Raspigamer
Moonlight Pair
Wed Sep 14, 2016 11:01 pm
I have installed Moonlight on to my raspberry pi using this tutorial. http://jordanhotmann.com/guide-install- ... nretropie/
Everything works fine except when I use moonlight pair <Computer IP> it doesn't do anything for several minutes then it tells me that it cannot connect to my computer's IP address. Any help?
joeygbsn
Re: Moonlight Pair
Sat Sep 17, 2016 4:21 am
Every time I've installed moonlight I just used sudo apt-get install moonlight and then everything just works. Maybe you could try that way instead of compiling it yourself. Then you can just follow that guide from the configuring moonlight section.
Return to “Gaming”
