pthread.h
-- Looking for pthread.h - found
-- Looking for pthread_create
-- Looking for pthread_create - not found
-- Looking for pthread_create in pthreads
-- Looking for pthread_create in pthreads - not found
-- Looking for pthread_create in pthread - found
-- Found Threads: TRUE
-- Found SDL: /usr/lib/arm-linux-gnueabihf/libSDLmain.a;/usr/lib/arm-linux-gnueabihf/libSDL.so;-lpthread (found version "1.2.15")
-- Could not find FMOD include files
-- Could NOT find SndFile (missing: SNDFILE_LIBRARY SNDFILE_INCLUDE_DIR)
-- Could NOT find MPG123 (missing: MPG123_LIBRARIES MPG123_INCLUDE_DIR)
-- Could NOT find FluidSynth (missing: FLUIDSYNTH_LIBRARIES FLUIDSYNTH_INCLUDE_DIR)
-- Could not find NASM. Disabling assembly code.
-- Performing Test CAN_DO_MFPMATH
-- Performing Test CAN_DO_MFPMATH - Failed
-- Performing Test CAN_DO_ARCHSSE2
-- Performing Test CAN_DO_ARCHSSE2 - Failed
-- Looking for filelength
-- Looking for filelength - not found
-- Looking for strupr
-- Looking for strupr - not found
-- Looking for stricmp
-- Looking for stricmp - not found
-- Looking for clock_gettime in rt
-- Looking for clock_gettime in rt - found
-- Performing Test HAS_VA_COPY
-- Performing Test HAS_VA_COPY - Success
CMake Warning (dev) at src/CMakeLists.txt:707 (get_target_property):
The LOCATION property should not be read from target "updaterevision". Use
the target name directly with add_custom_command, or use the generator
-- Fluid synth libs: FLUIDSYNTH_LIBRARIES-NOTFOUND
CMake Error at /usr/share/cmake-3.6/Modules/FindPackageHandleStandardArgs.cmake:148 (message):
Could NOT find OpenSSL, try to set the path to OpenSSL root folder in the
system variable OPENSSL_ROOT_DIR (missing: OPENSSL_LIBRARIES
OPENSSL_INCLUDE_DIR)
/usr/share/cmake-3.6/Modules/FindPackageHandleStandardArgs.cmake:388 (_FPHSA_FAILURE_MESSAGE)
/usr/share/cmake-3.6/Modules/FindOpenSSL.cmake:380 (find_package_handle_standard_args)
src/CMakeLists.txt:730 (FIND_PACKAGE)
That didn't work for me, but what did work was installing "libssl-dev".ptitSeb wrote:you are missing openssl.
Try someCode: Select all
sudo apt-get install libgnutls-openssl-dev
I also had to install "libglew-dev", else the compilation failed after about 32%, but even then it fails at 99% with:
/usr/bin/ld: CMakeFiles/zdoom.dir/asm_ia32/a.o: Relocations in generic ELF (EM: 3)
CMakeFiles/zdoom.dir/asm_ia32/a.o: error adding symbols: File in wrong format
collect2: error: ld returned 1 exit status
src/CMakeFiles/zdoom.dir/build.make:11057: recipe for target 'zandronum' failed
make[2]: *** [zandronum] Error 1
CMakeFiles/Makefile2:1032: recipe for target 'src/CMakeFiles/zdoom.dir/all' failed
make[1]: *** [src/CMakeFiles/zdoom.dir/all] Error 2
Makefile:83: recipe for target 'all' failed
make: *** [all] Error 2
You need to set NO_ASM to ON.
you can use ccmake, the curse gui for cmake, to easily change parameters before compile.
Anyway, I have just pushed a change to my repo to make NO_ASM default now.
How well does this run maybe 30 or 60 fps
when i launch using gl4es it does'nt work in gl renderer.when using only ./zandronum it gives me a black screen
after that i edited zandronum.ini it runs in standard x11 but slowish.gl4es gives me this:
LIBGL: Initialising gl4es
LIBGL: v0.9.5 built on Apr 2 2017 09:28:39
LIBGL: framebuffer output enabled
LIBGL:loaded: libbcm_host.so
LIBGL:loaded: libvcos.so
LIBGL:loaded: libGLESv1_CM.so
LIBGL:loaded: libEGL.so
LIBGL: Extension GL_OES_framebuffer_object detected and used
LIBGL: Extension GL_OES_depth24 detected and used
LIBGL: Extension GL_OES_rgb8_rgba8 detected and used
LIBGL: Extension GL_EXT_texture_format_BGRA8888 detected and used
LIBGL: Max texture size: 2048
LIBGL: Texture Units: 4, Max lights: 8
LIBGL: Implementation Read is GL_RGBA/GL_UNSIGNED_BYTE
LIBGL: Current folder is:/home/pi/zandronum
Mmmm, seems like I have introduce a bug and I get a crash trying to use glBlendEquation on my VM. I'll try to fix that (in gl4es)
I have fixed gl4es. But it seems your GLES1.1 driver doesn't expose BlendEquation extension anyway.
I still have to fix my Zandronum repo to manque Pandora specific changes (800x480 forced resolution, special keymap...) behind a PANDORA define. I'm working on it now.
@raysaaron
I have pushed some changes to gl4es (fixing a bug with glBlendEquation) and to Zandronum (moving all Pandora code behind a PANDORA define).
i've tried updateing my gl4es driver but it did'nt work
What do you mean by "it doesn't work"? It doesn't start and crash? just exit? give a black screen (in that case, try to remove ~/.config/zandronum or whatever the folder of the config is on your machine).
Aso, I'm surprised by the small number of extension GL4ES found in the previous copy of the console you pasted earlier.
Do you have some "eglinfo" output or something similar, so I can see the extensions your GLES 1.1 driver is supporting?
Here is my gl extensions:
GL_VENDOR: ptitSeb
GL_RENDERER: GLES_CM wrapper
GL_VERSION: 1.5 gl4es wrapper
GL_EXTENSIONS:
GL_EXT_abgr
GL_EXT_packed_pixels
GL_EXT_compiled_vertex_array
GL_ARB_vertex_buffer_object
GL_ARB_vertex_array_object
GL_EXT_vertex_array
GL_EXT_secondary_color
GL_EXT_texture_env_combine
GL_ARB_multitexture
GL_ARB_texture_env_add
GL_ARB_texture_border_clamp
GL_ARB_point_parameters
GL_EXT_texture_env_add
GL_ARB_texture_env_combine
GL_ARB_texture_env_crossbar
GL_ARB_texture_env_dot3
GL_ARB_texture_mirrored_repeat
GL_SGIS_generate_mipmap
GL_EXT_packed_depth_stencil
GL_EXT_draw_range_elements
GL_EXT_bgra
GL_ARB_texture_compression
GL_EXT_texture_compression_s3tc
GL_OES_texture_compression_S3TC
GL_EXT_texture_compression_dxt3
GL_EXT_texture_compression_dxt5
GL_EXT_texture_compression_dxt1
GL_EXT_point_parameters
GL_EXT_stencil_wrap
GL_SGIS_texture_edge_clamp
GL_EXT_texture_edge_clamp
GL_EXT_direct_state_access
GL_EXT_multi_draw_arrays
GL_SUN_multi_draw_arrays
GL_ARB_multisample
GL_EXT_texture_object
GL_EXT_polygon_offset
GL_GL4ES_hint
GL_ARB_texture_rectangle
GL_EXT_blend_color
GL_ARB_framebuffer_object
GL_EXT_framebuffer_object
GL_ARB_draw_buffers
