I'm still quite new to Linux, so I don't understand why I've run into this where others have not, or what I must do to fix it. For what it's worth, my PKG_CONFIG_PATH variable seems to be empty, but I don't know how to find this bluez.pc it's looking for.Package bluez was not found in the pkg-config search path.
Perhaps you should add the directory containing `bluez.pc'
to the PKG_CONFIG_PATH environment variable
Perhaps... I can't run that one though, because it's incompatible with both Java and Mono (and I have plans for using those with the PS3 controller).Spid wrote:I believe that most bloggers and tinkerers etal when talking about the Raspberry Pi they actually mean Raspbian "wheezy" which is ARMHF......
Java work *fine* using Rasbian armhf, OpenJDK have worked for months since Rasbian creation and Oracle JDK also work excellent.JoeStrout wrote:Perhaps... I can't run that one though, because it's incompatible with both Java and Mono (and I have plans for using those with the PS3 controller).Spid wrote:I believe that most bloggers and tinkerers etal when talking about the Raspberry Pi they actually mean Raspbian "wheezy" which is ARMHF......
I did try a sudo apt-get install bluez, which installed something, but the make attempt still fails.
sudo apt-get install bluez-utils bluez-compat bluez-hcidump checkinstall libusb-dev libbluetooth-dev joystick
Has anyone else seen this issue, I did a clean install of raspbian 2013-02-09 recently and ran into the same problem...Jako wrote:Hi! I updated raspbian and "sixad" don't works now. With "make" again the problem is the same. Sixad says:
sixad-bin[3714]: unable to connect to sdp session
That never happened before.
I tried to find some info about the "sdp session" on debian and at all i didn't got any conclusion. Cheking older images with my sixad conifg working don't give me any hint about the "sdp" service.
I just followed the tutorial at http://booting-rpi.blogspot.ro/2012/08/ ... ry-pi.html and have it working on wheezy. I had to run "sudo apt-get update" first which wasn't mentioned in the tutorial but is a good idea before installing anything via apt-get.Aquifel wrote:I am having the same issue as well, has anyone ever found a fix for this on raspbian?
[/quote]I think this could be the cause. I have no hcid.conf file but I read that the main.conf file has replaced hcid.conf file with newer versions. I dont see anywhere relevant to these options. Please help am getting very frustrated
+1mattlewis wrote:(...) exactly the same behaviour as reported here, i.e. "unable to connect to sdp session" message and flashing lights on the controller.
[email protected] ~ $ sudo sixad --start
sixad-bin[2494]: started
sixad-bin[2494]: sixad started, press the PS button now
sixad-bin[2494]: unable to connect to sdp session
sixad-bin[2494]: Connected Sony Computer Entertainment Wireless Controller (60:38:0E:75:A1:D4)
