TechDark
LXDE on RetroPie not starting
Wed Mar 01, 2017 3:17 pm
Hello!
I am trying to make my own game console by downloading RetroPie which is all fine
But here is the problem. When i have installed LXDE Pixel on the RetroPie, the screen turns black and goes back to the ports selection
What is wrong and what should i do?
PrettyCoolBruh
Re: LXDE on RetroPie not starting
Sat Mar 11, 2017 6:58 pm
I have been having the same problem, and I have somewhat of a work-around for it.
1. Press the 'F4' Key to go to terminal (if you need to go back to RetroPie, type in
emulationstation
2. Type in
cd RetroPie/roms/ports
3. Run
ls
to see if you have 'desktop.sh'
a. If you don't have it, you will have to delete the LXDE environment and install another one. Hopefully, that will have a desktop.sh, as well as a fix for this issue
b. If you do have it, run
sudo sh desktop.sh
This should now work, but keep in mind that running the 'sudo' command can do some destructive commands to the computer (as you are running as root). Since you're running as root, you should keep in mind that opening a terminal will run commands as if you are root. To fix this, just run a su command in the terminal. As this is happening, opening a file manager will also go to the root directory, what can confuse you is that downloads from the Internet will store your downloads in the root folder (/root/Downloads). So basically, make sure you know what you're doing.
Hope this helps
Return to “Gaming”
