RaspiBasti
Re: How to setup Minecraft 1.8.9 on RaspPi2
Thu Mar 21, 2019 9:00 pm
Sindybad wrote:
Tue Mar 01, 2016 8:31 pm
I have worked out how to install the OptiFine mod :D
Runs on average at a good 20 frames per second :o
How to install the OptiFine mod for better performance:
Assuming you have completed the tutorial above(and installed Minecraft 1.8.9):
Go to http://optifine.net/downloads
And download “OptiFine 1.8.9 HD U H3”
Go to your downloads
cd ~/Downloads
And run optifine installer
java -jar OptiFine_1.8.9_HD_U_H3.jar
Click install.
Now launch Minecraft
cd ~/Minecraft
java -jar Minecraft.jar
Select the OptiFine profile and click play. The launcher will crash
Install asm:
cd ~/Minecraft
mkdir Libraries
cd Libraries
Download asm-5.0.4-bin.zip from http://forge.ow2.org/project/showfiles. ... se_id=5660
Move it to the Libraries folder
cd ~/Minecraft/Libraries
mv ~/Downloads/asm-5.0.4-bin.zip .
Unzip it
unzip asm-5.0.4-bin.zip
Now download my updated run.sh:
cd ~/Minecraft
wget https://www.dropbox.com/s/0r5trow18vi5vls/runOptifine.sh?dl=1 -O runOptifine.sh
Fill runOptifine.sh with your Minecraft login details
Edit MINECRAFT_LOGIN, MINECRAFT_USERNAME, MINECRAFT_PASSWORD and MINECRAFT_UUID:
nano runOptifine.sh
Change permissions of file:
chmod 700 runOptifine.sh
Now run it:
./runOptifine.sh
When Minecraft has launched, turn everything down to low in the video settings (and turn on things like fast math)
Close Minecraft(It might crash if you open a world now)
And relaunch it:
./runOptifine.sh
Thanks for reading!
P.S. rpiMike, you can include this in the original post if you want
I have two problems with it:
First: There is no "OptiFine_1.8.9_HD_U_H3.jar" just a "OptiFine_1.8.9_HD_U_I3.jar" but it doesnt work either.
Second: (I tried almost all 1.8.9 OptiFine jar's) When i run "runOptifine.sh" it gives me this error:
Error: Could not find or load main class net.minecraft.launchwrapper.Launch
So, i looked into the .sh file, but net.minecraft.launchwrapper.Launch is in it. I don't know how to fix this.
rpiMike
Fri Mar 22, 2019 3:22 pm
The very last paragraph of the 1.12.1 tutorial describes how to create a new classpath (cp=)
If you want to attempt getting a new version of Minecraft working :
1 Install required version using java -jar Minecraft.jar - and allow to crash
2 Scroll up in terminal window and find last ../jre/bin/java command, scroll across and find ‘-cp ’, copy this path list until ‘ net.minecraft.launchwrapper.Launch’
3 Paste this text into the cp= in the run.sh script
Gess1t
Fri Mar 22, 2019 11:45 pm
First, https://occycraft.blogspot.com/2016/02/ ... todos.html, there is apparently a version of optifine available, but i don't know if it's safe.
If you don't want to take risk,
Try replacing the content of your runoptifine.sh with this : https://pastebin.com/UhmaJ71K while keeping your optifine version which was 1.8.9 I3
don't forget to set your infos, email / username (it won't run without it, even if the launcher doesn't use it) / password.
btw, move optifine to the desktop to avoid permissions issues. Cause if you sudo when launching the optifine installer, then it will install in the root folder, or you will need to setup the permissions again manually + if you don't do this, and you try to sudo ./runoptifine.sh, then it won't work.
If this doesn't work, then re-download Minecraft 1.8.9 vanilla via the launcher and repeat all the steps again.
masterwhos
Thu Mar 28, 2019 7:16 pm
This is how you fixx "unsatisfied link" error so copy this into your run.sh but edit "email,name,password" to your minecraft login :D btw im postinng this on a pi 3 model b+ on chromium it lags
#!/bin/sh
# script to run minecraft on ARM linux. for reference:
# http://rogerallen.github.io/jetson/2014 ... etson-tk1/
# https://devtalk.nvidia.com/default/topi ... etson-tk1/
# https://gist.github.com/rogerallen/91526c9c8be1a82881e0
# !!! YOU MUST PERSONALIZE ALL OF THIS INFO !!!
# your personal login/password. chmod 700 to keep this private
MINECRAFT_LOGIN="email"
MINECRAFT_USERNAME="name"
MINECRAFT_PASSWORD="password"
# where did you store the native liblwjgl.so and libopenal.so?
MINECRAFT_NATIVE_PATH=~/Minecraft/Natives
# info from initial run data in .minecraft/launcher_profiles.json
MINECRAFT_CLIENTTOKEN=b61fb8e9-97bf-435f-8354-1feaba0ce734
MINECRAFT_UUID=12345678-1234-1234-1234-123456789abc
MINECRAFT_VERSION=1.8
# SHOULD NOT NEED TO EDIT BELOW THIS LINE
# long list of paths from the minecraft logged commandline
CP=/home/pi/.minecraft/libraries/oshi-project/oshi-core/1.1/oshi-core-1.1.jar:/home/pi/.minecraft/libraries/net/java/dev/jna/jna/3.4.0/jna-3.4.0.jar:/home/pi/.minecraft/libraries/net/java/dev/jna/platform/3.4.0/platform-3.4.0.jar:/home/pi/.minecraft/libraries/com/ibm/icu/icu4j-core-mojang/51.2/icu4j-core-mojang-51.2.jar:/home/pi/.minecraft/libraries/net/sf/jopt-simple/jopt-simple/4.6/jopt-simple-4.6.jar:/home/pi/.minecraft/libraries/com/paulscode/codecjorbis/20101023/codecjorbis-20101023.jar:/home/pi/.minecraft/libraries/com/paulscode/codecwav/20101023/codecwav-20101023.jar:/home/pi/.minecraft/libraries/com/paulscode/libraryjavasound/20101123/libraryjavasound-20101123.jar:/home/pi/.minecraft/libraries/com/paulscode/librarylwjglopenal/20100824/librarylwjglopenal-20100824.jar:/home/pi/.minecraft/libraries/com/paulscode/soundsystem/20120107/soundsystem-20120107.jar:/home/pi/.minecraft/libraries/io/netty/netty-all/4.0.23.Final/netty-all-4.0.23.Final.jar:/home/pi/.minecraft/libraries/com/google/guava/guava/17.0/guava-17.0.jar:/home/pi/.minecraft/libraries/org/apache/commons/commons-lang3/3.3.2/commons-lang3-3.3.2.jar:/home/pi/.minecraft/libraries/commons-io/commons-io/2.4/commons-io-2.4.jar:/home/pi/.minecraft/libraries/commons-codec/commons-codec/1.9/commons-codec-1.9.jar:/home/pi/.minecraft/libraries/net/java/jinput/jinput/2.0.5/jinput-2.0.5.jar:/home/pi/.minecraft/libraries/net/java/jutils/jutils/1.0.0/jutils-1.0.0.jar:/home/pi/.minecraft/libraries/com/google/code/gson/gson/2.2.4/gson-2.2.4.jar:/home/pi/.minecraft/libraries/com/mojang/authlib/1.5.21/authlib-1.5.21.jar:/home/pi/.minecraft/libraries/com/mojang/realms/1.7.59/realms-1.7.59.jar:/home/pi/.minecraft/libraries/org/apache/commons/commons-compress/1.8.1/commons-compress-1.8.1.jar:/home/pi/.minecraft/libraries/org/apache/httpcomponents/httpclient/4.3.3/httpclient-4.3.3.jar:/home/pi/.minecraft/libraries/commons-logging/commons-logging/1.1.3/commons-logging-1.1.3.jar:/home/pi/.minecraft/libraries/org/apache/httpcomponents/httpcore/4.3.2/httpcore-4.3.2.jar:/home/pi/.minecraft/libraries/org/apache/logging/log4j/log4j-api/2.0-beta9/log4j-api-2.0-beta9.jar:/home/pi/.minecraft/libraries/org/apache/logging/log4j/log4j-core/2.0-beta9/log4j-core-2.0-beta9.jar:/home/pi/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl/2.9.4-nightly-20150209/lwjgl-2.9.4-nightly-20150209.jar:/home/pi/.minecraft/libraries/org/lwjgl/lwjgl/lwjgl_util/2.9.4-nightly-20150209/lwjgl_util-2.9.4-nightly-20150209.jar:/home/pi/.minecraft/libraries/tv/twitch/twitch/6.5/twitch-6.5.jar:/home/pi/.minecraft/versions/1.8.9/1.8.9.jar
# thanks to xRoyx on the nvidia dev forums for this update.
# the authtoken changes daily, so we need to login to authenticate
MINECRAFT_ATOKEN="$(\
curl -i \
-H "Accept:application/json" \
-H "content-Type:application/json" \
https://authserver.mojang.com/authenticate \
-X POST \
--data '{"agent": {"name": "Minecraft","version": 1}, "username": "'$MINECRAFT_LOGIN'", "password": "'$MINECRAFT_PASSWORD'", "clientToken": "'$MINECRAFT_CLIENTTOKEN'" }' \
| sed '/accessToken":"/!d;s//&\n/;s/.*\n//;:a;/",/bb;$!{n;ba};:b;s//\n&/;P;D' \
echo "todays access token = "$MINECRAFT_ATOKEN
# run minecraft with all the right commandline options
/usr/lib/jvm/jdk-8-oracle-arm32-vfp-hflt/jre/bin/java \
-Xmn128M -Xmx1024M \
-XX:+UseConcMarkSweepGC \
-XX:+CMSIncrementalMode \
-XX:-UseAdaptiveSizePolicy \
-Djava.library.path=$MINECRAFT_NATIVE_PATH \
-cp $CP \
net.minecraft.client.main.Main \
--username $MINECRAFT_USERNAME \
--accessToken "$MINECRAFT_ATOKEN" \
--uuid "$MINECRAFT_UUID" \
--version $MINECRAFT_VERSION \
--userProperties {} \
--gameDir ~/.minecraft \
--assetsDir ~/.minecraft/assets \
--assetIndex $MINECRAFT_VERSION
Blackhawk_135
Sun May 05, 2019 6:43 am
Hi there, while your tutorial does work for the versions you have specified, I have founs that minecraft 1.7.10 won't work in any way, I have followed both of the tutorials and only following the 1.8.9 guide does minecraft 1.7.10 start, just to crash whenever I create a world, and I tried to join a friend's server but it won't detect it.
I have tried everything and I can't seem to get it to work properly.
Could you do a guide for this version specifically?
Or maybe you could install 1.7.10 version following your guide to see if it works for you.
Acituanbus
Thu Jun 20, 2019 7:54 am
When I try to run run.sh I got this error:
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 271 100 107 100 164 326 500 --:--:-- --:--:-- --:--:-- 501
Java HotSpot(TM) Client VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
Error: Could not find or load main class net.minecraft.client.main.Main
I then tried to redo steps 7b to 11 but not I get a "permission denied" error :/
Any idea what to do?
InnerFate
Sun Jul 07, 2019 2:49 am
Help
Bash: /run.sh: No such file or directory
rpiiceo
Sat Aug 03, 2019 9:02 am
so, something happend...
100   755  100   591  100   164    798    221 --:--:-- --:--:-- --:--:--  1020
todays access token = b71609dadf614b08bdcab8dc7d6204d5
./run.sh: 43: ./run.sh: /usr/lib/jvm/jdk-8-oracle-arm32-vfp-hflt/jre/bin/java: not found
and here is my run.sh file
#!/bin/sh
MINECRAFT_LOGIN=aaaa.bbbb@cccc
MINECRAFT_USERNAME=abcdefghi
MINECRAFT_PASSWORD=xxxxxxx
curl -i \
-X POST \
-cp $CP \
can you please help me?
jdonald
Sun Aug 04, 2019 2:37 am
Raspbian doesn't come with JDK 8 preinstalled anymore so the sequence outlined here won't work by itself.
Use the newer 1.12.2 instructions where the script downloads and unpacks Java 8 for you.
Pi Gamer
Tue Sep 03, 2019 12:49 am
I use Raspberry Pi 3b+ and i put my GPU memory on 128. I also skipped the GL driver thing because I realized it forced a 60FPS. When I skipped the GL driver thing, I rocked up to 220FPS. Try it out!!
FrostLlama
Fri Dec 20, 2019 2:58 am
well for some reason, the game never crashed, and now when I try to open file explorer (using desktop and sudo pcmanfm) and it immediately closes. Please help :(
necrobutok
Wed May 06, 2020 12:10 pm
i've got a problem where it says 'failed to login:invalid session (try restarting your game). i restarted game a ton of times, uninstalled and reinstalled it, restarted my rpi 3, it still says the same thing, i can't create a world in single player.
Eklika
Mon May 18, 2020 8:53 am
It's not working for me, I was also trying to download Minecraft from other sites and still nothing
rpiMike
Mon May 18, 2020 1:50 pm
Use a newer tutorial:
viewtopic.php?f=78&t=243946
SemiNerd
Wed Jul 15, 2020 10:22 pm
I can’t get Minecraft to run on Broadcom, wether GL is enabled or disabled, it says VMware when I press f3, the performance is manageable but it still hangs. And when OpenGL is enabled, the FPS drops about 2-3 frames
SemiNerd
Wed Jul 22, 2020 11:04 pm
I re-flashed the os and I did the full setup again but now the FPS in Minecraft has dropped to 0-2 frames and glxgears flickers and stays at 30 FPS
Toear
Fri Jul 31, 2020 1:20 pm
rpiMike have you gotten 1.8.9 working on a pi 4? :?:
I want to install it for combat servers but none of the tutorials work.
Return to “Gaming”
