bubblegumpi wrote:scotty101 wrote:The KSP linux version has been compiled for running in "Intel compatible" x86 processors not ARM.
A bit more informative than the first post. Anyways is ARM the exception not the rule? Does this become a big problem when you are trying to use most "linux" programs? I bought the pi so I could have a Linux machine to learn and complement the PC. Or am I going to find out that there are alot of limitations due to the ARM architecture? One big thing is I want to use Software Defined Radio on it, but that doesn't do any good if most/everything is x86.
you asked a simple question - I provided the answer in the best way possible - if you wanted more info maybe the question could of been phrased better.
however
if you want to do 90% of what linux boxes do - i.e. the packages that are in the debian apt-get system then the RPi is fine -and will get you a long way down the road ,
if you want to run specialized programs from none authoritative sources then you will have difficulties [not that there is not a way for these things to work] YMMV
running a RPi is a great way of complimenting your x86 PC just be aware that it is not a machine that has the same power of most laptops / desktop you are likely to have
