I wanted to make a portable emulator.
I informed myself and found this: PIGRRL 2 https://learn.adafruit.com/pigrrl-2/overview
But I have never dealt with the raspberry or anything like it so I have some questions:
1. Are there better alternatives than the PIGRRL 2?
2. Wich raspberry is the best for my project. I found out the pi 3 is way more powerfull than the pi 2 but also uses more energy.
The energie/power rate of both devices is equal.
7.9s * 420mA = 3318 mAs for Pi2
4.5s * 720mA = 3240 mAs for Pi3
Written here : http://raspi.tv/2016/how-much-power-doe ... ed-to-pi2b
Does this result work for emulators or only for special tasks?
I need a pi that can emulate everything till n64 and it would be good if it can play some n64 games too, but also doesn't require to much energy to run.
3.If I use the PIGRRL 2 the display size will only be 2,8". Is it possible to get it to 3,5" or more, or is 2,8" enough?
4. Also the screen there is a touchscreen. What for?
5. I myself dont have a 3d printer so I looked for a way to get the case for the PIGRRL 2 and found a few on ebay. Are they worth buying or should I look somewhere else?
6. And the last question... How many mAh should the battery/akku have to get a decent playtime.
Thanks in advance for your response!
