Emmet_Dude
Wired PS3 Controller Works in Menu OR Game, Never both?
Sun Oct 02, 2016 2:33 pm
Hi everyone!
Sorry i'm completely new to the whole Raspberry Pi/Retropie scene and I've been having a really frustrating problem that i haven't been able to find an answer to, i'm using a Raspberry Pi 3 Model B running retropie mounted on a micro SD card, initially i was using cheap USB SNES controllers and they worked really well, could play the games fine and navigated the menus too, but then, because they were so cheaply made they both broke in a couple of days, buttons pushed right in or just not registering
So i invested in 2 Wired USB PS3 controllers from Argos seen here http://www.argos.co.uk/static/Product/p ... 685374.htm , and this is where the problems started, now i switch the pi on, configure the PS3 controller buttons (it shows up as like Acrux Gaming Pad) and that's great, it navigates the menu's and games lists perfectly, but when i start a game up on any of the consoles none of the buttons work at all, every time, so then i have to connect my USB keyboard, go in through the F1 menu and bind all the buttons again, then the controller works perfect in game, however when I'm done playing it, i'll press the "home" button to go back to the Retropie menu, it does, and none of the buttons work on there, i can't navigate the menu or reconfigure the controller so I had to switch it directly off then on again to start from the beginning again (which i believe is really bad for it)
So i'm wondering, does someone out there know how i can get the wired PS3 controllers to work in the menu's AND in the games without having to manually configure them in game every single time?
I've been trying to sort this out myself for about a week now searching through forums and wiki's but no joy, so any help at all would be greatly appreciated, i'm a total newbie at all this though so i'd need quite a bit of guidance
Thank you all in advance
Emmet_Dude
Goraxium
Re: Wired PS3 Controller Works in Menu OR Game, Never both?
Mon Oct 03, 2016 7:27 am
From memory, the settings you use in the emulator (when the games are running) aren't automatically saved. There's an option in one of the menus to enable saving on exit, as well as one to save the config as is.
Emmet_Dude
Mon Oct 03, 2016 12:38 pm
Hi, huge thanks for replying!
I've actually tried that option before, I told it to save setup on exit and save the controller config for next time through the F1 menu,
but when I exit the game that I reconfigured the controller in, it doesn't navigate the menus anymore, can't move to the controller config menu, keyboard doesn't work either so I just have to hard reset the console and do it all again, and when I go into the same game, the controller needs configured again
It's really frustrating and I've no idea how to make sure the controllers work in game AND on the menu
Emmet_dude
Return to “Gaming”
