Page 16 of 17
Re: How to setup Minecraft 1.8.9 on RaspPi2
Posted: Thu Oct 26, 2017 10:45 am
by Xynus
AH, alright. Would the guide be located in this thread, or is it in a different one?
Posted: Thu Oct 26, 2017 10:49 am
by rpiMike
In the link in my first reply to you.
Posted: Fri Oct 27, 2017 1:44 am
by Xynus
Hey. I tried the aforementioned method, but it didn’t work. I got no error message, only a white minecraft window with nothing running. Could you give it a try and tell me your results?
Posted: Sat Oct 28, 2017 6:21 am
by trnt
What Minecraft version is this? I've got the same problem by starting Minecraft 1.0 and 1.1 with the launcher(Yes, that's possible, newer versions are not possible to be started in the launcher
Posted: Sat Oct 28, 2017 12:52 pm
by Xynus
I’m attempting Beta 1.1_02
Posted: Sun Nov 19, 2017 7:48 am
by trnt
Posted: Sun Nov 26, 2017 8:17 pm
by Frederk
I tried this but it keeps saying 'unsatisfied link error' even though I did step 7 and 8 multiple times.
Posted: Sun Nov 26, 2017 8:34 pm
by rpiMike
Are you after this specific version 1.8.9 ? Have you seen the new 1.12.1 tutorial ?
When do you get the error ? Are you on Raspbian Stretch ? Did glxgears work at 60fps ?
Posted: Sun Nov 26, 2017 9:34 pm
by Frederk
I did the 1.12 tutorial and now it worked! Don't know what was wrong...
Posted: Fri Dec 01, 2017 1:28 pm
by trnt
That could be caused from spelling mistakes. I had the same probloem until I discovered the mistake
Posted: Sat Dec 02, 2017 7:43 am
by trnt
I get the Unsatisfied Link Error when I try to play mineraft using the launcher.
Play Minecraft by entering:
cd Minecraft
./run.sh
Posted: Fri Dec 08, 2017 2:21 am
by ToxicFragz5665
how can i join servers...
whenever i try i get access token can be null :roll:
Posted: Fri Dec 08, 2017 1:38 pm
by rpiMike
There is a link to a run script somewhere in this thread that will connect to servers. Alternatively the 1.12.1 tutorial connects to servers.
Posted: Sat Dec 09, 2017 12:35 am
by ToxicFragz5665
can u send me the link,
i was able to go on servers on 1.12 but i tried a little diff on 1.8.9 and didnt work :shock:
Posted: Sun Dec 10, 2017 4:59 pm
by Xynus
Hello again!
I'm attempting to reinstall the game, but whenever I attempt to install Optifine, it calls an error;
java.util.zip.ZipException: error in opening zip file
at java.util.zip.ZipFile.open(Native Method)
at java.util.zip.ZipFile.<init>(ZipFile.java:225)
at java.util.zip.ZipFile.<init>(ZipFile.java:155)
at java.util.zip.ZipFile.<init>(ZipFile.java:169)
at optifine.Patcher.process(Patcher.java:71)
at optifine.Installer.installOptiFineLibrary(Installer.java:308)
at optifine.Installer.doInstall(Installer.java:94)
at optifine.InstallerFrame.onInstall(InstallerFrame.java:425)
at optifine.InstallerFrame.connEtoC1(InstallerFrame.java:490)
at optifine.InstallerFrame.access$7(InstallerFrame.java:484)
at optifine.InstallerFrame$IvjEventHandler.actionPerformed(InstallerFrame.java:46)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:2022)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2348)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:402)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:259)
at javax.swing.plaf.basic.BasicButtonListener.mouseReleased(BasicButtonListener.java:252)
at java.awt.Component.processMouseEvent(Component.java:6533)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3324)
at java.awt.Component.processEvent(Component.java:6298)
at java.awt.Container.processEvent(Container.java:2236)
at java.awt.Component.dispatchEventImpl(Component.java:4889)
at java.awt.Container.dispatchEventImpl(Container.java:2294)
at java.awt.Component.dispatchEvent(Component.java:4711)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4888)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4525)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4466)
at java.awt.Container.dispatchEventImpl(Container.java:2280)
at java.awt.Window.dispatchEventImpl(Window.java:2746)
at java.awt.EventQueue.dispatchEventImpl(EventQueue.java:758)
at java.awt.EventQueue.access$500(EventQueue.java:97)
at java.awt.EventQueue$3.run(EventQueue.java:709)
at java.awt.EventQueue$3.run(EventQueue.java:703)
at java.security.AccessController.doPrivileged(Native Method)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:80)
at java.security.ProtectionDomain$JavaSecurityAccessImpl.doIntersectionPrivilege(ProtectionDomain.java:90)
at java.awt.EventQueue$4.run(EventQueue.java:731)
at java.awt.EventQueue$4.run(EventQueue.java:729)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:728)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:201)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:116)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:105)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:101)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:93)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:82)
Does anyone know a fix for this?
Optifine
Posted: Mon Mar 05, 2018 4:37 pm
by catsettos
I followed the steps in @Sindybad's tutorial on the first page and I keep getting the message
"Error: Could not find or load main class net.minecraft.launchwrapper.Launch"
and nothing happens. If anyone knows how to fix this please do :D
Posted: Mon Mar 05, 2018 5:48 pm
by rpiMike
Are you after 1.8.9 specifically ? My instructions for 1.12.1 include Optifine (link at top of first page).
Posted: Sat May 05, 2018 3:38 am
by Zenmama11
Please help
I have poured over this thread over and over and I am stuck on this:
Java HotSpot(TM) Client VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
Error: Could not find or load main class net.minecraft.client.main.Main
I have followed the steps to the best of my knowledge but clearly I am doing something wrong...
I am running pi3
I have version Oracle 8 for java
I have tried using version 1.8.9 in the minecraft launcher under edit profile
my glx gears are running around 38 fps but I saw someone else said they got it to work around this rate
I have updated my login info in the .sh file and put " " around my password because of a special character
....and I am almost ready to give up
So I digress, Please help
Posted: Sat May 05, 2018 1:48 pm
by rpiMike
Are you running the latest Raspbian Stretch ? glxgears should be close to 60fps, are you using an hdmi screen and decent psu?
Did you edit anything other than username and password in the run.sh. The script in the tutorial is specific to version 1.8.9.
Any reason your not using the 1.12 tutorial?
Posted: Mon Oct 08, 2018 12:37 pm
by LoLec
Hello! Could you do a 1.6.4 version with forge (for mods) please? I would like to run Minecraft 1.6.4 with Sim U Kraft mod.
Posted: Mon Oct 08, 2018 6:37 pm
by LoLec
What about forge? (For mods). Would be nice to play minecraft with mods on the raspberry pi 3. P.S i have a RPi 3 Model B+.
Posted: Fri Oct 26, 2018 8:20 am
by LoLec
Can i run 1.6.4 on the raspberry pi 3? And is it possible to play with Forge and mods?
Posted: Sat Feb 16, 2019 4:43 pm
by thebko
can i get some help when i type .run.sh it just says
: Syntax error: Unterminated quoted string
Posted: Wed Mar 20, 2019 3:33 pm
by RaspiBasti
Thank you, it works great!
But is it normal, that i can't join any servers?
It says, "Failed to login: Invalid session."
And is it possible to fix this? :?
Posted: Wed Mar 20, 2019 4:08 pm
by rpiMike
Are you specifically after 1.8.9? My other tutorial on 1.12.1 connects to servers.
