rpiMike
PokeMMO
Fri Jul 15, 2016 10:40 pm
How to get PokeMMO running on the Raspberry Pi2 or Pi3 :
1: If you've not yet enabled the experimental OpenGL driver then follow steps 1-5 here :
viewtopic.php?t=137279
2: Download 2 install scripts :
cd ~/Downloads && wget https://www.dropbox.com/s/acnv1ts4y00pv6c/InstallPokemmo1.sh && wget https://www.dropbox.com/s/pgtas3o5gpex217/InstallPokemmo2.sh && chmod +x InstallPokemmo1.sh && chmod +x InstallPokemmo2.sh
3: Install PokeMMO (this will throw an error, use CTRL-C to exit) :
./InstallPokemmo1.sh
4: Update the OpenGL libraries :
./InstallPokemmo2.sh
5: You will need to register for an account on https://pokemmo.eu
6: You will also need locate a Pokemon Red Fire Game Boy Advance rom. I can't help with this - try googling 'pokemon red fire rom gba'
7: Run
pokemmo-launcher
NesteaHD
Re: PokeMMO
Sun Sep 18, 2016 6:53 pm
Can i do this on a Raspberry pi Zero?
rpiMike
Re: PokeMMO
Tue Sep 20, 2016 8:11 am
NesteaHD wrote:Can i do this on a Raspberry pi Zero?
No, sorry, Pi Zero won't run OpenGL.
GFinlay
Re: PokeMMO
Sun Jun 04, 2017 9:54 pm
I am getting the following error when trying to run pokemmo-launcher
Unable to init server: could not connect: connection refused
chmod: cannot access /home/pi/.pokemmo/PokeMMO.sh no such file or directory
I had a look through samba and it doesn't seem to have created the /.pokemmo/PokeMMO.sh even though I followed the tutorial exactly, any ideas?
**edit
After coming off of the terminal and viewing file directories on desktop the /.pokemmo folder exists but the PokeMMO.sh file doesn't seem to be being created, I am unsure if this is a permissions issue or of it is something wrong with how I am setting up. Any ideas? Or is there somewhere I could download the PokeMMO.sh file and place it into the correct repository to see if it works?
shalkith
Re: PokeMMO
Tue Jan 09, 2018 10:31 pm
can this be run directly from the command line without having to boot into X server?
rpiMike
Re: PokeMMO
Thu Jan 11, 2018 11:07 pm
I don't think so.
HawkeyeFan18
Re: PokeMMO
Fri Dec 21, 2018 4:44 am
I am getting an error on both steps 3 and 4 saying that it is corrupt. Any suggestions?
Sparton91106
Re: PokeMMO
Wed Apr 17, 2019 4:14 am
I am getting a ,(Error 1) The installation is in a corrupt state. Reverifying the game files. whenever i try to run pokemmo
Return to “Gaming”
