PrettyCoolBruh
Quake3 and OpenArena on RPi Arch Linux
Mon Nov 28, 2016 12:58 am
Hey all,
Before you point out this is not Raspbian, yes. I am fully aware of that. The reason why I am posting this is because I have struggled with this a lot and found out that it was simple fix. I didn't want others to go through this, so I made this simple guide.
Okay, so open your LXTerminal, then type in:
sudo pacman -S ioquake3
It was a simple fix, and made me pretty mad, but at least it works now. Note that it installs the shareware files too, so you don't have to grab those. If you have a registered copy (assuming you followed the guide), open terminal, then type in
cd ~/.q3a
grab your registered .pk3 files, then do
mv [where your .pk3 files are] ~/.q3a/baseq3
Done! Keep in mind that the .q3a folder is HIDDEN in your HOME directory, not the / directory. To see your .q3a folder, go to the PCMan File Manager, go to your home directory, then click on view>>Show Hidden Items. That's it!
Now for OpenArena. Grab the .pk3 files from OpenArena, then do
cd ~/.q3a/baseq3
then do
mkdir oa
Finally, then do
mv [where your OpenArena .pk3 files are] ~/.q3a/baseq3/oa
Then go to ioquake3, select Mods, and click on oa. It should run. Enjoy!
-PrettyCoolBruh
People who think they know everything are a great annoyance to those of us who do
ellisgl
Re: Quake3 and OpenArena on RPi Arch Linux
Sat Mar 11, 2017 4:17 am
Out of the box (from shell), sudo doesn't exist. So ended up SU'ing to root. And packman -S ioquake3 comeback with target not found. Did you add extra repos?
ellisgl
Sat Mar 11, 2017 4:19 am
Actually it looks like it's been named ioquake3-rbp
PrettyCoolBruh
Sat Mar 11, 2017 6:43 pm
ellisgl wrote:Actually it looks like it's been named ioquake3-rbp
It should automatically resort to the ARM/Raspberry Pi build of Quake3. The AUR Package is available at https://aur.archlinux.org/packages/ioquake3/
Return to “Gaming”
