Page 3 of 3
Re: Unreal Speccy Portable - ZX Spectrum emulator
Posted: Wed Apr 15, 2015 7:00 am
by Higgy
Thanks.
The ZX Spectrum emulators seem to be having a new spurt of development which is great. 8-)
Posted: Fri Apr 17, 2015 9:40 am
by AmigaGamer
Thanks for this update. Its a great emulator i use it on my android tablet as well.
The joypad support is a welcome improvement.
Is there a way to define which joypad button operates as Fire?
An option to assign a button to Open the menu would be good too , perhaps in a future version? :)
Posted: Sun Dec 13, 2015 5:15 pm
by barrybarryk
I had a problem with my Joystick not working properly (button worked but the stick was non-responsive) turned out SDL sees my stick as a POV Hat and the emu doesn't support it. I managed to get it sorted by making a few changes and recompiling.
In sdl_joystick.cpp:
I added a new function 'ProcessHat':
static void ProcessHat(bool state, bool state_prev, byte key)
	if(state == state_prev) // state not changed
		return;
	if(state) // pressed
		Handler()->OnKey(key, KF_DOWN|OpJoyKeyFlags());
	else // released
		Handler()->OnKey(key, OpJoyKeyFlags());
And changed ProcessJoy:
void ProcessJoy(SDL_Event& e)
	static bool north, east, south, west, pre_north, pre_east, pre_south, pre_west;
	static ePadState pad, pad_prev;
	switch(e.type)
	//HAT Hack
	case SDL_JOYHATMOTION:
		pre_north = north;
		pre_east = east;
		pre_south = south;
		pre_west = west;
		north = false;
		east = false;
		south = false;
		west = false;
		if (e.jhat.value & SDL_HAT_UP)
			north = true;
		if (e.jhat.value & SDL_HAT_RIGHT)
			east = true;
		if (e.jhat.value & SDL_HAT_DOWN)
			south = true;
		if (e.jhat.value & SDL_HAT_LEFT)
			west = true;
		break;
	case SDL_JOYBUTTONDOWN:
			if(e.jbutton.button < PB_COUNT)
				pad.buttons[e.jbutton.button] = true;
		break;
	case SDL_JOYBUTTONUP:
				pad.buttons[e.jbutton.button] = false;
		break;
	case SDL_JOYAXISMOTION:
			if(e.jaxis.axis < AXES_COUNT)
				pad.axes[e.jaxis.axis] = float(e.jaxis.value)/32768;
		break;
	default:
		break;
	ProcessHat(north, pre_north, 'u');
	ProcessHat(east, pre_east, 'r');
	ProcessHat(south, pre_south, 'd');
	ProcessHat(west, pre_west, 'l');
	ProcessButton(PB_UP, pad, pad_prev, 'u');
	ProcessButton(PB_DOWN, pad, pad_prev, 'd');
	ProcessButton(PB_LEFT, pad, pad_prev, 'l');
	ProcessButton(PB_RIGHT, pad, pad_prev, 'r');
	ProcessButton(PB_A, pad, pad_prev, 'f');
	ProcessButton(PB_B, pad, pad_prev, 'e');
	ProcessButton(PB_X, pad, pad_prev, '1');
	ProcessButton(PB_Y, pad, pad_prev, ' ');
	ProcessButton(PB_SELECT, pad, pad_prev, 'm');
	ProcessButton(PB_START, pad, pad_prev, 'k');
	ProcessAxis(0, pad, pad_prev, 'r', 'l');
	ProcessAxis(1, pad, pad_prev, 'd', 'u');
	ProcessAxis(3, pad, pad_prev, 'r', 'l');
	ProcessAxis(4, pad, pad_prev, 'd', 'u');
	ProcessAxis(6, pad, pad_prev, 'r', 'l');
	ProcessAxis(7, pad, pad_prev, 'd', 'u');
	if(ButtonPressed(PB_LSHIFT, pad, pad_prev) || ButtonPressed(PB_LTRIGGER, pad, pad_prev))
		Handler()->OnAction(A_RESET);
	if(ButtonPressed(PB_RSHIFT, pad, pad_prev) || ButtonPressed(PB_RTRIGGER, pad, pad_prev))
		using namespace xOptions;
		eOptionB* o = eOptionB::Find("pause");
		SAFE_CALL(o)->Change();
	if(ButtonState(PB_SELECT, pad) && ButtonState(PB_START, pad))
		OpQuit(true);
	pad_prev = pad;
In sdl.cpp I added the SDL_JOYHATMOTION to the events polled:
#ifdef SDL_USE_JOYSTICK
				ProcessJoy(e);
				break;
#endif
And the only other change was adding "-lbcm_host" to the RPi makefile to get it to compile correctly for the pi
LFLAGS = -s -L$(SDKSTAGE)/opt/vc/lib -lbcm_host -lGLESv2 -lEGL `sdl-config --libs` -lz
After that, it's perfectly fine and now I can enjoy my speccy games with my Zipstick :D
Edit: I got the source for the version I edited from here this afternoon btw
Posted: Sun Apr 03, 2016 2:43 am
by jfroco
Hello
I've been using USP for a long time, however I noticed it runs faster than a real Spectrum in my Raspberry Pi Model B
This is obvious when playing Manic Miner (the music and the sprites move faster)
I've tested using HDMI (most modes) and analog video output in both NTSC and PAL.
My Raspberry PI is not overclocked
Do you have the same issue?
Thank you!!
Posted: Thu Jul 14, 2016 1:29 pm
by Andrey
jfroco wrote:I've been using USP for a long time, however I noticed it runs faster than a real Spectrum in my Raspberry Pi Model B
Hi!
It's because of emulating russian clone Pentagon 128K, it have a little speedup over standard ZX Spectrum 48/128K.
BTW, new version for Raspberry Pi is released.
Implemented web sources, now you can open files directly from web (VTRDOS/RZXARCHIVE).
https://bitbucket.org/djdron/unrealspeccyp/downloads
Posted: Thu Jul 14, 2016 1:32 pm
by Andrey
barrybarryk wrote:I had a problem with my Joystick not working properly (button worked but the stick was non-responsive) turned out SDL sees my stick as a POV Hat and the emu doesn't support it. I managed to get it sorted by making a few changes and recompiling.
Hello!)
Can you submit a patch with your improvements?
Posted: Sun Sep 04, 2016 3:10 pm
by Andrey
Small update 0.0.69.1.
  1. http://bbb.retroscene.org/ web source added
  2. press section from vtrdos web source added
Posted: Thu May 10, 2018 11:06 pm
by Andrey
There is new experimental version for raspbian stretch with ATM TURBO 2+ support.
Also Mr. Gluk reset service used instead of MadRom.
https://bitbucket.org/fyrex/unrealspecc ... downloads/
Posted: Fri May 18, 2018 4:48 pm
by Andrey
Just added joystick hat motion processing.
