chernandezba
New stable version ZEsarUX 4.2
Thu Dec 08, 2016 4:57 pm
Hi everyone!
I have uploaded a new stable version of ZEsarUX emulator, version 4.2.
You can download it from:
https://sourceforge.net/projects/zesarux/
Changes are:
Added machine Spectrum 48k Spanish
Added machine Pentagon 128
Added .ay file player for Spectrum and CPC files
Added AY Piano menu to view notes
Added Turbosound emulation
Added ZX Dandanator! Mini emulation
Added Superupgrade emulation
Added experimental 8-bit simple IDE emulation
Added Z88 Hybdrid (RAM+Eprom) Card support
Added print char traps for TBBlue, CPC464, Sam Coupe
Added three new Prism video modes: 256x128, 128x128, both at 256 colours, and 4 plane 256 colour mode clashless
Added Sam Coupe GUI Style
Added Sam Coupe curses, stdout, simpletext video drivers
Added Setting to disable colours (set to black & white) on Spectrum
Added Setting to disable loading tape sound
Added setting to change DivIDE/DivMMC RAM
Added tape browser
Added Z88 generic card browser
Added Z88 card browser when copying from eprom/flash card
Fixed bug reading ports 2ffd and 3ffd and crashes running +2A/+3 ROMS with real video enabled
Fixed Z80 cold start registers
Fixed Z88 bug when smart loading all slots were ejected
Fixed handling symbols (. , : / - + < > = ' ( ) ") on menu for machines: Z88, CPC, Sam Coupe
Fixed enabling some memory and debug interfaces, so you can enable and disable them in any order you want
Fixed divmmc/divide were disabled when doing smartload
Fixed drawing of some menu items that refresh continuously: waveform, ay registers, cpu stats, debug cpu, visualmem
Fixed ZXpand emulation on ZX80
Improved menu. Now all settings are on a separate "Settings" menu
Improved debugger:
*Individual breakpoints can be disabled
*Breakpoints are fired by default when condition changes from false to true. And they are only fired again when condition changes from true to false and false to true
Improved scanlines drawing. Some demos with display page change (RAM 5&7) on a scanline run perfect
Improved windows with text content. Now a progress symbol (*) is shown
Improved floating bus value
Updated Z88 OZ V4.6.2
Updated ZXUno Flash and MMC image to the crowdfunding ones. MMC image now is called "zxuno.mmc"
Updated TBBlue emulation to use new I/O ports
Some other minor bugfixes and improvements
I hope you like it :)
Cheers
Cesar
windale
Re: New stable version ZEsarUX 4.2
Thu Dec 22, 2016 11:14 pm
Could you add RZX support ? So we can at least watch the RZX replays, I'm not too bothered about making them.
chernandezba
Wed Apr 19, 2017 11:59 am
Sorry for the delay, I didn't see your question.
Yes, last ZEsarUX beta version does include RZX playback. It doesn't work well with all rzx files, seems that different emulators generate slightly different rzx files. But it works 50% of times
Cheers
Cesar
chernandezba
Wed Apr 19, 2017 12:00 pm
By the way, in a few days I will release next ZEsarUX 5.0 stable version. Lots of changes on it, the most important is Sinclair QL emulation ;)
https://sourceforge.net/p/zesarux/code/ ... /Changelog
Return to “Gaming”
