Page 9 of 17
Re: How to setup Minecraft 1.8.9 on RaspPi2
Posted: Tue Jan 17, 2017 4:00 pm
by Sumie
Xynus wrote:Would there ever be a way to run simple Forge mods on the raspberry pi? I was thinking simpler mods, like Effect HUD, Armour HUD, etc.? OR would the type of mod not make a difference?
Maybe. Take it upon yourself to see how it functions (if it's just JAR files injected into the command line, figure out which and try to include them in the CP line, and maybe it includes another class or something). Generally you can run Minecraft through the Java console on a PC that has the mods you want installed, and backtrack the log to find out how it works, then try transplanting those actions to the runOptifine script. That's how I got to the point of figuring how to get the most recent version of Minecraft loaded up on the Pi. The Pi was made for tinkering so... tinker.
When I started trying to get Minecraft on here, I knew almost nothing about Linux as a whole and definitely nothing about Java. Now I have a basic idea of how they both function and I can get around in Linux and I actually use Java command line to execute other Java based applications I ran (which until recently didn't even know they were Java apps). You can take a lot of pride in knowing you figured out how to do something yourself instead of relying on others to get it done. It makes you enjoy it that much more. :D
Everyone has their limitations and I certainly have mine, but it's fun to improve. I would love to be able to actually write that runOptifine script rather than take someone else's work and modify it. There is so much about how to write scripts I don't understand yet, but I hope to get there in the future.
If you do attempt loading these mods and run into problems, post what you're seeing and we'll try to work through it. That's kind of why these forums exist. Yay for collaboration!
Posted: Thu Jan 19, 2017 2:59 am
by xXxSilverterminalxXx
I'm using Raspberry Pi 3, and I can't seem to be able to join servers. I keep getting a message saying something about an incorrect session. What do I do?
HAAAAAAALP!
Posted: Thu Jan 19, 2017 8:57 am
by rpiMike
xXxSilverterminalxXx wrote:I'm using Raspberry Pi 3, and I can't seem to be able to join servers. I keep getting a message saying something about an incorrect session. What do I do?
HAAAAAAALP!
Try this run2.sh :
viewtopic.php?p=990835#p990835
Posted: Sun Jan 22, 2017 7:58 pm
HAAAAAAALP!
Try this run2.sh :
Thank you, it works now!
But there is one question I'd like to ask.
Can you make it run well?
Posted: Mon Jan 23, 2017 2:42 pm
by Sumie
xXxSilverterminalxXx wrote: Thank you, it works now!
Turn things down. I posted my configuration settings with many items turned down or off if you don't want to poke through all the settings. It's on the previous page.
The way this works in a Java VM with the whole 'server-client' method, you can't expect to squeeze much performance out of the game with the hardware it's on. I do get 30-50 fps with my settings though, which is relatively playable.
If you're a Java guru, you can try messing with the Java parameters passed in the run.sh script. I doubt there's much wiggle room there as well, though.
Posted: Sun Feb 12, 2017 4:16 am
by drffreeze
Hello Sumie,
I have been able to install Classic Minecraft. Thanks!
I had a question though, do you get a black screen when your FPS goes over your monitor's refresh rate? My refresh rate is 60Hz and it feels like if Minecraft goes over 60 Hz it causes the screen to black.
Regards,
drffreeze
Posted: Mon Feb 13, 2017 9:39 pm
by Sumie
drffreeze wrote:I had a question though, do you get a black screen when your FPS goes over your monitor's refresh rate? My refresh rate is 60Hz and it feels like if Minecraft goes over 60 Hz it causes the screen to black.
I can't say that I have. Usually it's just a struggle to get the FPS up to 50. Regardless, rendered framerate and refresh rate of your monitor are not directly related, other than trying to eliminate screen taring and stuttering gameplay.
I have noticed, however, that I was not able to connect my Pi up to certain monitors and TVs in my house. So, now that you mention it, may have been my problem and that the refresh rate was not supported on the Pi that my monitor/TV was requiring. I'll get around to testing it eventually.
If the screen 'goes black', does it ever come back up or do you have to reboot the Pi?
Posted: Tue Feb 14, 2017 1:55 am
by drffreeze
Hello Sumie,
I tried vsync and that did not solve the issue. I also tried adding a heatsink to see if it was a heat issue but that didn't help. I tried a 30W 5V supply and that did not help. Lastly I moved my microSD card over to my son's Pi 3 and it also exhibited the same issue.
When the screen goes black it just does so momentarily. It comes back just fine until it appears to go over 60+ FPS.
I may just try to rebuild Classic Minecraft from a fresh Raspbian install and check for black screen issue before I install OptiFine. I have tried other OpenGL applications and they don't experience the same issue even though they go well over 60 FPS.
I am trying to teach my kids about the scientific method by using overclocking their RPi 3 (CPU, GPU, and hypothesis). I have yet to find a way to log Minecraft FPS to a file. Do you know any way to log the FPS? The Debug Screen has much to variance.
Thanks for your help!
drffreeze
Posted: Tue Feb 14, 2017 6:05 pm
by Sumie
I was having a very similar issue with the screen blacking out for a second or so pretty frequently (2-5 times a minute), using the November update of Raspbian after overclocking my SDcard port. I reimaged 2 or 3 times and same behavior, of course then I overclocked the SDcard slot. I was thinking it was pretty benign to do since my SDcard could handle it (Sandisk Extreme Pro), but the last time I reimaged using the January update I had forgone the overclocking of the SDcard slot. Lo and behold, the flickering had stopped and I haven't seen it since.
Try reimaging your Pi without overclocking any settings and install Minecraft with Optifine and see if you get the same thing.
Posted: Wed Feb 15, 2017 5:41 pm
by Taberl
i get this report everytime i want to start ./run.sh
Description: Initializing game
java.lang.ExceptionInInitializerError
at ave.ar(SourceFile:560)
at ave.am(SourceFile:361)
at ave.a(SourceFile:310)
at net.minecraft.client.main.Main.main(SourceFile:124)
Caused by: java.lang.ArrayIndexOutOfBoundsException: 0
at org.lwjgl.opengl.XRandR.findPrimary(XRandR.java:326)
at org.lwjgl.opengl.XRandR.ScreentoDisplayMode(XRandR.java:315)
at org.lwjgl.opengl.LinuxDisplay$3.run(LinuxDisplay.java:746)
at org.lwjgl.opengl.LinuxDisplay$3.run(LinuxDisplay.java:743)
at java.security.AccessController.doPrivileged(Native Method)
at org.lwjgl.opengl.LinuxDisplay.init(LinuxDisplay.java:743)
at org.lwjgl.opengl.Display.<clinit>(Display.java:138)
... 4 more
Please help me ;(
Posted: Wed Feb 15, 2017 5:46 pm
by Sumie
For kicks, I decided to overclock my Pi3 last night, mostly to see if I could duplicate the video flicker issue I was having before. Took it up to 1.35 GHZ CPU with a 500mhz overclocked ram setting and 500mhz GPU core, and doubling the clock on my SDcard slot from 50 to 100 (using a different method than I was using before). Overvolt was set to 4, and seems to be stable. No blacking out randomly during Minecraft play. CPU temps hover at around 55 degrees Celsius (but I have a case with a heatsink and fan on the CPU, which I love by the way).
Ran Minecraft on it for over 2 hours, no issues, and was running at anywhere from 35-60 FPS. I even bumped the view distance from 2 to 3 and handled it great.
Posted: Thu Feb 16, 2017 2:30 am
by Sumie
Taberl wrote:Hello,
... 4 more
Please help me ;(
I bolded the important parts of the exception. From what I can tell, it looks like java is not able to initialize the display driver for this particular display mode. If you haven't already, update the distro and mesa tools, enable the OpenGL driver and set the VidRAM to 192, and if that doesn't work, try a different display.
Update Distro:
sudo apt-get update && sudo apt-get -y upgrade
Update Mesa Tools:
sudo apt-get -y install xcompmgr libgl1-mesa-dri && sudo apt-get -y install libalut0 libalut-dev && sudo apt-get -y install mesa-utils
Enable OpenGL driver:
Start > Applications > Raspberry Configuration Tool, then enable OpenGL driver. Make sure to set the Video RAM to at least 192 (that's what I set it to). Reboot.
Posted: Thu Feb 16, 2017 2:54 am
by drffreeze
Hello Sumie,
Thank you for your feedback. I will try to reload Classic Minecraft again on a clean build but without OptiFine or overclocking and see what I get.
Regards,
drffreeze
Posted: Thu Feb 16, 2017 4:09 pm
by Sumie
drffreeze wrote:Hello Sumie,
Regards,
drffreeze
I figured if you were able to put the SDcard into 2 systems and have the same thing happen, the problem is what is on that SDcard, most likely. I would go ahead with the Optifine installation though, as I seem to have more luck with it installed than without.
Posted: Mon Feb 20, 2017 4:00 pm
by Taberl
Thank You ! I tried a different display and it worked. But it is unplayable for me. Minecraft crashed 5 times in 30min. However thank you for your help :D
Posted: Sat Feb 25, 2017 12:37 am
by hdarr03
I tried to install optifine with the same instructions that were listed (With the exception of the file from optifine being h6 instead of h3) but whenever I try to run it, it gives me this error message in the terminal
todays access token =
Java HotSpot(TM) Client VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
Feb 25, 2017 12:29:07 AM net.minecraft.launchwrapper.LogWrapper log
INFO: Loading tweak class name optifine.OptiFineTweaker
SEVERE: Unable to launch
java.lang.ClassNotFoundException: optifine.OptiFineTweaker
at java.net.URLClassLoader.findClass(URLClassLoader.java:381)
at java.lang.ClassLoader.loadClass(ClassLoader.java:424)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331)
at java.lang.ClassLoader.loadClass(ClassLoader.java:357)
at net.minecraft.launchwrapper.LaunchClassLoader.findClass(LaunchClassLoader.java:99)
at java.lang.Class.forName0(Native Method)
at java.lang.Class.forName(Class.java:348)
at net.minecraft.launchwrapper.Launch.launch(Launch.java:94)
at net.minecraft.launchwrapper.Launch.main(Launch.java:27)
Any idea what to do?
Posted: Mon Feb 27, 2017 4:04 pm
by Sumie
hdarr03 wrote:I tried to install optifine with the same instructions that were listed (With the exception of the file from optifine being h6 instead of h3) but whenever I try to run it, it gives me this error message in the terminal
I believe your issue is the bolded above. It can't find the class, probably because the components have not been downloaded yet. This is due to not running Minecraft with Optifine installed 'normally'. Run it through the launcher normally and let it fail first. After which, close the launcher with the error message on it, then run the script.
It could also be that the script was modified incorrectly. Make sure the "OptiFineTweaker" object is not in the CP line (check to make sure there's a line break).
I have not tried running Minecraft with the new launcher they released recently. I hope it doesn't screw with this process... Maybe I will try it sometime this week.
Posted: Sat Mar 04, 2017 12:20 am
by hdarr03
I figured it out, I had the wrong version of optifine. It won't work with the newer version, you have to have the one that is specified in the post.
Posted: Sat Mar 04, 2017 5:35 pm
by Aircoookie
Hi, thank you for publishing this tutorial!
Sadly, it is not quite working on my Raspi 3.
When I try to run run.sh, it gives this error:
Error: Could not find or load main class net.minecraft.client.main.Main
The opengl drivers are active (glxgears works) and I've edited the launcher profile to version 1.8.9.
How can this be?
Posted: Mon Mar 06, 2017 12:33 am
by xXRoboBoyXx
Can someone help?? Im trying to connect to a 1.11.2 server but whenever i join this server: play.outsidercraft.net not sure if that helps but it tells me something like ¨invalid session (try restarting your game) Ive installed this and changed all of the settings but it just wont work! Can someone help me with this?
Posted: Mon Mar 06, 2017 8:57 am
by rpiMike
Have you tried run2.sh ?
You'll need to modify it for 1.11.2
Posted: Mon Mar 06, 2017 4:14 pm
by xXRoboBoyXx
rpiMike wrote:Have you tried run2.sh ?
Well i tryed that and it crashed my rpi but i think its cause i modified it wrong XP
Going to try modifying it another time and see if that works
Posted: Mon Mar 06, 2017 4:23 pm
by xXRoboBoyXx
well i tryed running the run2.sh file with everything edited correctly but now it gives me this STUPID error
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.anvil.hit
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.anvil.land
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.anvil.place
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.anvil.step
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.anvil.use
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.brewing_stand.brew
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.chest.close
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.chest.locked
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.chest.open
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.chorus_flower.death
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.chorus_flower.grow
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.cloth.break
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.cloth.fall
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.cloth.hit
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.cloth.place
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.cloth.step
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.comparator.click
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.dispenser.dispense
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.dispenser.fail
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.dispenser.launch
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.enchantment_table.use
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.end_gateway.spawn
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.enderchest.close
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.enderchest.open
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.fence_gate.close
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.fence_gate.open
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.fire.ambient
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.fire.extinguish
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.furnace.fire_crackle
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.glass.break
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.glass.fall
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.glass.hit
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.glass.place
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.glass.step
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.grass.break
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.grass.fall
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.grass.hit
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.grass.place
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.grass.step
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.gravel.break
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.gravel.fall
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.gravel.hit
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.gravel.place
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.gravel.step
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.iron_door.close
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.iron_door.open
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.iron_trapdoor.close
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.iron_trapdoor.open
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.ladder.break
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.ladder.fall
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.ladder.hit
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.ladder.place
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.ladder.step
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.lava.ambient
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.lava.extinguish
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.lava.pop
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.lever.click
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.metal.break
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.metal.fall
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.metal.hit
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.metal.place
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.metal.step
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.metal_pressureplate.click_off
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.metal_pressureplate.click_on
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.note.basedrum
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.note.bass
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.note.harp
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.note.hat
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.note.pling
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.note.snare
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.piston.contract
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.piston.extend
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.portal.ambient
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.portal.travel
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.portal.trigger
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.redstone_torch.burnout
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.sand.break
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.sand.fall
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.sand.hit
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.sand.place
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.sand.step
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.shulker_box.close
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.shulker_box.open
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.slime.break
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.slime.fall
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.slime.hit
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.slime.place
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.slime.step
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.snow.break
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.snow.fall
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.snow.hit
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.snow.place
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.snow.step
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.stone.break
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.stone.fall
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.stone.hit
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.stone.place
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.stone.step
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.stone_button.click_off
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.stone_button.click_on
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.stone_pressureplate.click_off
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.stone_pressureplate.click_on
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.tripwire.attach
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.tripwire.click_off
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.tripwire.click_on
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.tripwire.detach
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.water.ambient
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.waterlily.place
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.wood.break
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.wood.fall
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.wood.hit
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.wood.place
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.wood.step
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.wood_button.click_off
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.wood_button.click_on
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.wood_pressureplate.click_off
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.wood_pressureplate.click_on
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.wooden_door.close
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.wooden_door.open
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.wooden_trapdoor.close
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:block.wooden_trapdoor.open
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:enchant.thorns.hit
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.armorstand.break
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.armorstand.fall
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.armorstand.hit
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.armorstand.place
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.arrow.hit
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.arrow.hit_player
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.arrow.shoot
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.bat.ambient
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.bat.death
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.bat.hurt
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.bat.loop
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.bat.takeoff
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.blaze.ambient
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.blaze.burn
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.blaze.death
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.blaze.hurt
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.blaze.shoot
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.bobber.splash
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.bobber.throw
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.cat.ambient
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.cat.death
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.cat.hiss
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.cat.hurt
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.cat.purr
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.cat.purreow
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.chicken.ambient
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.chicken.death
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.chicken.egg
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.chicken.hurt
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.chicken.step
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.cow.ambient
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.cow.death
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.cow.hurt
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.cow.milk
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.cow.step
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.creeper.death
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.creeper.hurt
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.creeper.primed
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.donkey.ambient
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.donkey.angry
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.donkey.chest
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.donkey.death
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.donkey.hurt
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.egg.throw
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.elder_guardian.ambient
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.elder_guardian.ambient_land
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.elder_guardian.curse
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.elder_guardian.death
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.elder_guardian.death_land
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.elder_guardian.hurt
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.elder_guardian.flop
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.elder_guardian.hurt_land
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.enderdragon.ambient
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.enderdragon.death
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.enderdragon.flap
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.enderdragon.growl
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.enderdragon.hurt
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.enderdragon.shoot
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.enderdragon_fireball.explode
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.endereye.launch
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.endermen.ambient
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.endermen.death
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.endermen.hurt
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.endermen.scream
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.endermen.stare
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.endermen.teleport
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.endermite.ambient
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.endermite.death
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.endermite.hurt
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.endermite.step
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.enderpearl.throw
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.evocation_fangs.attack
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.evocation_illager.ambient
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.evocation_illager.cast_spell
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.evocation_illager.death
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.evocation_illager.hurt
[11:20:26] [Client thread/WARN]: Missing sound for event: minecraft:entity.evocation_illager.prepare_attack
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.evocation_illager.prepare_summon
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.evocation_illager.prepare_wololo
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.experience_bottle.throw
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.experience_orb.pickup
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.firework.blast
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.firework.blast_far
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.firework.large_blast
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.firework.large_blast_far
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.firework.launch
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.firework.shoot
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.firework.twinkle
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.firework.twinkle_far
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.generic.big_fall
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.generic.burn
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.generic.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.generic.drink
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.generic.eat
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.generic.explode
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.generic.extinguish_fire
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.generic.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.generic.small_fall
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.generic.splash
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.generic.swim
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.ghast.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.ghast.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.ghast.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.ghast.scream
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.ghast.shoot
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.ghast.warn
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.guardian.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.guardian.ambient_land
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.guardian.attack
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.guardian.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.guardian.death_land
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.guardian.flop
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.guardian.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.guardian.hurt_land
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.horse.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.horse.angry
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.horse.armor
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.horse.breathe
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.horse.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.horse.eat
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.horse.gallop
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.horse.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.horse.jump
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.horse.land
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.horse.saddle
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.horse.step
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.horse.step_wood
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.hostile.big_fall
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.hostile.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.hostile.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.hostile.small_fall
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.hostile.splash
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.hostile.swim
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.husk.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.husk.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.husk.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.husk.step
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.irongolem.attack
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.irongolem.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.irongolem.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.irongolem.step
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.item.break
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.item.pickup
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.itemframe.add_item
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.itemframe.break
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.itemframe.place
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.itemframe.remove_item
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.itemframe.rotate_item
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.leashknot.break
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.leashknot.place
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.lightning.impact
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.lightning.thunder
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.lingeringpotion.throw
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.llama.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.llama.angry
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.llama.chest
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.llama.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.llama.eat
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.llama.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.llama.spit
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.llama.step
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.llama.swag
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.magmacube.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.magmacube.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.magmacube.jump
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.magmacube.squish
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.minecart.inside
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.minecart.riding
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.mooshroom.shear
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.mule.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.mule.chest
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.mule.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.mule.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.painting.break
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.painting.place
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.pig.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.pig.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.pig.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.pig.saddle
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.pig.step
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.player.attack.crit
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.player.attack.knockback
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.player.attack.nodamage
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.player.attack.strong
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.player.attack.sweep
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.player.attack.weak
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.player.big_fall
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.player.breath
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.player.burp
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.player.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.player.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.player.levelup
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.player.small_fall
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.player.splash
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.player.swim
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.polar_bear.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.polar_bear.baby_ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.polar_bear.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.polar_bear.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.polar_bear.step
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.polar_bear.warning
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.rabbit.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.rabbit.attack
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.rabbit.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.rabbit.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.rabbit.jump
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.sheep.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.sheep.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.sheep.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.sheep.shear
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.sheep.step
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.shulker.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.shulker.close
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.shulker.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.shulker.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.shulker.hurt_closed
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.shulker.open
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.shulker.shoot
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.shulker.teleport
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.shulker_bullet.hit
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.shulker_bullet.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.silverfish.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.silverfish.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.silverfish.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.silverfish.step
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.skeleton.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.skeleton.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.skeleton.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.skeleton.shoot
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.skeleton.step
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.skeleton_horse.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.skeleton_horse.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.skeleton_horse.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.slime.attack
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.slime.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.slime.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.slime.jump
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.slime.squish
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.small_magmacube.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.small_magmacube.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.small_magmacube.squish
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.small_slime.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.small_slime.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.small_slime.jump
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.small_slime.squish
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.snowball.throw
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.snowman.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.snowman.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.snowman.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.snowman.shoot
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.spider.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.spider.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.spider.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.spider.step
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.splash_potion.break
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.splash_potion.throw
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.squid.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.squid.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.squid.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.stray.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.stray.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.stray.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.stray.step
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.tnt.primed
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.vex.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.vex.charge
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.vex.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.vex.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.villager.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.villager.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.villager.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.villager.no
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.villager.trading
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.villager.yes
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.vindication_illager.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.vindication_illager.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.vindication_illager.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.witch.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.witch.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.witch.drink
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.witch.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.witch.throw
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.wither.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.wither.break_block
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.wither.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.wither.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.wither.shoot
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.wither.spawn
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.wither_skeleton.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.wither_skeleton.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.wither_skeleton.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.wither_skeleton.step
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.wolf.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.wolf.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.wolf.growl
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.wolf.howl
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.wolf.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.wolf.pant
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.wolf.shake
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.wolf.step
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.wolf.whine
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie.attack_door_wood
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie.attack_iron_door
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie.break_door_wood
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie.infect
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie.step
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie_horse.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie_horse.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie_horse.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie_pig.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie_pig.angry
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie_pig.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie_pig.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie_villager.ambient
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie_villager.converted
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie_villager.cure
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie_villager.death
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie_villager.hurt
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:entity.zombie_villager.step
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.armor.equip_chain
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.armor.equip_diamond
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.armor.equip_elytra
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.armor.equip_generic
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.armor.equip_gold
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.armor.equip_iron
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.armor.equip_leather
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.bottle.empty
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.bottle.fill
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.bottle.fill_dragonbreath
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.bucket.empty
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.bucket.empty_lava
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.bucket.fill
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.bucket.fill_lava
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.chorus_fruit.teleport
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.elytra.flying
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.firecharge.use
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.flintandsteel.use
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.hoe.till
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.shield.block
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.shield.break
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.shovel.flatten
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:item.totem.use
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:music.creative
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:music.credits
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:music.dragon
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:music.end
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:music.game
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:music.menu
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:music.nether
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:record.11
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:record.13
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:record.blocks
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:record.cat
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:record.chirp
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:record.far
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:record.mall
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:record.mellohi
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:record.stal
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:record.strad
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:record.wait
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:record.ward
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:ui.button.click
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:weather.rain
[11:20:27] [Client thread/WARN]: Missing sound for event: minecraft:weather.rain.above
[11:20:27] [Sound Library Loader/INFO]: Starting up SoundSystem...
[11:20:27] [Thread-5/INFO]: Initializing LWJGL OpenAL
[11:20:27] [Thread-5/INFO]: (The LWJGL binding of OpenAL.  For more information, see http://www.lwjgl.org)
AL lib: (EE) oss_open_playback: Could not open /dev/dsp: No such file or directory
AL lib: (WW) alc_initconfig: Failed to initialize backend "pulse"
[11:20:27] [Thread-5/INFO]: OpenAL initialized.
[11:20:27] [Sound Library Loader/INFO]: Sound engine started
[11:20:35] [Client thread/INFO]: Created: 1024x512 textures-atlas
[11:20:53] [Server thread/INFO]: Starting integrated minecraft server version 1.11.2
[11:20:53] [Server thread/INFO]: Generating keypair
[11:20:54] [Server thread/ERROR]: Encountered an unexpected exception
java.lang.NoClassDefFoundError: it/unimi/dsi/fastutil/longs/Long2ObjectMap
	at mt.d(SourceFile:270) ~[1.11.2.jar:?]
	at lt.<init>(SourceFile:62) ~[1.11.2.jar:?]
	at lw.<init>(SourceFile:123) ~[1.11.2.jar:?]
	at cch.a(SourceFile:98) ~[1.11.2.jar:?]
	at cch.j(SourceFile:130) ~[1.11.2.jar:?]
	at net.minecraft.server.MinecraftServer.run(SourceFile:436) [1.11.2.jar:?]
	at java.lang.Thread.run(Thread.java:745) [?:1.8.0_65]
Caused by: java.lang.ClassNotFoundException: it.unimi.dsi.fastutil.longs.Long2ObjectMap
	at java.net.URLClassLoader.findClass(URLClassLoader.java:381) ~[?:1.8.0_65]
	at java.lang.ClassLoader.loadClass(ClassLoader.java:424) ~[?:1.8.0_65]
	at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:331) ~[?:1.8.0_65]
	at java.lang.ClassLoader.loadClass(ClassLoader.java:357) ~[?:1.8.0_65]
	... 7 more
[11:20:54] [Server thread/ERROR]: This crash report has been saved to: /home/pi/.minecraft/crash-reports/crash-2017-03-06_11.20.54-server.txt
[11:20:54] [Server thread/INFO]: Stopping server
[11:20:54] [Server thread/INFO]: Saving players
[11:20:54] [Server thread/INFO]: Saving worlds
If someone could help me with this that would help me a ton!
Posted: Tue Mar 07, 2017 3:27 pm
by Sumie
xXRoboBoyXx wrote:well i tryed running the run2.sh file with everything edited correctly but now it gives me this STUPID error
	... 7 more
You got me on this one...
It may be that you missed placing a .jar file in the CP line, or that it's referencing a .jar file that doesn't exist for some reason. Something that has to do with fastutil, which is supposed to be referenced in the CP line in the run script. Doublecheck it and make sure the reference is there.
Posted: Fri Mar 10, 2017 7:42 pm
by Sumie
Just tried installing fresh March update of Raspbian and went through all the Minecraft install steps, including Optifine OptiFine 1.11.2 HD U B7 and it still works just fine without a hitch. Just so everyone knows.
I may take all the work on the front page, and rewrite up the steps to getting it all working on another thread soon, and maintain that thread as new versions are released. We'll see if I want to put that much work into it...
