PrettyCoolBruh
How to install quake3 on Raspbian the Simpler Way!
Mon Nov 28, 2016 1:13 am
Hey all,
So I was reading the forums, and stumbled onto How to install/ build/ play Quake 3.... by raspberrypiguy1. Amazing guide. I thank him for doing this :D But when I saw it, it was a bit complicated. Here is the simpler way to get quake 3. Enjoy!
Change to the directory where you will store the downloaded files:
cd /home/pi/
Download the files using wget:
wget http://radium.hexxeh.net/quake3.zip
wget http://www.andershizzle.com/Q3%20Demo%20Paks.zip
OR if you have registered .pk3 files, ignore the second wget
and follow as normal
Unzip the two files you just downloaded using unzip:
unzip quake3.zip
unzip Q3\ Demo\ Paks.zip
Move all of the pak files that were extracted from Q3 Demo Paks.zip over to quake3/baseq3/ using the mv command:
mv baseq3/pak* quake3/baseq3/
Change the file permissions using chmod:
chmod +x quake3/start.sh
chmod +x quake3/ioquake3.arm
chmod +x quake3/ioq3ded.arm
Change the current directory:
cd quake3
Then you can start it with the following command:
./start.sh
If there is any errors, PLEASE REPLY :)
Reference: http://blog.modmypi.com/2012/06/1.html
Okay, so if you have the registered pk3 files then cd to your quake3 directory
cd quake3/
then perform the mv command:
mv [your registered .pk3 files] baseq3
Then your done!
-PrettyCoolBruh
People who think they know everything are a great annoyance to those of us who do
peabody1929
Re: How to install quake3 on Raspbian the Simpler Way!
Wed Nov 30, 2016 1:17 am
I get an error on the website:
This site can’t be reached
radium.hexxeh.net’s server DNS address could not be found.
Return to “Gaming”
