Page 15 of 17
Re: Problem Servers
Posted: Fri Sep 22, 2017 2:27 pm
by Dutch-Pi-Guy
I have minecraft on my raspberry pi 3 but it do not want to connect to a minecraft server
Re: How to setup Minecraft 1.8.9 on RaspPi2
Posted: Fri Sep 22, 2017 5:33 pm
by rpiMike
Which version of Minecraft have you installed ? Have you installed Optifine also ?
There are links to run script files in the thread that allow server access for 1.8.9 with/without Optifine.
What server are you trying to connect to ?
You might need a newer version of Minecraft, 1.12.1 tutorial here viewtopic.php?f=78&t=186547
Posted: Sat Sep 23, 2017 11:17 pm
by ijens10
ok, so I found out that I was using noobs instead of raspbian. I have now downloaded raspbian onto a new micro sd and went through the instructions. everything went very smotthly and I was really excited bc it was actually going to work this time. Only to find out that bash: ./run.sh: Permission denied. :( :oops: . Help.....
Posted: Sun Sep 24, 2017 6:30 am
by rpiMike
Try :
sudo chmod +x run.sh
Posted: Sun Sep 24, 2017 6:16 pm
by VeraDra
I've been looking to get 1.9.4 working, a friend of mine has a 1.9.4 server and can't upgrade for some reason. Despite multiple attempts to modify the run.sh file, I always get an error.
Java HotSpot(TM) Client VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
2017-09-24 13:04:16,176 ERROR Error processing element Queue: CLASS_NOT_FOUND
2017-09-24 13:04:16,281 ERROR Unable to locate appender ServerGuiConsole for logger
Exception in thread "main" java.lang.NoClassDefFoundError: com/mojang/authlib/properties/PropertyMap
	at net.minecraft.client.main.Main.main(SourceFile:88)
Caused by: java.lang.ClassNotFoundException: com.mojang.authlib.properties.PropertyMap
	at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
	at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331)
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
	... 1 more
I tried using this and not the 1.12.1 one, because I assumed that 1.8.9 is closer to 1.9.4 than 1.12.1 is.
What exactly would I need to change in the run.sh?
Posted: Sun Sep 24, 2017 6:54 pm
by rpiMike
Copied from last paragraph of 1.12.1 tutorial :
If you want to attempt getting a new version of Minecraft working :
1 Install required version using java -jar Minecraft.jar - and allow to crash
2 Scroll up in terminal window and find last ../jre/bin/java command, scroll across and find ‘-cp ’, copy this path list until ‘ net.minecraft.launchwrapper.Launch’
3 Paste this text into the cp= in the run.sh script
Posted: Sun Sep 24, 2017 7:44 pm
by VeraDra
Thanks!
Posted: Sun Sep 24, 2017 7:51 pm
by VeraDra
Problem #2:
Exception in thread "main" java.lang.SecurityException: class "bvg"'s signer information does not match signer information of other classes in the same package
	at java.lang.ClassLoader.checkCerts(ClassLoader.java:895)
	at java.lang.ClassLoader.preDefineClass(ClassLoader.java:665)
	at java.lang.ClassLoader.defineClass(ClassLoader.java:758)
	at java.security.SecureClassLoader.defineClass(SecureClassLoader.java:142)
	at java.net.URLClassLoader.defineClass(URLClassLoader.java:467)
	at java.net.URLClassLoader.access$100(URLClassLoader.java:73)
	at java.net.URLClassLoader$1.run(URLClassLoader.java:368)
	at java.net.URLClassLoader$1.run(URLClassLoader.java:362)
	at java.security.AccessController.doPrivileged(Native Method)
	at java.net.URLClassLoader.findClass(URLClassLoader.java:361)
	at java.lang.ClassLoader.defineClass1(Native Method)
	at java.lang.ClassLoader.defineClass(ClassLoader.java:760)
	at net.minecraft.client.main.Main.main(SourceFile:39)
I had copied everything after 'cp-' and before 'net.minecraft.launchwrapper.Launch'
Posted: Sun Sep 24, 2017 11:22 pm
by ijens10
Try :
All good now. I tried using
bash ~/Minecraft/run.sh
Which works fine so thank you very much. For future people wanting to do this I recommend bringing down the frame rate to around 30 bc even with a 64 mb micro sd it still freezes and lags if I move to fast. Anyway, thanks rpimike for the great find. C u guys around! :D
Posted: Tue Sep 26, 2017 5:12 am
by ijens10
Hi again Mike,
yes, it's me. Minecraft works fine on my Big desktop, Works fine on my tv, but as soon as I moved it to my small desktop I get this crash report:
---- Minecraft Crash Report ----
// Ouch. That hurt :(
Time: 26/09/17 2:58 PM
Description: Initializing game
java.lang.ExceptionInInitializerError
	at ave.ar(SourceFile:560)
	at ave.am(SourceFile:361)
	at ave.a(SourceFile:310)
	at net.minecraft.client.main.Main.main(SourceFile:124)
Caused by: java.lang.NullPointerException
	at org.lwjgl.opengl.LinuxDisplay.getAvailableDisplayModes(LinuxDisplay.java:947)
	at org.lwjgl.opengl.LinuxDisplay.init(LinuxDisplay.java:738)
	at org.lwjgl.opengl.Display.<clinit>(Display.java:138)
	... 4 more
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
	Minecraft Version: 1.8.9
	Operating System: Linux (arm) version 4.9.41-v7+
	Java Version: 1.8.0_65, Oracle Corporation
	Java VM Version: Java HotSpot(TM) Client VM (mixed mode), Oracle Corporation
	Memory: 97042480 bytes (92 MB) / 160174080 bytes (152 MB) up to 1060372480 bytes (1011 MB)
	JVM Flags: 5 total; -Xmn128M -Xmx1024M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy
	IntCache: cache: 0, tcache: 0, allocated: 0, tallocated: 0
	Launched Version: 1.8
	LWJGL: 2.9.4
	OpenGL: ~~ERROR~~ RuntimeException: No OpenGL context found in the current thread.
	GL Caps:
	Using VBOs: No
	Is Modded: Probably not. Jar signature remains and client brand is untouched.
	Type: Client (map_client.txt)
	Resource Packs:
	Current Language: ~~ERROR~~ NullPointerException: null
	Profiler Position: N/A (disabled)
	CPU: <unknown>
HELP??
Thank you very much again.....
Posted: Tue Sep 26, 2017 6:11 am
by rpiMike
Is that one Raspberry Pi being moved between 3 different displays ? If so what screen resolution is each ? Are you using Open GL Full / Fake ?
Posted: Tue Sep 26, 2017 7:48 am
by ijens10
As specified I have changed the open gl to Full in the raspi-config menu. The 3 displays are all set to auto however, if you need the specifications then I can find them out for you?
Posted: Tue Sep 26, 2017 7:54 am
by rpiMike
Does glxgears run at 60fps on your small desktop ? I suspect OpenGL isn't working properly on your small desktop - maybe screen resolution problem.
Posted: Tue Sep 26, 2017 8:10 am
by ijens10
As far as I know yes but I can check again tomorrow. Parental restrictions...
Posted: Tue Sep 26, 2017 11:45 pm
by Hyperthread
Please help!
Whenever I press "Play" it gives me this!
[18:40:21 INFO]: Looking for orphaned versions to clean up...
[18:40:21 INFO]: Looking for old natives & assets to clean up...
[18:40:27 INFO]: Game ended with no troubles detected (exit code 0)
[18:40:27 INFO]: Following visibility rule and exiting launcher as the game has ended
[18:40:27 INFO]: Deleting /home/pi/.minecraft/versions/1.8.9-OptiFine_HD_U_H8/1.8.9-OptiFine_HD_U_H8-natives-3026872717539
[18:40:27 INFO]: Requesting window close
[18:40:27 INFO]: Window closed, shutting down.
[18:40:27 INFO]: Halting executors
[18:40:27 INFO]: Awaiting termination.
[18:40:27 INFO]: Goodbye.
Posted: Mon Oct 09, 2017 8:43 am
by ijens10
Hi Mike, thanks for all your help. All is good so it must’ve been a little glitch in the system. See you around and I hope this is the last post I make in this thread!!!!
Posted: Fri Oct 20, 2017 11:09 am
by trnt
Sindybad wrote:
Tue Mar 01, 2016 8:31 pm
I have worked out how to install the OptiFine mod :D
Runs on average at a good 20 frames per second :o
How to install the OptiFine mod for better performance:
Assuming you have completed the tutorial above(and installed Minecraft 1.8.9):
Go to http://optifine.net/downloads
And download “OptiFine 1.8.9 HD U H3”
Go to your downloads
cd ~/Downloads
And run optifine installer
java -jar OptiFine_1.8.9_HD_U_H3.jar
Click install.
Now launch Minecraft
cd ~/Minecraft
Select the OptiFine profile and click play. The launcher will crash
Install asm:
cd ~/Minecraft
mkdir Libraries
cd Libraries
Download asm-5.0.4-bin.zip from http://forge.ow2.org/project/showfiles. ... se_id=5660
Move it to the Libraries folder
cd ~/Minecraft/Libraries
mv ~/Downloads/asm-5.0.4-bin.zip .
Unzip it
unzip asm-5.0.4-bin.zip
Now download my updated run.sh:
cd ~/Minecraft
wget https://www.dropbox.com/s/0r5trow18vi5vls/runOptifine.sh?dl=1 -O runOptifine.sh
Fill runOptifine.sh with your Minecraft login details
Edit MINECRAFT_LOGIN, MINECRAFT_USERNAME, MINECRAFT_PASSWORD and MINECRAFT_UUID:
nano runOptifine.sh
Change permissions of file:
chmod 700 runOptifine.sh
Now run it:
./runOptifine.sh
When Minecraft has launched, turn everything down to low in the video settings (and turn on things like fast math)
Close Minecraft(It might crash if you open a world now)
And relaunch it:
./runOptifine.sh
Thanks for reading!
P.S. rpiMike, you can include this in the original post if you want
But when I type ./runOptifine.sh there is a bash:
bash: ./runOptifine.sh: Keine Berechtigung
(I don't know how to translate this German words, but it means, I'm not allowed to run this)
I copied the matter into a new file called run1.sh but then my terminal showed that:
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 277 100 107 100 170 245 390 --:--:-- --:--:-- --:--:-- 390
todays access token =
Okt 20, 2017 12:51:37 PM net.minecraft.launchwrapper.LogWrapper log
INFORMATION: Loading tweak class name optifine.OptiFineTweaker
SCHWERWIEGEND: Unable to launch
java.lang.ClassNotFoundException: optifine.OptiFineTweaker
at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:99)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:348)
at net.minecraft.launchwrapper.Launch.launch(Launch.java:94)
at net.minecraft.launchwrapper.Launch.main(Launch.java:27)
(SCHWERWIEGEND could be the same as FATAL ERROR)
Posted: Fri Oct 20, 2017 11:19 am
by trnt
rpiMike wrote:
Sun Mar 06, 2016 7:11 pm
Yes, it is possible to connect to Minecraft servers.
No, it isn't. When I try to connect to a server minecraft says: invalid session (try restarting your game)
I'm using LXTerminal, Raspberry Pi3 and the latest raspbian jessie. I've tried to run minecraft directly by entering
cd ~/.minecraft/versions/1.8.9/
java -jar 1.8.9.jar
and then it says
Fehler: Hauptklasse net.minecraft.client.Main konnte nicht gefunden oder geladen werden
I've searched in the internet for the meaning of this sentence but other people only get this:
Fehler: Hauptklasse net.minecraft.client.Main konnte nicht gefunden oder geladen werden Java HotSpot(TM) Client VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
Posted: Fri Oct 20, 2017 11:23 am
by trnt
I'm using noobs, too. But is that serious.
Posted: Fri Oct 20, 2017 11:32 am
by rpiMike
If you get permission denied running a .sh file you probably need 'sudo chmod +x <file>'
I'm assuming you installed Raspbian using Noobs?
Is there a reason you want Minecraft 1.8.9 - the new tutorial for 1.12.1 would be easier : viewtopic.php?f=78&t=186547
Posted: Wed Oct 25, 2017 1:11 pm
by trnt
And if you've downloaded and started the launcher don't start it with
cd Minecraft
That downloads Minecraft.jar and starts the launcher.
This is faster:
cd .minecraft
java -jar launcher.jar
Posted: Thu Oct 26, 2017 12:11 am
by Xynus
Hello! I know this is probably an oldder thread, but I was wondering if anyone could send me a run script or anything to allow me to run minecraft on beta 1.1_02. I co-own a server called Nostalgia Project, and I thought it would make things easier to take the little computer around with me to help me get on and do work faster
Posted: Thu Oct 26, 2017 6:44 am
by rpiMike
If you read the last paragraph of the 1.12.1 thread - it tells you how to create the class path for a different version of Minecraft for your own script.
Posted: Thu Oct 26, 2017 10:35 am
by Xynus
I know, but I’m not exactly the best at locating libraries. Last time I attempted to do it, it ended up in a big mess and nothing got accomplished lol
Posted: Thu Oct 26, 2017 10:40 am
by rpiMike
You don't need to locate any libraries - basically run Minecraft.jar - let it fail - and copy the class path.
