CyberTails
Re: How to setup Minecraft 1.8.9 on RaspPi2
Sat May 14, 2016 3:09 pm
Regarding the Overclocking step, Does this apply to the RPi3 as well?
muggy
Sat May 14, 2016 3:57 pm
[quote="muggy"]I've followed this tutorial step by step on my pi3, unfortunately without success.
2 In Menu\Preferences\Raspberry Pi Configuration :
Set overclock to High(1000MHz)
This is not possible on a pi3.
Frene
Sat May 14, 2016 7:40 pm
Thanks for this great tutorial. Can't wait to try it. My raspberrypi 3 is on his way.
Is there a way to install it with RetroPie? My goal is to build a dedicated Minecraft computer but i thought it would be better if at startup, we could decide between Minecraft or Retropie to play old games. Anyone tried that? Is that possible?
Thanks for your input!
muggy
Sun May 15, 2016 8:16 pm
rpiMike wrote: ...
A new build of Raspbian has been released today, i'm flashing it to an sd card as I type this, might help with your issues.
@rpiMike: Thanks a lot.
I've reformatted my SD-Card and installed the new version with NOOBS 1.9.1 on my Pi 3. Now the installation has worked and starting a single player game is possible, but now some other problems came up:
1. The game lags extremely. Maybe I should try optifine ?
2. Rapid movement of the window with the mouse or switching the window to fullscreen causes the Pi to hang completely.
3. Network playing is impossible. Servers are found and displayed, but the following message is displayed:
"Failed to connect to the server. Failed to login! Invalid session (Try restarting your game)."
ChickenPillow
Mon May 16, 2016 3:09 pm
Uhh, guys. So generally Minecraft works fine. But one problem, the internet lags ALOT! When I scroll down its not good at ALL! I glitches and lags a whole load! Any ideas how I can fix it, it started when I followed this tutorial to setup mc. Thanks
rpiMike
Mon May 16, 2016 4:34 pm
ChickenPillow wrote:Uhh, guys. So generally Minecraft works fine. But one problem, the internet lags ALOT! When I scroll down its not good at ALL! I glitches and lags a whole load! Any ideas how I can fix it, it started when I followed this tutorial to setup mc. Thanks
Turn the OpenGL driver off in 'sudo raspi-config', then reboot. You'll need to turn back on if you want to play Minecraft again.
muggy
Mon May 16, 2016 5:20 pm
Hi BaconCat,
I've tried to answer your PM, but my answer sticks to the outbox and I can't send it.
Thanks for your clue. How can I find out the UUID? I'm not very familiar with scriptfiles...
I have installed Optifine now. Lags less now but runs not really fluid yet. And still the Pi suddenly freezes completely from time to time in the middle of action :-(
muggy
Tue May 17, 2016 6:21 pm
O.K.
Network playing works again. Had to repair the run.sh-files with the right UUID and now I can access the servers again. :D
Unfortunately I still experience the lags and hangs. :cry:
rpiMike
Tue May 17, 2016 8:06 pm
Please don't forget this is running on a £30 computer that was designed for educational purposes. Its a miracle full Minecraft works at all.
Try reducing more of the Minecraft video settings, might gain a few more fps.
muggy
Tue May 17, 2016 9:38 pm
rpiMike wrote:Please don't forget this is running on a £30 computer that was designed for educational purposes. Its a miracle full Minecraft works at all.
Yes, you are totally right. On the other hand I have watched some videos on youtube that show minecraft played for a long time without any problems like mine. At least they claim to play it on a Pi. But none of these moviemakers made a tutorial for how they managed to get that far ;)
With this tutorial you made a really good job, rpiMike. Thank you very much again for your help.
tegsirat
Mon May 23, 2016 11:49 pm
I was able to get to the main menu on 1.9.4 with (and without) optifine installed.
When I try and create new world, it hangs. Anyone have any idea what's going on:
[18:39:18] [Client thread/INFO]: Setting user: tegsirat
[18:39:29] [Client thread/INFO]: LWJGL Version: 2.9.4
[18:39:31] [Client thread/INFO]: Reloading ResourceManager: Default
[18:39:34] [Sound Library Loader/INFO]: Starting up SoundSystem...
[18:39:34] [Thread-5/INFO]: Initializing LWJGL OpenAL
[18:39:34] [Thread-5/INFO]: (The LWJGL binding of OpenAL.  For more information, see http://www.lwjgl.org)
[18:39:34] [Thread-5/INFO]: OpenAL initialized.
[18:39:34] [Sound Library Loader/INFO]: Sound engine started
[18:39:42] [Client thread/INFO]: Created: 1024x512 textures-atlas
[18:39:50] [Realms Notification Availability checker #1/INFO]: Could not authorize you against Realms server: Invalid session id
[18:40:08] [Client thread/INFO]: Connecting to 104.219.4.184, 25565
[18:40:19] [Client thread/INFO]: Deleting level test
[18:40:19] [Client thread/INFO]: Attempt 1...
[18:40:52] [Server thread/INFO]: Starting integrated minecraft server version 1.9.4
[18:40:52] [Server thread/INFO]: Generating keypair
[18:40:53] [Realms Notification Availability checker #1/INFO]: Could not authorize you against Realms server: Invalid session id
[18:40:54] [Server thread/ERROR]: Encountered an unexpected exception
java.lang.NoClassDefFoundError: it/unimi/dsi/fastutil/longs/Long2ObjectMap
	at mn.d(SourceFile:280) ~[1.9.4.jar:?]
	at ln.<init>(SourceFile:60) ~[1.9.4.jar:?]
	at lq.<init>(SourceFile:123) ~[1.9.4.jar:?]
	at byl.a(SourceFile:99) ~[1.9.4.jar:?]
	at byl.j(SourceFile:131) ~[1.9.4.jar:?]
	at net.minecraft.server.MinecraftServer.run(SourceFile:428) [1.9.4.jar:?]
	at java.lang.Thread.run(Thread.java:745) [?:1.8.0_65]
Caused by: java.lang.ClassNotFoundException: it.unimi.dsi.fastutil.longs.Long2ObjectMap
	at java.net.URLClassLoader.findClass(URLClassLoader.java:381) ~[?:1.8.0_65]
	at java.lang.ClassLoader.loadClass(ClassLoader.java:424) ~[?:1.8.0_65]
	at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331) ~[?:1.8.0_65]
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:1.8.0_65]
	... 7 more
[18:40:54] [Server thread/ERROR]: This crash report has been saved to: /home/pi/.minecraft/crash-reports/crash-2016-05-23_18.40.54-server.txt
[18:40:54] [Server thread/INFO]: Stopping server
[18:40:54] [Server thread/INFO]: Saving players
[18:40:54] [Server thread/INFO]: Saving worlds
rpiMike
Tue May 24, 2016 7:27 am
I suspect you might be missing a jar file from your classpath list. I have got 1.9.4 working, although haven't got sound yet.
What I do is run minecraft until it crashes (java -jar Minecraft.jar). Then copy the class path list from the command window into my run.sh .
I'll check my 1.9.4 run.sh tonight.
stutteringp0et
Sat May 28, 2016 7:37 pm
I try using run.sh and I get this:
todays access token = 3c18a4542f94470ca5d272fb3b327d9c
Java HotSpot(TM) Client VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
Error: Could not find or load main class net.minecraft.client.main.Main
If I attempt to run java -jar Minecraft.jar, I get this:
Java HotSpot(TM) Client VM warning: You have loaded library /home/simon/.minecraft/versions/1.9.4/1.9.4-natives-3887566803974/liblwjgl64.so which might have disabled stack guard. The VM will try to fix the stack guard now.
It's highly recommended that you fix the library with 'execstack -c <libfile>', or link it with '-z noexecstack'.
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/simon/.minecraft/versions/1.9.4/1.9.4-natives-3887566803974/liblwjgl.so: /home/simon/.minecraft/versions/1.9.4/1.9.4-natives-3887566803974/liblwjgl.so: cannot open shared object file: No such file or directory (Possible cause: can't load IA 32-bit .so on a ARM-bit platform)
	at java.lang.ClassLoader$NativeLibrary.load(Native Method)
	at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1941)
	at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1857)
	at java.lang.Runtime.loadLibrary0(Runtime.java:870)
	at java.lang.System.loadLibrary(System.java:1122)
	at org.lwjgl.Sys$1.run(Sys.java:72)
	at java.security.AccessController.doPrivileged(Native Method)
	at org.lwjgl.Sys.doLoadLibrary(Sys.java:66)
	at org.lwjgl.Sys.loadLibrary(Sys.java:96)
	at org.lwjgl.Sys.<clinit>(Sys.java:117)
	at bcd.I(SourceFile:2751)
	at net.minecraft.client.main.Main.main(SourceFile:39)
cleverusername
Sun May 29, 2016 8:51 am
pi3, went thru the install. monitor is 1080p. when i get to 4 Enable ‘AA GL Driver’
i get: "Driver and kernel not present on your system. Please update"
what do I do next?
Thanks!
MasterBuilder121
Mon May 30, 2016 8:21 pm
Hi everyone!
I have done everything that this article has said to do, and I have gotten to the point where the Minecraft launcher starts, but then it gives me this:
Java HotSpot(TM) Client VM warning: You have loaded library /home/pi/.minecraft/versions/1.9.4/1.9.4-natives-870795965626/liblwjgl64.so which might have disabled stack guard. The VM will try to fix the stack guard now.
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/pi/.minecraft/versions/1.9.4/1.9.4-natives-870795965626/liblwjgl.so: /home/pi/.minecraft/versions/1.9.4/1.9.4-natives-870795965626/liblwjgl.so: cannot open shared object file: No such file or directory (Possible cause: can't load IA 32-bit .so on a ARM-bit platform)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1938)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1854)
at net.minecraft.client.main.Main.main(SourceFile:39)[/code][/size]
Please help!
DatGamingLad
Tue May 31, 2016 6:37 pm
How do i Enable AA Gl Driver, because you literary just said Enable AA GL Driver without and instruction on how to do it. please help me!!!! :( :( :(
rpiMike
Tue May 31, 2016 8:20 pm
DatGamingLad wrote:How do i Enable AA Gl Driver, because you literary just said Enable AA GL Driver without and instruction on how to do it. please help me!!!! :( :( :(
In a terminal window run 'sudo raspi-config', this will start the config utility. Select '9 Advanced Options', then select 'AA GL Driver', then select 'Enable', then select 'Yes' to reboot. You can see this on the video tutorial at about 04:10.
KH6JAG
Tue May 31, 2016 8:24 pm
I am able to locate the 'AB GL Driver’ but whenever I try to enable i get the following message "Driver and kernel not present on your system. Please update
The gears graphics runs but only at ~25 fps I have the overclock set to the highest value
rpiMike
Tue May 31, 2016 8:56 pm
KH6JAG wrote:I am able to locate the 'AB GL Driver’ but whenever I try to enable i get the following message "Driver and kernel not present on your system. Please update
Sounds like your update/upgrade of Raspbian Jessie hasn't worked.
rpiMike
Tue May 31, 2016 8:57 pm
cleverusername wrote:pi3, went thru the install. monitor is 1080p. when i get to 4 Enable ‘AA GL Driver’
what do I do next?
Thanks!
rpiMike
Tue May 31, 2016 9:08 pm
MasterBuilder121 wrote:Hi everyone!
Please help!
This tutorial is designed for 1.8.9, in the Minecraft launcher did you edit the profile and select use release 1.8.9 ?
MasterBuilder121
Tue May 31, 2016 10:44 pm
Please help!
No, but I updated the run.sh file to 1.9.4. I also tried using 1.8.9, updating the run.sh file too, but it didn't work.
Nope, I refuse to use those "signatures" that everybody... oh.
Liaxxxx
Wed Jun 01, 2016 5:00 pm
Wow this helped a lot!I set it up and it worked perfectly. :D
MasterBuilder121
Thu Jun 02, 2016 12:01 am
Ok, so I uninstalled then re installed it, and it won't give me that error anymore. However, it will give me this:
---- Minecraft Crash Report ----
// Don't be sad, have a hug! <3
Time: 01/06/16 23:58
Description: Initializing game
java.lang.ExceptionInInitializerError
	at ave.ar(SourceFile:560)
	at ave.am(SourceFile:361)
	at ave.a(SourceFile:310)
	at net.minecraft.client.main.Main.main(SourceFile:124)
Caused by: java.lang.NullPointerException
	at org.lwjgl.opengl.LinuxDisplay.getAvailableDisplayModes(LinuxDisplay.java:947)
	at org.lwjgl.opengl.LinuxDisplay.init(LinuxDisplay.java:738)
	at org.lwjgl.opengl.Display.<clinit>(Display.java:138)
	... 4 more
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
	Minecraft Version: 1.8.9
	Operating System: Linux (arm) version 4.4.11-v7+
	Java Version: 1.8.0_65, Oracle Corporation
	Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
	Memory: 97502456 bytes (92 MB) / 159653888 bytes (152 MB) up to 1060372480 bytes (1011 MB)
	JVM Flags: 5 total; -Xmn128M -Xmx1024M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy
	IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
	Launched Version: 1.8
	LWJGL: 2.9.4
	OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
	GL Caps:
	Using VBOs: No
	Is Modded: Probably not. Jar signature remains and client brand is untouched.
	Type: Client (map_client.txt)
	Resource Packs:
	Current Language: ~~ERROR~~ NullPointerException: null
	Profiler Position: N/A (disabled)
	CPU: <unknown>
Again, please help! At least this time it actually is a crash report...
Firestorm185
Thu Jun 02, 2016 3:16 am
Hey guys! Thanks a TON for this information! It's been amazing playing Minecraft on my Pi 2! I just have two questions:
1- I was playing it with OptiFine and was testing out lower resolutions for fullscreen and I got down to one of the lower ones and it stopped outputting to my monitor... so now I'm stuck. Anyone know how to fix it?
2 - is there a way to manually set OptiFine's settings without Miencraft running? Like, a text doc somewhere in the settings. If so, would someone know where? I can't find it.
Thanks and have a great one! :D
Return to “Gaming”
