Aang
Re: How to setup Minecraft 1.8.9 on RaspPi2
Mon Jun 12, 2017 2:28 pm
And try creating a new flat world ( for testing ), there some’ issue with old world from others versions.
rpiMike
Tue Jun 13, 2017 7:48 am
Minecraft 1.12 does work :)
Xcom6000
Tue Jun 13, 2017 8:03 am
I did the "sudo apt update && sudo apt upgrade -y". Then tried to create a superflat terrain to try login to the game. It gets stuck here as shown on the picture.
Xcom6000
Tue Jun 13, 2017 10:04 am
Its more then likely something wrong with some installation step. I don't have a lot of experience using the pi. Just followed random tutorials to install the operative system and the game. It seams the game crashes just on its own randomly in the menu screen. I will try to reinstall everything from a full formated SD card. But as this is the 3rd time doing that its starting to become a bit hopeless to the exact step I'm missing or how to even fix it.
Aang
Tue Jun 13, 2017 11:38 am
Now try to load this world... It should work. Else I do not see what is wrong, but remember this is experimental. Did you tried going on a server ?
Xcom6000
Wed Jun 14, 2017 12:42 pm
After finding my UUID from this sight and setting it. https://mcuuid.net/
I tried to login to a server. One of the survival servers was impossible to login to. Crashed immediately, a server that I had issues trying to login to using the Minecraft Console Client as well with my pi.
Another creative server I logged into caused a freez after 1-2 seconds and my pi became unresponsive.
I also tried to generate a new super flat world and login to it. Crashed as shown in the picture above.
I should note that I'm connecting to the pi using RealVNC and I used this guide to install the operative system.
https://www.youtube.com/watch?v=toWBmUsWD6M
I also should note that I could run Minecraft 1.8.9 when installed and play it, although it was choppy it worked fine. Its only the change to 1.11.2 that seams oddly impossible. I have even attempted to reinstall everything from scratch and try it again all over from the start with no change.
Either I miss some form of update, old java version or some other unknown update that I'm unaware of or there is a key important step in some guide or something that I'm missing.
Aang
Wed Jun 14, 2017 1:58 pm
The simple way to be sure it if I send my complete 1.11.2 install, java included.
Xcom6000
Wed Jun 14, 2017 2:43 pm
That would be really sweet. Could easily test that way.
Aang
Wed Jun 14, 2017 4:26 pm
Will do that quickly.
xXRoboBoyXx
Wed Jun 14, 2017 6:56 pm
rpiMike wrote:Minecraft 1.12 does work :)
Awesome! Now we need to wait for 1.12 optifine (:
Ps. Would overclocking the gpu get more fps? Got f1-f12 working also!
3.141592653589...
xXRoboBoyXx
Mon Jun 19, 2017 5:38 pm
I'm getting 10-30 fps on a overclocked raspberry pi 3! This tutorial is awesome!
3.141592653589...
Aang
Mon Jun 19, 2017 7:38 pm
I am actually making fixes for 1.9, 1.10, 1.11, 1.12, and forge / optifine.
I will post them here with some automated install script for off-line mode. But I do not have that's much time to work on.
Xcom6000
Tue Jun 20, 2017 10:24 am
That would be really nice. Really hoping that 1.12 might fix so Minecraft is playable on the pi. The guides here on this thread starts with an assumption you have a working pi already. There is no instruction where its installed from a formatted SD card. There must be missing installations steps and is the reason some people have problems and others don't.
rpiMike
Wed Jun 21, 2017 10:45 am
Minecraft 1.12 with Optifine running on Raspberry Pi 3 :
https://youtu.be/2sREfySmRNU
New 1.12 thread :
viewtopic.php?f=78&t=186547
Paulwood
Sat Jun 24, 2017 5:08 pm
Looks like there is a conflict with the new (2017-06-21-raspbian-jessie) Jessie version and the GL Driver . When you do step 4 Enable ‘GL Driver’ and reboot, Pixel comes up without a menu bar. If you shutoff the GL Driver the menu bar comes back.
rpiMike
Sat Jun 24, 2017 5:17 pm
Paulwood wrote:Looks like there is a conflict with the new (2017-06-21-raspbian-jessie) Jessie version and the GL Driver . When you do step 4 Enable ‘GL Driver’ and reboot, Pixel comes up without a menu bar. If you shutoff the GL Driver the menu bar comes back.
Yes, that does seem to be a problem.
gaetawoo
Mon Jun 26, 2017 2:35 am
quavoce wrote:These are the commands that I ran to get Minecraft 1.11.2 running on my RPi3 (latest Wheezy). They have all been taken from the first page instructions, and just copied here for reference to show what worked.
I used this post: viewtopic.php?p=1096541#p1096541
to get 1.11.2 working on my RaspPi 3B. Worked perfectly. But now, 1.12 is out. and I did the exact same steps and I change my current working runOptifine.sh script to have the 1.12 instead 1.11 in VERSION and to reference the new Optifine folders and jar files. And it fails. This is the console text:
[email protected]:~/Minecraft $ ./runOptifine.sh
  % Total    % Received % Xferd  Average Speed   Time    Time     Time  Current
                                 Dload  Upload   Total   Spent    Left  Speed
100   445  100   269  100   176    702    459 --:--:-- --:--:-- --:--:--   704
todays access token = 6b19dfea0fc34bd792d3722fa87269bc
Java HotSpot(TM) Client VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
Jun 25, 2017 9:24:32 PM net.minecraft.launchwrapper.LogWrapper log
INFO: Loading tweak class name optifine.OptiFineTweaker
Jun 25, 2017 9:24:33 PM net.minecraft.launchwrapper.LogWrapper log
INFO: Using primary tweak class name optifine.OptiFineTweaker
INFO: Calling tweak class optifine.OptiFineTweaker
OptiFineTweaker: acceptOptions
OptiFineTweaker: injectIntoClassLoader
OptiFine ClassTransformer
OptiFine URL: file:/home/pi/.minecraft/libraries/optifine/OptiFine/1.12_HD_U_C2/OptiFine-1.12_HD_U_C2.jar
OptiFine ZIP file: /home/pi/.minecraft/libraries/optifine/OptiFine/1.12_HD_U_C2/OptiFine-1.12_HD_U_C2.jar
OptiFineTweaker: getLaunchArguments
OptiFineTweaker: getLaunchTarget
INFO: Launching wrapped minecraft {net.minecraft.client.main.Main}
Jun 25, 2017 9:24:36 PM net.minecraft.launchwrapper.LogWrapper log
SEVERE: Unable to launch
java.lang.reflect.InvocationTargetException
        at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
        at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
        at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
        at java.lang.reflect.Method.invoke(Method.java:497)
        at net.minecraft.launchwrapper.Launch.launch(Launch.java:131)
        at net.minecraft.launchwrapper.Launch.main(Launch.java:27)
Caused by: java.lang.NoSuchMethodError: org.apache.logging.log4j.Logger.info(Ljava/lang/String;Ljava/lang/Object;)V
        at bhz.<init>(SourceFile:370)
        at net.minecraft.client.main.Main.main(SourceFile:123)
        ... 6 more
Anyone have any ideas?? I'd love to get 1.12 working with Optifine for my kid so he can play with his siblings and on the online servers. Thank you!
rpiMike
Mon Jun 26, 2017 6:11 am
        ... 6 more
New 1.12 thread :
gaetawoo
Mon Jun 26, 2017 2:18 pm
rpiMike wrote: New 1.12 thread :
Yea I saw that after I posted. I did everything the same you did and it still didn't work, then you posted the bit about running it from the Minecraft.jar and copypasta-ing the path after -cp and using that in the run script and then it worked. So that was key! Thanks for that! I got OptiFine 1.12 running.
owen_soo
Thu Jun 29, 2017 3:55 pm
You need to enable the OpenGLdriver with the Fake MS? I dont remember what it was called exactly but something like that it works GREAT(~12 FPS on a server) on my PI3!
rpiMike
Thu Jun 29, 2017 4:22 pm
You should be using Open GL (Full KMS).
owen_soo
Thu Jun 29, 2017 4:26 pm
Really? It works fine for me with the fake one :P
gaetawoo
Thu Jun 29, 2017 4:29 pm
yea i'm using the fake one. i tried the full and it wouldn't work.. can't remember why, it was a while ago.. but it would work with the fake.
rpiMike
Thu Jun 29, 2017 4:41 pm
Just tried it - Fake KMS does indeed work :D
Quinten_Knight7601
Tue Jul 04, 2017 5:43 am
I am having troubles with this, every time I try starting Minecraft it comes up with a message saying that it could not find or load main class net.minecraft.client.main.Main :cry: did I do something wrong? Do I need to change something? Please let me know how to fix this
Return to “Gaming”
