Aeon Alpha
Posted: Tue Jun 14, 2016 10:01 pm
by bullen
I just ported my multiplayer space shooter.
Performance:
RPi 2 ~15 fps.
RPi 3 ~25 fps.
RPi 3+ ~33 fps.
RPi 4 ~48 fps.
For comparison:
Old PC ~300 fps.
New PC ~500-800 fps.
You need:
- A Raspberry Pi 3+.
- The recent release of Raspbian (2018+).
Instructions:
- Enable the experimental OpenGL driver and restart with:
sudo raspi-config (Advanced Options - GL Driver - Fake KMS)
- Install these:
sudo apt-get install libalut0 libalut-dev openjdk-11-jdk
- Download the game: http://aeonalpha.com/aeon.zip
cd Downloads
unzip aeon.zip
cd aeon
./raspberrypi.sh
Re: Aeon Alpha
Posted: Sat Jun 25, 2016 6:46 am
by cpcbegin
Aeon Alpha doesn't run on a raspberry pi 2?
AA need oracle java in other PC GNU/Linux? OpenJDK isn't enough?
Re: Aeon Alpha
Posted: Sun Jun 26, 2016 7:33 am
by bullen
It runs on RPi 2 but the framerate is too low ~10...
I haven't tested OpenJDK, but as a general rule I always use the original Java for best performance.
Edit: Now OpenJDK is your best option.
Re: Aeon Alpha
Posted: Mon Sep 12, 2016 5:57 am
by bullen
With the latest raspbian upgrade performance went from 20 to 5 FPS! :(
Re: Aeon Alpha
Posted: Sat Dec 17, 2016 9:22 am
by bullen
With the latest experimental kernel it runs at 30 fps!
sudo apt-get install rpi-update
sudo BRANCH=next rpi-update
Re: Aeon Alpha
Posted: Mon May 01, 2017 9:11 pm
by bullen
Now HDMI output seems broken in the latest firmware... this is not very fun.
Re: Aeon Alpha
Posted: Tue May 02, 2017 8:45 am
by jamesh
bullen wrote:Now HDMI output seems broken in the latest firmware... this is not very fun.
? Works fine for me. I'm sure that HDMI being broken would have been flagged up....
Is this firmware from rpi-update? That is bleeding edge stuff and you should only use it if you have a specific reason. Are you using the new 3D driver?
Re: Aeon Alpha
Posted: Tue May 02, 2017 12:40 pm
by bullen
Yep and yep... My screen goes blue like it always does then black again. It didn't before the rpi-update. How do I 1) rollback or 2) install the rpi-update I had before?
Re: Aeon Alpha
Posted: Wed May 31, 2017 9:51 pm
by bullen
Ok, back to 30 FPS with RPi 3, 2017-04-10 lite release and fake KMS!
And holy &%$# now Java uses pulse audio so sound works 100% too!
Just waiting for phonejack audio to support pulse without whine too: https://www.raspberrypi.org/forums/view ... 5#p1170725
Works now! Add audio_pwm_mode=2 to /boot/config.txt
Here's a TWM from raspbian lite instructions to get your installation perfect for aeon alpha:
https://downloads.raspberrypi.org/raspb ... e-lite.zip
From Raspbian Lite:
sudo su
apt-get update
apt-get install emacs-nox xinit xserver-xorg twm xterm x11-xserver-utils xcompmgr xli xdotool
LANG=C
startx
// if you click the mouse you should see a cross as mouse pointer.
// auto login
emacs /etc/systemd/system/getty.target.wants/getty\@tty1.service
ExecStart=-/sbin/agetty --autologin pi --noclear %I $TERM
// auto startx
emacs .profile
if [ $(tty) = /dev/tty1 ]; then
    export LC_ALL=C
    alias ll="ls -l"
    startx
fi
// fake kms
raspi-config
  advanced options
    gl driver
      fake kms
// cleanup and install the basics
rm -rf Desktop/ Documents/ Downloads/ Music/ Pictures/ Public/ Templates/ Videos/
apt-get install chromium-browser omxplayer openjdk-11-jdk mesa-utils libalut0 libalut-dev
now you can download and launch aeonalpha!
OPTIONAL:
// disable screen timeout
emacs /etc/X11/xinit/xserverrc
exec /usr/bin/X <b>-s 0 dpms</b> -nolisten tcp "[email protected]"
// twm config
wget http://rupy.se/twmrc
mv twmrc .twmrc
// background image
wget http://move.rupy.se/file/mupee.png // 1280
wget http://move.rupy.se/file/genesh.jpg // 1024
cp /etc/X11/xinit/xinitrc ~/.xinitrc
emacs .xinitrc
xli -onroot mupee.png / genesh.jpg
// windows fonts
sudo apt-get install ttf-mscorefonts-installer
Re: Aeon Alpha
Posted: Thu Jan 11, 2018 5:24 pm
by bullen
There now the game works 99% on the rpi with sound at 30 FPS!
Just add audio_pwm_mode=2 to /boot/config.txt
Thx to Anholt for OpenGL fixed pipeline graphics + jdb and Oracle for mixer sound!
The only tiny flaw left is that the "text to voice" stopped working!
Works most of the time...
Re: Aeon Alpha
Posted: Thu Mar 22, 2018 5:43 pm
by bullen
With latest Raspbian and 3B+ gets you flawless experience on Raspberry with 33-34 FPS "smoothness" and thermal situation under control!
Only the text to speech is lagging a bit, but that's ok... Edit: on RPi 4 speech does not lag any more, seems out-of-order execution is really important for that?
Re: Aeon Alpha
Posted: Sat Aug 04, 2018 3:28 pm
by bullen
Re: Aeon Alpha
Posted: Tue Jul 02, 2019 10:33 pm
by bullen
Sometimes the game just freezes X when started on the new Pi 4.
Maybe it has something to do with audio:
AL lib: (EE) oss_open_playback: Could not open /dev/dsp: No such file or directory
Installing alsa-oss fixes that problem, the lockup still occurs.
This is what happens in Xorg.log, I'm pretty sure it's related to these since the lockup always occurs immediately after the last of these:
Edit: I don't know where to look deeper, and also some way to restart X without having to cycle power would help!
Edit2: just to confirm my suspicion, buster works fine on a RPi 2 so this is a problem with the new RPi 4 GPU and/or it's drivers.
[ 38.029] (II) modeset(0): Disabling kernel dirty updates, not required.
[ 81.993] (II) modeset(0): EDID vendor "XXX", prod id 0
[ 81.993] (II) modeset(0): Using EDID range info for horizontal sync
[ 81.993] (II) modeset(0): Using EDID range info for vertical refresh
[ 81.993] (II) modeset(0): Printing DDC gathered Modelines:
[ 81.993] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 772 777 806 +hsync -vsync (48.4 kHz eP)
[ 81.993] (II) modeset(0): Modeline "1366x768"x0.0 85.50 1366 1436 1579 1792 768 771 777 798 +hsync +vsync (47.7 kHz e)
[ 81.993] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 81.993] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 81.993] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 81.993] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 81.993] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 81.993] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 81.993] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 81.994] (II) modeset(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 81.994] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 81.994] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 81.994] (II) modeset(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 81.994] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 81.994] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 81.994] (II) modeset(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 81.994] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 81.994] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 81.994] (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 81.994] (II) modeset(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 81.994] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 81.994] (II) modeset(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 81.994] (--) modeset(0): HDMI max TMDS frequency 225000KHz
[ 82.435] (II) modeset(0): EDID vendor "XXX", prod id 0
[ 82.435] (II) modeset(0): Using hsync ranges from config file
[ 82.435] (II) modeset(0): Using vrefresh ranges from config file
[ 82.435] (II) modeset(0): Printing DDC gathered Modelines:
[ 82.435] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 772 777 806 +hsync -vsync (48.4 kHz eP)
[ 82.435] (II) modeset(0): Modeline "1366x768"x0.0 85.50 1366 1436 1579 1792 768 771 777 798 +hsync +vsync (47.7 kHz e)
[ 82.435] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 82.435] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 82.435] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 82.436] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 82.436] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 82.436] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 82.436] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 82.436] (II) modeset(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 82.436] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 82.436] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 82.436] (II) modeset(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 82.436] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 82.436] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 82.436] (II) modeset(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 82.436] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 82.436] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 82.436] (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 82.436] (II) modeset(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 82.436] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 82.436] (II) modeset(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 82.437] (--) modeset(0): HDMI max TMDS frequency 225000KHz
[ 82.466] (II) modeset(0): EDID vendor "XXX", prod id 0
[ 82.466] (II) modeset(0): Using hsync ranges from config file
[ 82.466] (II) modeset(0): Using vrefresh ranges from config file
[ 82.466] (II) modeset(0): Printing DDC gathered Modelines:
[ 82.466] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 772 777 806 +hsync -vsync (48.4 kHz eP)
[ 82.466] (II) modeset(0): Modeline "1366x768"x0.0 85.50 1366 1436 1579 1792 768 771 777 798 +hsync +vsync (47.7 kHz e)
[ 82.466] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 82.466] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 82.466] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 82.466] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 82.466] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 82.467] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 82.467] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 82.467] (II) modeset(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 82.467] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 82.467] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 82.467] (II) modeset(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 82.467] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 82.467] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 82.467] (II) modeset(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 82.467] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 82.467] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 82.467] (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 82.467] (II) modeset(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 82.467] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 82.467] (II) modeset(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 82.468] (--) modeset(0): HDMI max TMDS frequency 225000KHz
[ 82.497] (II) modeset(0): EDID vendor "XXX", prod id 0
[ 82.497] (II) modeset(0): Using hsync ranges from config file
[ 82.497] (II) modeset(0): Using vrefresh ranges from config file
[ 82.497] (II) modeset(0): Printing DDC gathered Modelines:
[ 82.497] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 772 777 806 +hsync -vsync (48.4 kHz eP)
[ 82.497] (II) modeset(0): Modeline "1366x768"x0.0 85.50 1366 1436 1579 1792 768 771 777 798 +hsync +vsync (47.7 kHz e)
[ 82.497] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 82.497] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 82.497] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 82.497] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 82.497] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 82.497] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 82.497] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 82.497] (II) modeset(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 82.497] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 82.497] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 82.497] (II) modeset(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 82.497] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 82.497] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 82.497] (II) modeset(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 82.497] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 82.497] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 82.497] (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 82.497] (II) modeset(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 82.498] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 82.498] (II) modeset(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 82.498] (--) modeset(0): HDMI max TMDS frequency 225000KHz
[ 85.306] (II) modeset(0): EDID vendor "XXX", prod id 0
[ 85.307] (II) modeset(0): Using hsync ranges from config file
[ 85.307] (II) modeset(0): Using vrefresh ranges from config file
[ 85.307] (II) modeset(0): Printing DDC gathered Modelines:
[ 85.307] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 772 777 806 +hsync -vsync (48.4 kHz eP)
[ 85.307] (II) modeset(0): Modeline "1366x768"x0.0 85.50 1366 1436 1579 1792 768 771 777 798 +hsync +vsync (47.7 kHz e)
[ 85.307] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1390 1430 1650 720 725 730 750 +hsync +vsync (45.0 kHz e)
[ 85.307] (II) modeset(0): Modeline "720x480"x0.0 27.00 720 736 798 858 480 489 495 525 -hsync -vsync (31.5 kHz e)
[ 85.307] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2448 2492 2640 1080 1084 1094 1125 interlace +hsync +vsync (28.1 kHz e)
[ 85.307] (II) modeset(0): Modeline "1280x720"x0.0 74.25 1280 1720 1760 1980 720 725 730 750 +hsync +vsync (37.5 kHz e)
[ 85.307] (II) modeset(0): Modeline "720x576"x0.0 27.00 720 732 796 864 576 581 586 625 -hsync -vsync (31.2 kHz e)
[ 85.307] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2008 2052 2200 1080 1084 1089 1125 +hsync +vsync (67.5 kHz e)
[ 85.307] (II) modeset(0): Modeline "1920x1080i"x0.0 74.25 1920 2008 2052 2200 1080 1084 1094 1125 interlace +hsync +vsync (33.8 kHz e)
[ 85.307] (II) modeset(0): Modeline "1440x480i"x0.0 27.00 1440 1478 1602 1716 480 488 494 525 interlace -hsync -vsync (15.7 kHz e)
[ 85.307] (II) modeset(0): Modeline "640x480"x0.0 25.18 640 656 752 800 480 490 492 525 -hsync -vsync (31.5 kHz e)
[ 85.307] (II) modeset(0): Modeline "1920x1080"x0.0 148.50 1920 2448 2492 2640 1080 1084 1089 1125 +hsync +vsync (56.2 kHz e)
[ 85.307] (II) modeset(0): Modeline "1440x576i"x0.0 27.00 1440 1464 1590 1728 576 580 586 625 interlace -hsync -vsync (15.6 kHz e)
[ 85.307] (II) modeset(0): Modeline "1920x1080"x0.0 74.25 1920 2558 2602 2750 1080 1084 1089 1125 +hsync +vsync (27.0 kHz e)
[ 85.307] (II) modeset(0): Modeline "800x600"x0.0 40.00 800 840 968 1056 600 601 605 628 +hsync +vsync (37.9 kHz e)
[ 85.307] (II) modeset(0): Modeline "800x600"x0.0 36.00 800 824 896 1024 600 601 603 625 +hsync +vsync (35.2 kHz e)
[ 85.307] (II) modeset(0): Modeline "720x400"x0.0 28.32 720 738 846 900 400 412 414 449 -hsync +vsync (31.5 kHz e)
[ 85.307] (II) modeset(0): Modeline "1024x768"x0.0 65.00 1024 1048 1184 1344 768 771 777 806 -hsync -vsync (48.4 kHz e)
[ 85.307] (II) modeset(0): Modeline "1680x1050"x0.0 119.00 1680 1728 1760 1840 1050 1053 1059 1080 +hsync -vsync (64.7 kHz e)
[ 85.307] (II) modeset(0): Modeline "1280x800"x0.0 71.00 1280 1328 1360 1440 800 803 809 823 +hsync -vsync (49.3 kHz e)
[ 85.307] (II) modeset(0): Modeline "1280x1024"x0.0 108.00 1280 1328 1440 1688 1024 1025 1028 1066 +hsync +vsync (64.0 kHz e)
[ 85.307] (II) modeset(0): Modeline "1280x960"x0.0 108.00 1280 1376 1488 1800 960 961 964 1000 +hsync +vsync (60.0 kHz e)
[ 85.308] (--) modeset(0): HDMI max TMDS frequency 225000KHz
