rpiMike
Re: How to setup Minecraft 1.8.9 on RaspPi2
Sat Apr 23, 2016 6:50 am
I've simplified the tutorial and added a video showing how to setup.
https://www.youtube.com/watch?v=EVpGh0zFInM
princec
Tue Apr 26, 2016 2:42 pm
Fancy a shot at getting our games to run? Shouldn't be too hard if you've got Minecraft to work.
Cas :)
rpiMike
Tue Apr 26, 2016 2:46 pm
princec wrote:Fancy a shot at getting our games to run? Shouldn't be too hard if you've got Minecraft to work.
Cas :)
Sure, I can try and help.
Private message me ?
birv2
Raspberry Pi Certified Educator
Tue Apr 26, 2016 6:14 pm
So I'm assuming it's not codable a la Adventures in Minecraft, which allows you to use Python. Since that's coded against the PE version, which is C++.
I think.
rpiMike
Tue Apr 26, 2016 7:15 pm
birv2 wrote:So I'm assuming it's not codable a la Adventures in Minecraft, which allows you to use Python. Since that's coded against the PE version, which is C++.
I think.
Can't be coded with Python like the Pi version. Can be coded using various Plugins and scripts.
BaconCat
Sat Apr 30, 2016 11:05 am
Has any one tryed to get the FTB launcher working?
I have no idea what I'm doing
halppls
Mon May 02, 2016 5:58 am
I get an error while trying to launch optifine,
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 274 100 107 100 167 129 201 --:--:-- --:--:-- --:--:-- 201
todays access token =
Java HotSpot(TM) Client VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
May 02, 2016 5:46:14 AM net.minecraft.launchwrapper.LogWrapper log
INFO: Loading tweak class name optifine.OptiFineTweaker
SEVERE: Unable to launch
java.lang.ClassNotFoundException: optifine.OptiFineTweaker
at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:99)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:348)
at net.minecraft.launchwrapper.Launch.launch(Launch.java:94)
at net.minecraft.launchwrapper.Launch.main(Launch.java:27)
Anyone know what is wrong?
markyd
Wed May 04, 2016 4:01 pm
I am afraid I am a "me too" I think I followed the instructions to the letter, the only difference was the the OptiFine_1.8.9_HD_U_H3.jar file was not available and I used H5 ... apart from that got exactly the same results as above :-(
BaconCat
Thu May 05, 2016 12:36 am
markyd wrote:I am afraid I am a "me too" I think I followed the instructions to the letter, the only difference was the the OptiFine_1.8.9_HD_U_H3.jar file was not available and I used H5 ... apart from that got exactly the same results as above :-(
You MUST use OptiFine_1.8.9_HD_U_H3.jar. H5 will not work
halppls
Thu May 05, 2016 4:02 am
Nvm that, I actually got it working,
edit your runOptifine.sh
Find the 27th line ( I think was it)
and change all the parts that have the Optifine H3 part and change them to H5.
thats what I did to fix it
markyd
Thu May 05, 2016 8:05 am
Thanks for the reply, but alas, I made 4 edits to that line in total changing H3 to H5 but got the same result .... gues will just have to hunt down the H3 version and give that a go.
MarkyD
rpiMike
Thu May 05, 2016 7:14 pm
halppls wrote:Nvm that, I actually got it working,
That worked for me too, updated file here :
https://www.dropbox.com/s/9euv4pocl1cgk ... ne.sh?dl=0
rpiRyan
Tue May 10, 2016 12:49 am
Anocs wrote:
rpiMike wrote:
alguien wrote:I cant enable opengl. if i enable it i dont see anything on the screen. Why is this? Im using a raspberry pi 2
Sounds like your power supply can't cope. How many amps are your power supply, should really be 2 amps for Raspberry Pi 2.
Currently experimental Mesa and DRM driver for Broadcom VC4 hardware driver works only in 1080p.
See this thread: https://github.com/anholt/linux/issues/7
Is there any way to fix? I currently have a 1080 x 600 monitor, and have been asking for help with the black screen OpenGL issue. I spoke with the creator - https://github.com/anholt/linux/issues/28 and he has been guiding me along it- until he asks me for the edid of the screen. I looked at the edid and it was blank, and so I need help to solve this problem. Mr.Hooper, do you know of any way to solve this? If anyone in this forum knows, feel free to tell me. I need all the help I can get to get this working. Thanks!
rpiMike
Tue May 10, 2016 2:04 pm
rpiRyan - have you tried this :
viewtopic.php?f=66&t=136048
rpiRyan
Wed May 11, 2016 2:33 am
rpiMike - No it did not work.
Instead of a black screen, I get my regular very large low voltage sign (Windows Logo?) and then a No Signal blue screen.
dsigurdsson
Wed May 11, 2016 3:45 pm
I'm having some issue and wondering if anyone could assist abit.
I'm only able to get Minecraft to run (via run.sh) if I disable the AA GL Driver. But then I'm running at 93%-100% which doesn't work.
It's a Raspberry Pi3
When I do have the AA GL Driver enabled Minecraft crashes with the following report
---- Minecraft Crash Report ----
// Oh - I know what I did wrong!
Time: 11.5.2016 15:34
Description: Initializing game
java.lang.ExceptionInInitializerError
at ave.ar(SourceFile:560)
at ave.am(SourceFile:361)
at ave.a(SourceFile:310)
at net.minecraft.client.main.Main.main(SourceFile:124)
Caused by: java.lang.NullPointerException
at org.lwjgl.opengl.LinuxDisplay.getAvailableDisplayModes(LinuxDisplay.java:947)
at org.lwjgl.opengl.LinuxDisplay.init(LinuxDisplay.java:738)
at org.lwjgl.opengl.Display.<clinit>(Display.java:138)
... 4 more
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.8.9
Operating System: Linux (arm) version 4.1.19-v7+
Java Version: 1.8.0_65, Oracle Corporation
Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
Memory: 99381624 bytes (94 MB) / 159002624 bytes (151 MB) up to 1060372480 bytes (1011 MB)
JVM Flags: 5 total; -Xmn128M -Xmx1024M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy
IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
Launched Version: 1.8
LWJGL: 2.9.4
OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
GL Caps:
Using VBOs: No
Is Modded: Probably not. Jar signature remains and client brand is untouched.
Type: Client (map_client.txt)
Resource Packs:
Current Language: ~~ERROR~~ NullPointerException: null
Profiler Position: N/A (disabled)
CPU: <unknown>
muggy
Wed May 11, 2016 8:59 pm
I've followed this tutorial step by step on my pi3, unfortunately without success.
[i]2 In Menu\Preferences\Raspberry Pi Configuration :
[i][/i]Set overclock to High(1000MHz)[/i]
This is not possible on a pi3.
[i]3 Install the experimental OpenGL Driver, sound & glxgears demo
4 Enable ‘AA GL Driver’
5 Test driver using glxgears
[/i]
After rebooting, the desktop size exceeds the size of the screen now so its hard to handle windows that start in fullsize and the main panel almost disappears at the upper edge of the screen. Very uncomfortable. Hope restoring the old displaydriver will work.
glxgears runs at 50fps but not minecraft.
What have I done wrong? How can I get back my correct desktop size?
Here the launcher's game output:
[i]Java HotSpot(TM) Client VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
Java HotSpot(TM) Client VM warning: You have loaded library /home/pi/.minecraft/versions/1.8.9/1.8.9-natives-7047780640569/liblwjgl64.so which might have disabled stack guard. The VM will try to fix the stack guard now.
It's highly recommended that you fix the library with 'execstack -c <libfile>', or link it with '-z noexecstack'.
Exception in thread "main" java.lang.UnsatisfiedLinkError: /home/pi/.minecraft/versions/1.8.9/1.8.9-natives-7047780640569/liblwjgl.so: /home/pi/.minecraft/versions/1.8.9/1.8.9-natives-7047780640569/liblwjgl.so: Kann die Shared-Object-Datei nicht öffnen: Datei oder Verzeichnis nicht gefunden (Possible cause: can't load IA 32-bit .so on a ARM-bit platform)
at java.lang.ClassLoader$NativeLibrary.load(Native Method)
at java.lang.ClassLoader.loadLibrary0(ClassLoader.java:1938)
at java.lang.ClassLoader.loadLibrary(ClassLoader.java:1854)
at java.lang.Runtime.loadLibrary0(Runtime.java:870)
at java.lang.System.loadLibrary(System.java:1122)
at org.lwjgl.Sys$1.run(Sys.java:72)
at java.security.AccessController.doPrivileged(Native Method)
at org.lwjgl.Sys.doLoadLibrary(Sys.java:66)
at org.lwjgl.Sys.loadLibrary(Sys.java:96)
at org.lwjgl.Sys.<clinit>(Sys.java:117)
at ave.J(SourceFile:2539)
at net.minecraft.client.main.Main.main(SourceFile:41)[/i]
and the last lines of the launcher log:
[i][22:23:46 INFO]: Minecraft Launcher 1.6.61 (through bootstrap 5) started on linux...
[22:23:46 INFO]: Current time is May 11, 2016 10:23:46 PM
[22:23:46 INFO]: System.getProperty('os.name') == 'Linux'
[22:23:46 INFO]: System.getProperty('os.version') == '4.1.19-v7+'
[22:23:46 INFO]: System.getProperty('os.arch') == 'arm'
[22:23:46 INFO]: System.getProperty('java.version') == '1.8.0_65'
[22:23:46 INFO]: System.getProperty('java.vendor') == 'Oracle Corporation'
[22:23:46 INFO]: System.getProperty('sun.arch.data.model') == '32'
[22:23:46 INFO]: proxy == DIRECT
[22:23:47 INFO]: Refreshing local version list...
[22:23:47 INFO]: Refreshing remote version list...
[22:23:48 INFO]: Refresh complete.
[22:23:49 INFO]: Loaded 1 profile(s); selected 'MatteoKSC'
[22:23:49 INFO]: Refreshing auth...
[22:23:49 INFO]: Logging in with access token
[22:23:56 INFO]: Getting syncinfo for selected version
[22:23:56 INFO]: Queueing library & version downloads
[22:23:56 INFO]: Download job 'Version & Libraries' started (16 threads, 33 files)
[22:23:56 INFO]: Attempting to download /home/pi/.minecraft/libraries/net/sf/jopt-simple/jopt-simple/4.6/jopt-simple-4.6.jar for job 'Version & Libraries'... (try 0)
[22:23:56 INFO]: Attempting to download /home/pi/.minecraft/libraries/net/java/jutils/jutils/1.0.0/jutils-1.0.0.jar for job 'Version & Libraries'... (try 0)
[22:23:56 INFO]: Attempting to download /home/pi/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl/2.9.4-nightly-20150209/lwjgl-2.9.4-nightly-20150209.jar for job 'Version & Libraries'... (try 0)
[22:23:56 INFO]: Attempting to download /home/pi/.minecraft/libraries/org/apache/logging/log4j/log4j-api/2.0-beta9/log4j-api-2.0-beta9.jar for job 'Version & Libraries'... (try 0)
[22:23:56 INFO]: Attempting to download /home/pi/.minecraft/libraries/org/apache/commons/commons-compress/1.8.1/commons-compress-1.8.1.jar for job 'Version & Libraries'... (try 0)
[22:23:56 INFO]: Attempting to download /home/pi/.minecraft/libraries/commons-codec/commons-codec/1.9/commons-codec-1.9.jar for job 'Version & Libraries'... (try 0)
[22:23:56 INFO]: Attempting to download /home/pi/.minecraft/libraries/oshi-project/oshi-core/1.1/oshi-core-1.1.jar for job 'Version & Libraries'... (try 0)
[22:23:56 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/paulscode/librarylwjglopenal/20100824/librarylwjglopenal-20100824.jar for job 'Version & Libraries'... (try 0)
[22:23:56 INFO]: Attempting to download /home/pi/.minecraft/libraries/org/apache/commons/commons-lang3/3.3.2/commons-lang3-3.3.2.jar for job 'Version & Libraries'... (try 0)
[22:23:56 INFO]: Attempting to download /home/pi/.minecraft/libraries/org/apache/httpcomponents/httpclient/4.3.3/httpclient-4.3.3.jar for job 'Version & Libraries'... (try 0)
[22:23:56 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/mojang/netty/1.6/netty-1.6.jar for job 'Version & Libraries'... (try 0)
[22:23:56 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/google/guava/guava/17.0/guava-17.0.jar for job 'Version & Libraries'... (try 0)
[22:23:56 INFO]: Attempting to download /home/pi/.minecraft/libraries/net/java/jinput/jinput/2.0.5/jinput-2.0.5.jar for job 'Version & Libraries'... (try 0)
[22:23:56 INFO]: Attempting to download /home/pi/.minecraft/libraries/net/java/jinput/jinput-platform/2.0.5/jinput-platform-2.0.5-natives-linux.jar for job 'Version & Libraries'... (try 0)
[22:23:56 INFO]: Attempting to download /home/pi/.minecraft/libraries/commons-io/commons-io/2.4/commons-io-2.4.jar for job 'Version & Libraries'... (try 0)
[22:23:56 INFO]: Attempting to download /home/pi/.minecraft/libraries/net/java/dev/jna/jna/3.4.0/jna-3.4.0.jar for job 'Version & Libraries'... (try 0)
[22:23:57 INFO]: Download job 'Resources' skipped as there are no files to download
[22:23:57 INFO]: Job 'Resources' finished successfully (took 0:00:00.000)
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/google/guava/guava/17.0/guava-17.0.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/paulscode/codecjorbis/20101023/codecjorbis-20101023.jar for job 'Version & Libraries'... (try 0)
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/net/java/dev/jna/jna/3.4.0/jna-3.4.0.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/google/code/gson/gson/2.2.4/gson-2.2.4.jar for job 'Version & Libraries'... (try 0)
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl/2.9.4-nightly-20150209/lwjgl-2.9.4-nightly-20150209.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Attempting to download /home/pi/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl-platform/2.9.4-nightly-20150209/lwjgl-platform-2.9.4-nightly-20150209-natives-linux.jar for job 'Version & Libraries'... (try 0)
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/commons-io/commons-io/2.4/commons-io-2.4.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Attempting to download /home/pi/.minecraft/libraries/tv/twitch/twitch/6.5/twitch-6.5.jar for job 'Version & Libraries'... (try 0)
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/commons-codec/commons-codec/1.9/commons-codec-1.9.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/paulscode/codecwav/20101023/codecwav-20101023.jar for job 'Version & Libraries'... (try 0)
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/org/apache/commons/commons-lang3/3.3.2/commons-lang3-3.3.2.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/paulscode/soundsystem/20120107/soundsystem-20120107.jar for job 'Version & Libraries'... (try 0)
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/org/apache/httpcomponents/httpclient/4.3.3/httpclient-4.3.3.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Attempting to download /home/pi/.minecraft/libraries/org/apache/httpcomponents/httpcore/4.3.2/httpcore-4.3.2.jar for job 'Version & Libraries'... (try 0)
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/net/java/jinput/jinput/2.0.5/jinput-2.0.5.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/mojang/realms/1.7.59/realms-1.7.59.jar for job 'Version & Libraries'... (try 0)
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/org/apache/commons/commons-compress/1.8.1/commons-compress-1.8.1.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Attempting to download /home/pi/.minecraft/libraries/io/netty/netty-all/4.0.23.Final/netty-all-4.0.23.Final.jar for job 'Version & Libraries'... (try 0)
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/net/java/jinput/jinput-platform/2.0.5/jinput-platform-2.0.5-natives-linux.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/mojang/authlib/1.5.21/authlib-1.5.21.jar for job 'Version & Libraries'... (try 0)
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/org/apache/logging/log4j/log4j-api/2.0-beta9/log4j-api-2.0-beta9.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Attempting to download /home/pi/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl_util/2.9.4-nightly-20150209/lwjgl_util-2.9.4-nightly-20150209.jar for job 'Version & Libraries'... (try 0)
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/oshi-project/oshi-core/1.1/oshi-core-1.1.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Attempting to download /home/pi/.minecraft/libraries/commons-logging/commons-logging/1.1.3/commons-logging-1.1.3.jar for job 'Version & Libraries'... (try 0)
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/mojang/netty/1.6/netty-1.6.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/net/sf/jopt-simple/jopt-simple/4.6/jopt-simple-4.6.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/paulscode/libraryjavasound/20101123/libraryjavasound-20101123.jar for job 'Version & Libraries'... (try 0)
[22:23:57 INFO]: Attempting to download /home/pi/.minecraft/libraries/net/java/dev/jna/platform/3.4.0/platform-3.4.0.jar for job 'Version & Libraries'... (try 0)
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/paulscode/librarylwjglopenal/20100824/librarylwjglopenal-20100824.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/ibm/icu/icu4j-core-mojang/51.2/icu4j-core-mojang-51.2.jar for job 'Version & Libraries'... (try 0)
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/net/java/jutils/jutils/1.0.0/jutils-1.0.0.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Attempting to download /home/pi/.minecraft/libraries/org/apache/logging/log4j/log4j-core/2.0-beta9/log4j-core-2.0-beta9.jar for job 'Version & Libraries'... (try 0)
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/paulscode/codecjorbis/20101023/codecjorbis-20101023.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Attempting to download /home/pi/.minecraft/versions/1.8.9/1.8.9.jar for job 'Version & Libraries'... (try 0)
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/google/code/gson/gson/2.2.4/gson-2.2.4.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/paulscode/libraryjavasound/20101123/libraryjavasound-20101123.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/paulscode/codecwav/20101023/codecwav-20101023.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/paulscode/soundsystem/20120107/soundsystem-20120107.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/tv/twitch/twitch/6.5/twitch-6.5.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/commons-logging/commons-logging/1.1.3/commons-logging-1.1.3.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/mojang/authlib/1.5.21/authlib-1.5.21.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl_util/2.9.4-nightly-20150209/lwjgl_util-2.9.4-nightly-20150209.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/org/apache/httpcomponents/httpcore/4.3.2/httpcore-4.3.2.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl-platform/2.9.4-nightly-20150209/lwjgl-platform-2.9.4-nightly-20150209-natives-linux.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/org/apache/logging/log4j/log4j-core/2.0-beta9/log4j-core-2.0-beta9.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/net/java/dev/jna/platform/3.4.0/platform-3.4.0.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/mojang/realms/1.7.59/realms-1.7.59.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/ibm/icu/icu4j-core-mojang/51.2/icu4j-core-mojang-51.2.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:57 INFO]: Finished downloading /home/pi/.minecraft/libraries/io/netty/netty-all/4.0.23.Final/netty-all-4.0.23.Final.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:58 INFO]: Finished downloading /home/pi/.minecraft/versions/1.8.9/1.8.9.jar for job 'Version & Libraries': Local file matches hash, using that
[22:23:58 INFO]: Job 'Version & Libraries' finished successfully (took 0:00:01.471)
[22:23:58 INFO]: Launching game
[22:23:58 INFO]: Unpacking natives to /home/pi/.minecraft/versions/1.8.9/1.8.9-natives-6424581964525
[22:23:58 INFO]: Launching in /home/pi/.minecraft
[22:23:58 INFO]: Half command: /usr/lib/jvm/jdk-8-oracle-arm32-vfp-hflt/jre/bin/java -Xmx512M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M -Djava.library.path=/home/pi/.minecraft/versions/1.8.9/1.8.9-natives-6424581964525 -cp /home/pi/.minecraft/libraries/com/mojang/netty/1.6/netty-1.6.jar:/home/pi/.minecraft/libraries/oshi-project/oshi-core/1.1/oshi-core-1.1.jar:/home/pi/.minecraft/libraries/net/java/dev/jna/jna/3.4.0/jna-3.4.0.jar:/home/pi/.minecraft/libraries/net/java/dev/jna/platform/3.4.0/platform-3.4.0.jar:/home/pi/.minecraft/libraries/com/ibm/icu/icu4j-core-mojang/51.2/icu4j-core-mojang-51.2.jar:/home/pi/.minecraft/libraries/net/sf/jopt-simple/jopt-simple/4.6/jopt-simple-4.6.jar:/home/pi/.minecraft/libraries/com/paulscode/codecjorbis/20101023/codecjorbis-20101023.jar:/home/pi/.minecraft/libraries/com/paulscode/codecwav/20101023/codecwav-20101023.jar:/home/pi/.minecraft/libraries/com/paulscode/libraryjavasound/20101123/libraryjavasound-20101123.jar:/home/pi/.minecraft/libraries/com/paulscode/librarylwjglopenal/20100824/librarylwjglopenal-20100824.jar:/home/pi/.minecraft/libraries/com/paulscode/soundsystem/20120107/soundsystem-20120107.jar:/home/pi/.minecraft/libraries/io/netty/netty-all/4.0.23.Final/netty-all-4.0.23.Final.jar:/home/pi/.minecraft/libraries/com/google/guava/guava/17.0/guava-17.0.jar:/home/pi/.minecraft/libraries/org/apache/commons/commons-lang3/3.3.2/commons-lang3-3.3.2.jar:/home/pi/.minecraft/libraries/commons-io/commons-io/2.4/commons-io-2.4.jar:/home/pi/.minecraft/libraries/commons-codec/commons-codec/1.9/commons-codec-1.9.jar:/home/pi/.minecraft/libraries/net/java/jinput/jinput/2.0.5/jinput-2.0.5.jar:/home/pi/.minecraft/libraries/net/java/jutils/jutils/1.0.0/jutils-1.0.0.jar:/home/pi/.minecraft/libraries/com/google/code/gson/gson/2.2.4/gson-2.2.4.jar:/home/pi/.minecraft/libraries/com/mojang/authlib/1.5.21/authlib-1.5.21.jar:/home/pi/.minecraft/libraries/com/mojang/realms/1.7.59/realms-1.7.59.jar:/home/pi/.minecraft/libraries/org/apache/commons/commons-compress/1.8.1/commons-compress-1.8.1.jar:/home/pi/.minecraft/libraries/org/apache/httpcomponents/httpclient/4.3.3/httpclient-4.3.3.jar:/home/pi/.minecraft/libraries/commons-logging/commons-logging/1.1.3/commons-logging-1.1.3.jar:/home/pi/.minecraft/libraries/org/apache/httpcomponents/httpcore/4.3.2/httpcore-4.3.2.jar:/home/pi/.minecraft/libraries/org/apache/logging/log4j/log4j-api/2.0-beta9/log4j-api-2.0-beta9.jar:/home/pi/.minecraft/libraries/org/apache/logging/log4j/log4j-core/2.0-beta9/log4j-core-2.0-beta9.jar:/home/pi/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl/2.9.4-nightly-20150209/lwjgl-2.9.4-nightly-20150209.jar:/home/pi/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl_util/2.9.4-nightly-20150209/lwjgl_util-2.9.4-nightly-20150209.jar:/home/pi/.minecraft/libraries/tv/twitch/twitch/6.5/twitch-6.5.jar:/home/pi/.minecraft/versions/1.8.9/1.8.9.jar net.minecraft.client.main.Main
[22:23:58 INFO]: Looking for orphaned versions to clean up...
[22:23:59 INFO]: Looking for old natives & assets to clean up...
[22:24:02 ERROR]: Game ended with bad state (exit code 1)
[22:24:02 INFO]: Ignoring visibility rule and showing launcher due to a game crash
[22:24:02 INFO]: Deleting /home/pi/.minecraft/versions/1.8.9/1.8.9-natives-6424581964525
[22:34:20 INFO]: Getting syncinfo for selected version
[22:34:20 INFO]: Queueing library & version downloads
[22:34:20 INFO]: Download job 'Version & Libraries' started (16 threads, 33 files)
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/io/netty/netty-all/4.0.23.Final/netty-all-4.0.23.Final.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/net/java/jinput/jinput-platform/2.0.5/jinput-platform-2.0.5-natives-linux.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/paulscode/soundsystem/20120107/soundsystem-20120107.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/net/java/jinput/jinput/2.0.5/jinput-2.0.5.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/org/apache/commons/commons-lang3/3.3.2/commons-lang3-3.3.2.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/net/sf/jopt-simple/jopt-simple/4.6/jopt-simple-4.6.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/paulscode/libraryjavasound/20101123/libraryjavasound-20101123.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl-platform/2.9.4-nightly-20150209/lwjgl-platform-2.9.4-nightly-20150209-natives-linux.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/tv/twitch/twitch/6.5/twitch-6.5.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/mojang/realms/1.7.59/realms-1.7.59.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/org/apache/commons/commons-compress/1.8.1/commons-compress-1.8.1.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/paulscode/codecwav/20101023/codecwav-20101023.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/ibm/icu/icu4j-core-mojang/51.2/icu4j-core-mojang-51.2.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/commons-logging/commons-logging/1.1.3/commons-logging-1.1.3.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/mojang/netty/1.6/netty-1.6.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/paulscode/librarylwjglopenal/20100824/librarylwjglopenal-20100824.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Download job 'Resources' skipped as there are no files to download
[22:34:20 INFO]: Job 'Resources' finished successfully (took 0:00:00.000)
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/ibm/icu/icu4j-core-mojang/51.2/icu4j-core-mojang-51.2.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/commons-io/commons-io/2.4/commons-io-2.4.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/mojang/realms/1.7.59/realms-1.7.59.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/net/java/jutils/jutils/1.0.0/jutils-1.0.0.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/net/java/jutils/jutils/1.0.0/jutils-1.0.0.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl/2.9.4-nightly-20150209/lwjgl-2.9.4-nightly-20150209.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl-platform/2.9.4-nightly-20150209/lwjgl-platform-2.9.4-nightly-20150209-natives-linux.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/io/netty/netty-all/4.0.23.Final/netty-all-4.0.23.Final.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/net/java/dev/jna/jna/3.4.0/jna-3.4.0.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/org/apache/commons/commons-compress/1.8.1/commons-compress-1.8.1.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl_util/2.9.4-nightly-20150209/lwjgl_util-2.9.4-nightly-20150209.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/paulscode/librarylwjglopenal/20100824/librarylwjglopenal-20100824.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/google/code/gson/gson/2.2.4/gson-2.2.4.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/commons-io/commons-io/2.4/commons-io-2.4.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/commons-codec/commons-codec/1.9/commons-codec-1.9.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/mojang/netty/1.6/netty-1.6.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/org/apache/httpcomponents/httpclient/4.3.3/httpclient-4.3.3.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/paulscode/codecwav/20101023/codecwav-20101023.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/google/guava/guava/17.0/guava-17.0.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/org/apache/logging/log4j/log4j-api/2.0-beta9/log4j-api-2.0-beta9.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/commons-logging/commons-logging/1.1.3/commons-logging-1.1.3.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/org/apache/httpcomponents/httpcore/4.3.2/httpcore-4.3.2.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/org/apache/logging/log4j/log4j-api/2.0-beta9/log4j-api-2.0-beta9.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/oshi-project/oshi-core/1.1/oshi-core-1.1.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/net/java/jinput/jinput-platform/2.0.5/jinput-platform-2.0.5-natives-linux.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/org/apache/logging/log4j/log4j-core/2.0-beta9/log4j-core-2.0-beta9.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/commons-codec/commons-codec/1.9/commons-codec-1.9.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/mojang/authlib/1.5.21/authlib-1.5.21.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/mojang/authlib/1.5.21/authlib-1.5.21.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/net/java/dev/jna/platform/3.4.0/platform-3.4.0.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl_util/2.9.4-nightly-20150209/lwjgl_util-2.9.4-nightly-20150209.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/libraries/com/paulscode/codecjorbis/20101023/codecjorbis-20101023.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/tv/twitch/twitch/6.5/twitch-6.5.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/org/apache/commons/commons-lang3/3.3.2/commons-lang3-3.3.2.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Attempting to download /home/pi/.minecraft/versions/1.8.9/1.8.9.jar for job 'Version & Libraries'... (try 0)
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/paulscode/libraryjavasound/20101123/libraryjavasound-20101123.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/paulscode/codecjorbis/20101023/codecjorbis-20101023.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/net/sf/jopt-simple/jopt-simple/4.6/jopt-simple-4.6.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/net/java/jinput/jinput/2.0.5/jinput-2.0.5.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/paulscode/soundsystem/20120107/soundsystem-20120107.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/oshi-project/oshi-core/1.1/oshi-core-1.1.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/google/code/gson/gson/2.2.4/gson-2.2.4.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/org/apache/httpcomponents/httpclient/4.3.3/httpclient-4.3.3.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/net/java/dev/jna/platform/3.4.0/platform-3.4.0.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/org/apache/httpcomponents/httpcore/4.3.2/httpcore-4.3.2.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:20 INFO]: Finished downloading /home/pi/.minecraft/libraries/org/apache/logging/log4j/log4j-core/2.0-beta9/log4j-core-2.0-beta9.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:21 INFO]: Finished downloading /home/pi/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl/2.9.4-nightly-20150209/lwjgl-2.9.4-nightly-20150209.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:21 INFO]: Finished downloading /home/pi/.minecraft/libraries/net/java/dev/jna/jna/3.4.0/jna-3.4.0.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:21 INFO]: Finished downloading /home/pi/.minecraft/libraries/com/google/guava/guava/17.0/guava-17.0.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:21 INFO]: Finished downloading /home/pi/.minecraft/versions/1.8.9/1.8.9.jar for job 'Version & Libraries': Local file matches hash, using that
[22:34:21 INFO]: Job 'Version & Libraries' finished successfully (took 0:00:01.217)
[22:34:21 INFO]: Launching game
[22:34:21 INFO]: Unpacking natives to /home/pi/.minecraft/versions/1.8.9/1.8.9-natives-7047780640569
[22:34:21 INFO]: Launching in /home/pi/.minecraft
[22:34:21 INFO]: Half command: /usr/lib/jvm/jdk-8-oracle-arm32-vfp-hflt/jre/bin/java -Xmx512M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M -Djava.library.path=/home/pi/.minecraft/versions/1.8.9/1.8.9-natives-7047780640569 -cp /home/pi/.minecraft/libraries/com/mojang/netty/1.6/netty-1.6.jar:/home/pi/.minecraft/libraries/oshi-project/oshi-core/1.1/oshi-core-1.1.jar:/home/pi/.minecraft/libraries/net/java/dev/jna/jna/3.4.0/jna-3.4.0.jar:/home/pi/.minecraft/libraries/net/java/dev/jna/platform/3.4.0/platform-3.4.0.jar:/home/pi/.minecraft/libraries/com/ibm/icu/icu4j-core-mojang/51.2/icu4j-core-mojang-51.2.jar:/home/pi/.minecraft/libraries/net/sf/jopt-simple/jopt-simple/4.6/jopt-simple-4.6.jar:/home/pi/.minecraft/libraries/com/paulscode/codecjorbis/20101023/codecjorbis-20101023.jar:/home/pi/.minecraft/libraries/com/paulscode/codecwav/20101023/codecwav-20101023.jar:/home/pi/.minecraft/libraries/com/paulscode/libraryjavasound/20101123/libraryjavasound-20101123.jar:/home/pi/.minecraft/libraries/com/paulscode/librarylwjglopenal/20100824/librarylwjglopenal-20100824.jar:/home/pi/.minecraft/libraries/com/paulscode/soundsystem/20120107/soundsystem-20120107.jar:/home/pi/.minecraft/libraries/io/netty/netty-all/4.0.23.Final/netty-all-4.0.23.Final.jar:/home/pi/.minecraft/libraries/com/google/guava/guava/17.0/guava-17.0.jar:/home/pi/.minecraft/libraries/org/apache/commons/commons-lang3/3.3.2/commons-lang3-3.3.2.jar:/home/pi/.minecraft/libraries/commons-io/commons-io/2.4/commons-io-2.4.jar:/home/pi/.minecraft/libraries/commons-codec/commons-codec/1.9/commons-codec-1.9.jar:/home/pi/.minecraft/libraries/net/java/jinput/jinput/2.0.5/jinput-2.0.5.jar:/home/pi/.minecraft/libraries/net/java/jutils/jutils/1.0.0/jutils-1.0.0.jar:/home/pi/.minecraft/libraries/com/google/code/gson/gson/2.2.4/gson-2.2.4.jar:/home/pi/.minecraft/libraries/com/mojang/authlib/1.5.21/authlib-1.5.21.jar:/home/pi/.minecraft/libraries/com/mojang/realms/1.7.59/realms-1.7.59.jar:/home/pi/.minecraft/libraries/org/apache/commons/commons-compress/1.8.1/commons-compress-1.8.1.jar:/home/pi/.minecraft/libraries/org/apache/httpcomponents/httpclient/4.3.3/httpclient-4.3.3.jar:/home/pi/.minecraft/libraries/commons-logging/commons-logging/1.1.3/commons-logging-1.1.3.jar:/home/pi/.minecraft/libraries/org/apache/httpcomponents/httpcore/4.3.2/httpcore-4.3.2.jar:/home/pi/.minecraft/libraries/org/apache/logging/log4j/log4j-api/2.0-beta9/log4j-api-2.0-beta9.jar:/home/pi/.minecraft/libraries/org/apache/logging/log4j/log4j-core/2.0-beta9/log4j-core-2.0-beta9.jar:/home/pi/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl/2.9.4-nightly-20150209/lwjgl-2.9.4-nightly-20150209.jar:/home/pi/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl_util/2.9.4-nightly-20150209/lwjgl_util-2.9.4-nightly-20150209.jar:/home/pi/.minecraft/libraries/tv/twitch/twitch/6.5/twitch-6.5.jar:/home/pi/.minecraft/versions/1.8.9/1.8.9.jar net.minecraft.client.main.Main
[22:34:21 INFO]: Looking for orphaned versions to clean up...
[22:34:21 INFO]: Looking for old natives & assets to clean up...
[22:34:25 ERROR]: java.io.IOException: Stream closed
[22:34:25 ERROR]: Game ended with bad state (exit code 1)
[22:34:25 INFO]: Ignoring visibility rule and showing launcher due to a game crash
[22:34:25 INFO]: Deleting /home/pi/.minecraft/versions/1.8.9/1.8.9-natives-7047780640569
[/i]
rpiMike
Thu May 12, 2016 12:05 pm
dsigurdsson wrote:I'm having some issue and wondering if anyone could assist abit.
... 4 more
-- Head --
Stacktrace:
Details:
Stacktrace:
Details:
LWJGL: 2.9.4
GL Caps:
Using VBOs: No
Resource Packs:
CPU: <unknown>
Did you get glxgears working at 60 fps ? Are you using a 1080p screen ? Are you using a 2.5 amp PSU ?
rpiMike
Thu May 12, 2016 12:09 pm
muggy - Are you using a 1080p screen ? Are you using a 2.5 amp PSU ?
If your using a non standard resolution the following might work :
You can turn the GL driver off using 'sudo raspi-config', which should return your desktop to normal.
dsigurdsson
Thu May 12, 2016 4:43 pm
... 4 more
-- Head --
Stacktrace:
Details:
Stacktrace:
Details:
LWJGL: 2.9.4
GL Caps:
Using VBOs: No
Resource Packs:
CPU: <unknown>
glxgears runs smooth at 59-60fps, currently using a 2.4A PSU, trying to verify the monitor, it's not a screen but a TV with HDMI input.
dsigurdsson
Thu May 12, 2016 10:51 pm
So screen was not running at 1080p, changed that. Now with AA GL Driver enabled I get black screen after reboot.
muggy
Fri May 13, 2016 5:12 pm
rpiMike wrote:muggy - Are you using a 1080p screen ? Are you using a 2.5 amp PSU ?
Hi rpiMike,
thanks for your reply.
I've already changed back the display settings with raspi-config and it looks fine again. I thought, as it is mentioned in the tutorial, that this experimental GL driver is necessary for minecraft to run.
The screen I'm using at the moment is a Toshiba LCD-TV-flatscreen conected with HDMI. Don't know how to find out if it's a 1080p but I'll try to get that information.
Found out it is a 2.5 amp PSU.
rpiMike
Fri May 13, 2016 5:24 pm
Yes, the experimental GL driver is required to run Minecraft, unfortunately its not compatible with all screens currently.
When the driver is enabled it draws more power from the Pi so you need a good power supply unit (PSU). The recommended one for the Pi3 is 5.1V (Volts) and 2.5A (Amps).
A new build of Raspbian has been released today, i'm flashing it to an sd card as I type this, might help with your issues.
muggy
Fri May 13, 2016 5:34 pm
New raspbian version, sounds promising :-)
Now that I know what a PSU is :lol: I can say it can deliver 2.5A.
muggy
Fri May 13, 2016 6:21 pm
O.K. here's what I found out about the TV-screen:
Toshiba 37 XV 635 D, 1920x1080 (Full HD) / ActiveVision M100 HD (100 Hz), 94 cm / 37" / 16:9, 4x HDMI (incl. HDCP)
Return to “Gaming”
