Raspigamer
Powerboost Power Supply
Tue Jan 03, 2017 12:47 am
I want to know what charger I should get/use for my Powerboost 1000c right now I have this power supply http://www.canakit.com/raspberry-pi-ada ... -2-5a.html I wanted to know weather this is the right power supply or not because adafruit doesn't actually say what the input voltage is
klricks
Re: Powerboost Power Supply
Tue Jan 03, 2017 3:01 am
Raspigamer wrote:I want to know what charger I should get/use for my Powerboost 1000c right now I have this power supply http://www.canakit.com/raspberry-pi-ada ... -2-5a.html I wanted to know weather this is the right power supply or not because adafruit doesn't actually say what the input voltage is
Since the charge port on the Powerboast board is micro USB, the input charge voltage is 5V.
From the FAQ the current used in the charging circuit is up to 1800 mA
Note the 1000c could probably run a RPi Zero or maybe a headless RPi 1, but not likely to do well with a RPi 2 or 3.
Return to “Gaming”
