Aloshi
Re: RetroPie Setup - Auto-installer/updater for RetroArch ga
Sat Oct 26, 2013 6:10 pm
If you're not actively playing games on it, that should be possible. The front-end, EmulationStation, is a little CPU hungry, but if you leave it idle for 30 seconds (by default) it will go into "sleep mode" and leave most of the CPU free.
Sato
Sat Oct 26, 2013 6:20 pm
Aloshi wrote:If you're not actively playing games on it, that should be possible. The front-end, EmulationStation, is a little CPU hungry, but if you leave it idle for 30 seconds (by default) it will go into "sleep mode" and leave most of the CPU free.
Cool, so if I were to set it up so that the web server would begin to run, then have EmulationStation start, it should work?
Sato
Sun Oct 27, 2013 10:49 am
I'm getting an error that retroarch fails to compile/install, along with some of the cores (but I'll ignore them for now). Any idea on what the problem could be? Everything else works fine. Here's the debug.log:
RetroArch files:
/usr/local/bin/retroarch does NOT exist.
/usr/local/bin/retroarch-zip does NOT exist.
-rw-r--r-- 1 pi pi 18K Oct 27 10:20 /home/pi/RetroPie/configs/all/retroarch.cfg
Active lines in /home/pi/RetroPie/configs/all/retroarch.cfg:
system_directory = /home/pi/RetroPie/emulatorcores/
video_smooth = false
video_aspect_ratio = 1.33
audio_out_rate = 48000
audio_driver = alsathread
input_player1_a = x
input_player1_b = z
input_player1_y = a
input_player1_x = s
input_player1_start = enter
input_player1_select = rshift
input_player1_l = q
input_player1_r = w
input_player1_left = left
input_player1_right = right
input_player1_up = up
input_player1_down = down
input_exit_emulator = escape
input_rewind = r
rewind_enable = true
rewind_buffer_size = 10
rewind_granularity = 2
Emulation Station files:
-rwxr-xr-x 1 pi pi 564K Oct 27 09:31 /home/pi/RetroPie/supplementary/EmulationStation/emulationstation
-rw-r--r-- 1 pi pi 9.5K Oct 27 09:56 /home/pi/RetroPie/../.emulationstation/es_systems.cfg
/home/pi/RetroPie/../.emulationstation/es_input.cfg does NOT exist.
Content of es_systems.cfg:
DESCNAME=Apple ][
NAME=apple2
PATH=/home/pi/RetroPie/roms/apple2
EXTENSION=.txt
COMMAND=/home/pi/RetroPie/emulators/linapple-src_2a/Start.sh
DESCNAME=Atari 800
NAME=atari800
PATH=/home/pi/RetroPie/roms/atari800
EXTENSION=.xex .XEX
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 1 "/home/pi/RetroPie/emulators/atari800-3.0.0/installdir/bin/atari800 %ROM%"
PLATFORMID=22
DESCNAME=Atari 2600
NAME=atari2600
PATH=/home/pi/RetroPie/roms/atari2600
EXTENSION=.a26 .A26 .bin .BIN .rom .ROM .zip .ZIP .gz .GZ
#alternatively: COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 1 "stella %ROM%"
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 1 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/stella-libretro/stella_libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/atari2600/retroarch.cfg  %ROM%"
PLATFORMID=22
DESCNAME=Atari ST/STE/Falcon
NAME=atariStSteFalcon
PATH=/home/pi/RetroPie/roms/atariStSteFalcon
EXTENSION=.st .ST .img .IMG .rom .ROM
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 1 "hatari %ROM%"
DESCNAME=Basilisk II
NAME=basiliskii
PATH=/home/pi/RetroPie/roms/basiliskii
EXTENSION=.txt
COMMAND=sudo modprobe snd_pcm_oss && xinit /home/pi/RetroPie/emulators/basiliskii/installdir/bin/BasiliskII
# Or possibly just COMMAND=xinit /home/pi/RetroPie/emulators/basiliskii/installdir/bin/BasiliskII
DESCNAME=Cave Story
NAME=cavestory
PATH=/home/pi/RetroPie/roms/cavestory
EXTENSION=.txt
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 1 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/nxengine-libretro/nxengine_libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/cavestory/retroarch.cfg /home/pi/RetroPie/emulatorcores/nxengine-libretro/datafiles/Doukutsu.exe"
DESCNAME=C64
NAME=c64
PATH=/home/pi/RetroPie/roms/c64
EXTENSION=.crt .CRT .d64 .D64 .g64 .G64 .t64 .T64 .tap .TAP .x64 .X64 .zip .ZIP
COMMAND=/home/pi/RetroPie/emulators/vice-2.3.dfsg/installdir/bin/x64 %ROM%
PLATFORMID=40
DESCNAME=Doom
NAME=doom
PATH=/home/pi/RetroPie/roms/doom
EXTENSION=.WAD .wad
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 1 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/libretro-prboom/prboom_libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/doom/retroarch.cfg %ROM%"
PLATFORMID=1
DESCNAME=Duke Nukem 3D
NAME=duke3d
PATH=/home/pi/RetroPie/roms/duke3d
EXTENSION=.grp .GRP
COMMAND=eduke32 -g %ROM% -gamegrp %ROM%
PLATFORMID=1
DESCNAME=Game Boy
NAME=gb
PATH=/home/pi/RetroPie/roms/gb
EXTENSION=.gb .GB
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 1 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/gambatte-libretro/libgambatte/gambatte_libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/gb/retroarch.cfg %ROM%"
PLATFORMID=4
DESCNAME=Game Boy Advance
NAME=gba
PATH=/home/pi/RetroPie/roms/gba
EXTENSION=.gba .GBA
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 1 "/home/pi/RetroPie/emulators/gpsp/raspberrypi/gpsp %ROM%"
PLATFORMID=5
DESCNAME=Game Boy Color
NAME=gbc
PATH=/home/pi/RetroPie/roms/gbc
EXTENSION=.gbc .GBC
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 1 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/gambatte-libretro/libgambatte/gambatte_libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/gbc/retroarch.cfg %ROM%"
PLATFORMID=41
DESCNAME=Sega Game Gear
NAME=gamegear
PATH=/home/pi/RetroPie/roms/gamegear
EXTENSION=.gg .GG
COMMAND=/home/pi/RetroPie/emulators/osmose-0.8.1+rpi20121122/osmose %ROM% -joy -tv -fs
PLATFORMID=20
DESCNAME=Intellivision
NAME=intellivision
PATH=/home/pi/RetroPie/roms/intellivision
EXTENSION=.int .INT .bin .BIN
COMMAND=/home/pi/RetroPie/emulators/jzintv-1.0-beta4/bin/jzintv -z1 -f1 -q %ROM%
PLATFORMID=32
DESCNAME=MAME
NAME=mame
PATH=/home/pi/RetroPie/roms/mame
EXTENSION=.zip .ZIP
COMMAND=/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/imame4all-libretro/libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/mame/retroarch.cfg %ROM%
# alternatively: COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 1 "/home/pi/RetroPie/emulators/pifba/fba2x %ROM%"
PLATFORMID=23
DESCNAME=FinalBurn Alpha
NAME=fba
PATH=/home/pi/RetroPie/roms/fba
EXTENSION=.zip .ZIP
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 1 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/fba-libretro/fb_alpha_libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/fba/retroarch.cfg  %ROM%"
PLATFORMID=23
DESCNAME=PC (x86)
NAME=x86
PATH=/home/pi/RetroPie/roms/x86
EXTENSION=.txt
COMMAND=/home/pi/RetroPie/emulators/rpix86/Start.sh
PLATFORMID=1
DESCNAME=ScummVM
NAME=scummvm
PATH=/home/pi/RetroPie/roms/scummvm
EXTENSION=.exe .EXE
COMMAND=scummvm
PLATFORMID=20
DESCNAME=Sega Master System II
NAME=mastersystem
PATH=/home/pi/RetroPie/roms/mastersystem
EXTENSION=.sms .SMS
PLATFORMID=35
DESCNAME=Sega Mega Drive / Genesis
NAME=megadrive
PATH=/home/pi/RetroPie/roms/megadrive
EXTENSION=.smd .SMD .bin .BIN
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 1 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/picodrive/picodrive_libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/megadrive/retroarch.cfg  %ROM%"
# alternatively: COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 1 "/home/pi/RetroPie/emulators/dgen-sdl/dgen -f -r /home/pi/RetroPie/configs/all/dgenrc %ROM%"
# alternatively: COMMAND=export LD_LIBRARY_PATH="/home/pi/RetroPie/supplementary/dispmanx/SDL12-kms-dispmanx/build/.libs"; /home/pi/RetroPie/emulators/dgen-sdl/dgen %ROM%
PLATFORMID=18
DESCNAME=NeoGeo
NAME=neogeo
PATH=/home/pi/RetroPie/roms/neogeo
EXTENSION=.zip .ZIP
COMMAND=/home/pi/RetroPie/emulators/gngeo-pi-0.85/installdir/bin/arm-linux-gngeo -i /home/pi/RetroPie/roms/neogeo -B /home/pi/RetroPie/emulators/gngeo-pi-0.85/neogeobios %ROM%
PLATFORMID=24
DESCNAME=Nintendo Entertainment System
NAME=nes
PATH=/home/pi/RetroPie/roms/nes
EXTENSION=.nes .NES
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 1 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/fceu-next/fceumm-code/fceumm_libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/nes/retroarch.cfg  %ROM%"
PLATFORMID=7
DESCNAME=Nintendo 64
NAME=nes
PATH=/home/pi/RetroPie/roms/n64
EXTENSION=.z64 .ZE64
COMMAND=/home/pi/RetroPie/emulators/mupen64plus-rpi/test/mupen64plus --configdir /home/pi/RetroPie/emulators/mupen64plus-rpi/ --corelib /home/pi/RetroPie/emulators/mupen64plus-rpi/test/libmupen64plus.so.2.0.0 %ROM%
PLATFORMID=3
DESCNAME=PC Engine/TurboGrafx 16
NAME=pcengine
PATH=/home/pi/RetroPie/roms/pcengine
EXTENSION=.pce
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 1 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/mednafen-pce-libretro/libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/pcengine/retroarch.cfg %ROM%"
PLATFORMID=34
DESCNAME=Sony Playstation 1
NAME=psx
PATH=/home/pi/RetroPie/roms/psx
EXTENSION=.img .IMG .7z .7Z .pbp .PBP .bin .BIN
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 1 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L  --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/psx/retroarch.cfg %ROM%"
PLATFORMID=10
DESCNAME=Playstation Portable
NAME=psp
PATH=/home/pi/RetroPie/roms/psp
EXTENSION=.iso .ISO .cso .CSO
COMMAND=/home/pi/RetroPie/emulators/ppsspp/PPSSPPSDL %ROM% en
PLATFORMID=13
DESCNAME=Super Nintendo
NAME=snes
PATH=/home/pi/RetroPie/roms/snes
EXTENSION=.smc .sfc .fig .swc .SMC .SFC .FIG .SWC
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 1 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/pocketsnes-libretro/libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/snes/retroarch.cfg  %ROM%"
# alternatively: COMMAND=/home/pi/RetroPie/emulators/snes9x-rpi/snes9x %ROM%
# alternatively: COMMAND=/home/pi/RetroPie/emulators/pisnes/snes9x %ROM%
PLATFORMID=6
DESCNAME=ZX Spectrum
NAME=zxspectrum
PATH=/home/pi/RetroPie/roms/zxspectrum
EXTENSION=.z80 .Z80
COMMAND=xinit fuse
# alternatively: COMMAND=/home/pi/RetroPie/emulators/fbzx-2.10.0/fbzx %ROM%
DESCNAME=Input Configuration
NAME=esconfig
PATH=/home/pi/RetroPie/roms/esconfig
EXTENSION=.sh .SH
COMMAND=/home/pi/RetroPie/roms/esconfig/Start.sh
Content of es_input.cfg:
Emulators and cores:
-rwxr-xr-x 1 pi pi 812K Oct 27 05:47 /home/pi/RetroPie/emulatorcores/fceu-next/fceumm-code/fceumm_libretro.so
-rwxr-xr-x 1 pi pi 806K Oct 26 17:59 /home/pi/RetroPie/emulatorcores/libretro-prboom/prboom_libretro.so
-rw-r--r-- 1 pi pi 310K Oct 26 17:50 /home/pi/RetroPie/emulatorcores/libretro-prboom/prboom.wad
-rwxr-xr-x 1 pi pi 1.5M Oct 26 15:48 /home/pi/RetroPie/emulatorcores/stella-libretro/stella_libretro.so
-rwxr-xr-x 1 pi pi 949K Oct 26 17:50 /home/pi/RetroPie/emulatorcores/nxengine-libretro/nxengine_libretro.so
-rwxr-xr-x 1 pi pi 312K Oct 26 18:13 /home/pi/RetroPie/emulatorcores/gambatte-libretro/libgambatte/gambatte_libretro.so
-rwxr-xr-x 1 pi pi 3.1M Oct 27 04:53 /home/pi/RetroPie/emulatorcores/Genesis-Plus-GX/genesis_plus_gx_libretro.so
-rwxr-xr-x 1 pi pi 21M Oct 27 03:07 /home/pi/RetroPie/emulatorcores/fba-libretro/fb_alpha_libretro.so
 does NOT exist.
-rwxr-xr-x 1 pi pi 3.4M Oct 27 07:50 /home/pi/RetroPie/emulatorcores/mednafen-pce-libretro/libretro.so
-rwxr-xr-x 1 pi pi 970K Oct 27 08:18 /home/pi/RetroPie/emulatorcores/pocketsnes-libretro/libretro.so
-rwxr-xr-x 1 pi pi 1.1M Oct 26 15:19 /home/pi/RetroPie/emulators/uae4rpi/uae4all
SNESDev:
/home/pi/RetroPie/supplementary/SNESDev-Rpi/bin/SNESDev does NOT exist.
Summary of ROMS directory:
4.0K	/home/pi/RetroPie/roms/psx
4.0K	/home/pi/RetroPie/roms/mastersystem
316K	/home/pi/RetroPie/roms/doom
4.0K	/home/pi/RetroPie/roms/zxspectrum
4.0K	/home/pi/RetroPie/roms/neogeo
4.0K	/home/pi/RetroPie/roms/x86
4.0K	/home/pi/RetroPie/roms/c64
4.0K	/home/pi/RetroPie/roms/scummvm
4.0K	/home/pi/RetroPie/roms/cavestory
468K	/home/pi/RetroPie/roms/zmachine
11M	/home/pi/RetroPie/roms/duke3d
4.0K	/home/pi/RetroPie/roms/esconfig
4.0K	/home/pi/RetroPie/roms/gamegear
4.0K	/home/pi/RetroPie/roms/basiliskii
4.0K	/home/pi/RetroPie/roms/gbc
4.0K	/home/pi/RetroPie/roms/nes
4.0K	/home/pi/RetroPie/roms/atariStSteFalcon
4.0K	/home/pi/RetroPie/roms/mame
772K	/home/pi/RetroPie/roms/megadrive
4.0K	/home/pi/RetroPie/roms/psp
4.0K	/home/pi/RetroPie/roms/snes
4.0K	/home/pi/RetroPie/roms/pcengine
4.0K	/home/pi/RetroPie/roms/atari800
4.0K	/home/pi/RetroPie/roms/fba
4.0K	/home/pi/RetroPie/roms/n64
4.0K	/home/pi/RetroPie/roms/intellivision
4.0K	/home/pi/RetroPie/roms/apple2
4.0K	/home/pi/RetroPie/roms/atari2600
4.0K	/home/pi/RetroPie/roms/gba
4.0K	/home/pi/RetroPie/roms/amiga
13M	/home/pi/RetroPie/roms/
13M	total
Unrecognized ROM extensions:
/home/pi/RetroPie/roms/megadrive/projmd-20120429.bin
Check for needed APT packages:
Checking for somelib: install ok installed
installed: libsdl1.2-dev
installed: screen
installed: scons
installed: libasound2-dev
installed: pkg-config
installed: libgtk2.0-dev
installed: libboost-filesystem-dev
installed: libboost-system-dev
installed: zip
installed: libxml2
installed: libxml2-dev
installed: libbz2-dev
installed: python-imaging
installed: libfreeimage-dev
installed: libfreetype6-dev
installed: libaudiofile-dev
installed: libsdl-sound1.2-dev
installed: libsdl-mixer1.2-dev
End of log file
Other things that failed to install are the N64 Core, PPSSPP and one other that I'm afraid I forgot. Any ideas?
Sato
Sun Oct 27, 2013 8:33 pm
Okay, I managed to get most things working. Only problem I'm now having is the PSX core, N64 core and PPSSPP core failing to compile. I get the following output when trying to directly compile the PSX core:
plugins/dfsound/out.o: In function `SetupSound':
/home/pi/RetroPie/emulatorcores/pcsx_rearmed/plugins/dfsound/out.c:34: undefined reference to `out_register_libretro'
collect2: ld returned 1 exit status
make: *** [pcsx] Error 1
And here's the log file for when I try and install through the RetroPie-Setup Installer:
RetroArch files:
-rw-r--r-- 1 pi pi 19K Oct 27 17:17 /home/pi/RetroPie/configs/all/retroarch.cfg
 savefile_directory = /home/pi/RetroPie/saves
 savestate_directory = /home/pi/RetroPie/states
 video_driver = "gl"
 video_fullscreen_x = 1920
 video_fullscreen_y = 1080
 video_fullscreen = true
 video_force_aspect = true
video_aspect_ratio = 1.25
audio_driver = alsa
input_player1_a = x
input_player1_b = z
input_player1_y = a
input_player1_x = s
input_player1_l = q
input_player1_r = w
input_rewind = r
 autosave_interval = 5
input_player1_joypad_index = "0"
input_player1_b_btn = "2"
input_player1_y_btn = "3"
input_player1_select_btn = "8"
input_player1_start_btn = "9"
input_player1_up_axis = "-6"
input_player1_down_axis = "+6"
input_player1_left_axis = "-5"
input_player1_right_axis = "+5"
input_player1_a_btn = "1"
input_player1_x_btn = "0"
input_player1_l_btn = "6"
input_player1_r_btn = "7"
input_player1_l2_btn = "4"
input_player1_r2_btn = "5"
input_player1_l3_btn = "10"
input_player1_r3_btn = "11"
input_player1_l_x_plus_axis = "+0"
input_player1_l_x_minus_axis = "-0"
input_player1_l_y_plus_axis = "+1"
input_player1_l_y_minus_axis = "-1"
input_player1_r_x_plus_axis = "+4"
input_player1_r_x_minus_axis = "-4"
input_player1_r_y_plus_axis = "+3"
input_player1_r_y_minus_axis = "-3"
input_enable_hotkey_btn = "8"
input_exit_emulator_btn = "9"
-rw-r--r-- 1 pi pi 9.2K Oct 27 18:50 /home/pi/RetroPie/../.emulationstation/es_systems.cfg
-rw-r--r-- 1 pi pi 635 Oct 27 16:23 /home/pi/RetroPie/../.emulationstation/es_input.cfg
#DESCNAME=Apple ][
#NAME=apple2
#PATH=/home/pi/RetroPie/roms/apple2
#EXTENSION=.txt
#COMMAND=/home/pi/RetroPie/emulators/linapple-src_2a/Start.sh
DESCNAME=Atari 800
NAME=atari800
EXTENSION=.xex .XEX
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 2 "/home/pi/RetroPie/emulators/atari800-3.0.0/installdir/bin/atari800 %ROM%"
PLATFORMID=22
DESCNAME=Atari 2600
NAME=atari2600
#alternatively: COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 2 "stella %ROM%"
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 2 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/stella-libretro/stella_libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/atari2600/retroarch.cfg  %ROM%"
PLATFORMID=22
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 2 "hatari %ROM%"
#DESCNAME=Basilisk II
#NAME=basiliskii
#PATH=/home/pi/RetroPie/roms/basiliskii
#EXTENSION=.txt
#COMMAND=sudo modprobe snd_pcm_oss && xinit /home/pi/RetroPie/emulators/basiliskii/installdir/bin/BasiliskII
DESCNAME=Cave Story
NAME=cavestory
EXTENSION=.txt
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 2 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/nxengine-libretro/nxengine_libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/cavestory/retroarch.cfg /home/pi/RetroPie/emulatorcores/nxengine-libretro/datafiles/Doukutsu.exe"
DESCNAME=C64
NAME=c64
PLATFORMID=40
DESCNAME=Doom
NAME=doom
EXTENSION=.WAD .wad
COMMAND=chocolate-doom -iwad %ROM%
PLATFORMID=1
NAME=duke3d
EXTENSION=.grp .GRP
PLATFORMID=1
DESCNAME=Game Boy
NAME=gb
EXTENSION=.gb .GB
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 2 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/gambatte-libretro/libgambatte/gambatte_libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/gb/retroarch.cfg %ROM%"
PLATFORMID=4
NAME=gba
EXTENSION=.gba .GBA
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 2 "/home/pi/RetroPie/emulators/gpsp/raspberrypi/gpsp %ROM%"
PLATFORMID=5
NAME=gbc
EXTENSION=.gbc .GBC
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 2 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/gambatte-libretro/libgambatte/gambatte_libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/gbc/retroarch.cfg %ROM%"
PLATFORMID=41
NAME=gamegear
EXTENSION=.gg .GG
PLATFORMID=20
NAME=intellivision
PLATFORMID=32
DESCNAME=MAME
NAME=mame
EXTENSION=.zip .ZIP
# alternatively: COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 2 "/home/pi/RetroPie/emulators/pifba/fba2x %ROM%"
PLATFORMID=23
NAME=fba
EXTENSION=.zip .ZIP
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 2 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/fba-libretro/fb_alpha_libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/fba/retroarch.cfg  %ROM%"
PLATFORMID=23
#DESCNAME=PC (x86)
#NAME=x86
#PATH=/home/pi/RetroPie/roms/x86
#EXTENSION=.txt
#COMMAND=/home/pi/RetroPie/emulators/rpix86/Start.sh
#PLATFORMID=1
DESCNAME=ScummVM
NAME=scummvm
EXTENSION=.exe .EXE
COMMAND=scummvm
PLATFORMID=20
NAME=mastersystem
EXTENSION=.sms .SMS
PLATFORMID=35
NAME=megadrive
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 2 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/picodrive/picodrive_libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/megadrive/retroarch.cfg  %ROM%"
# alternatively: COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 2 "/home/pi/RetroPie/emulators/dgen-sdl/dgen -f -r /home/pi/RetroPie/configs/all/dgenrc %ROM%"
PLATFORMID=18
DESCNAME=NeoGeo
NAME=neogeo
EXTENSION=.zip .ZIP
PLATFORMID=24
NAME=nes
EXTENSION=.nes .NES
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 2 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/fceu-next/fceumm-code/fceumm_libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/nes/retroarch.cfg  %ROM%"
PLATFORMID=7
NAME=nes
PLATFORMID=3
NAME=pcengine
EXTENSION=.pce
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 2 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/mednafen-pce-libretro/libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/pcengine/retroarch.cfg %ROM%"
PLATFORMID=34
NAME=psx
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 2 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L  --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/psx/retroarch.cfg %ROM%"
PLATFORMID=10
NAME=psp
PLATFORMID=13
NAME=snes
COMMAND=/home/pi/RetroPie/supplementary/runcommand/runcommand.sh 2 "/home/pi/RetroPie/emulators/RetroArch/installdir/bin/retroarch -L /home/pi/RetroPie/emulatorcores/pocketsnes-libretro/libretro.so --config /home/pi/RetroPie/configs/all/retroarch.cfg --appendconfig /home/pi/RetroPie/configs/snes/retroarch.cfg  %ROM%"
PLATFORMID=6
NAME=zxspectrum
EXTENSION=.z80 .Z80
COMMAND=xinit fuse
#DESCNAME=Input Configuration
#NAME=esconfig
#PATH=/home/pi/RetroPie/roms/esconfig
#EXTENSION=.sh .SH
#COMMAND=/home/pi/RetroPie/roms/esconfig/Start.sh
<?xml version="1.0"?>
<inputList>
	<inputConfig type="keyboard" />
	<inputConfig type="joystick" deviceName="USB Gamepad ">
		<input name="a" type="button" id="2" value="1" />
		<input name="b" type="button" id="1" value="1" />
		<input name="down" type="hat" id="0" value="4" />
		<input name="left" type="hat" id="0" value="8" />
		<input name="menu" type="button" id="9" value="1" />
		<input name="pagedown" type="button" id="7" value="1" />
		<input name="pageup" type="button" id="6" value="1" />
		<input name="right" type="hat" id="0" value="2" />
		<input name="up" type="hat" id="0" value="1" />
	</inputConfig>
</inputList>
 does NOT exist.
SNESDev:
241M	/home/pi/RetroPie/roms/psx
26M	/home/pi/RetroPie/roms/doom
168K	/home/pi/RetroPie/roms/nes
2.1M	/home/pi/RetroPie/roms/megadrive
4.1M	/home/pi/RetroPie/roms/snes
14M	/home/pi/RetroPie/roms/gb
298M	/home/pi/RetroPie/roms/
298M	total
/home/pi/RetroPie/roms/megadrive/Mega Man - The Wily Wars.bin
/home/pi/RetroPie/roms/megadrive/Mega Man - The Wily Wars.srm
/home/pi/RetroPie/roms/megadrive/Mega Man - The Wily Wars.jpeg
/home/pi/RetroPie/roms/nes/Mega Man.jpeg
/home/pi/RetroPie/roms/psx/Gran Turismo 2 [Simulation Mode] [SCUS 94488].bin
/home/pi/RetroPie/roms/psx/Gran Turismo 2 [Simulation Mode] [SCUS 94488].jpeg
/home/pi/RetroPie/roms/psx/scph1001.bin
/home/pi/RetroPie/roms/snes/Chrono Trigger.jpeg
installed: screen
installed: scons
installed: zip
installed: libxml2
End of log file
Any ideas on what the problem is, or how to fix it?
petrockblog
Tue Oct 29, 2013 6:34 am
I know that the PPSSPP emulator is currently making problems and I do not know a solution to make it compile myself. The other emulators should work. I need to have a look into that this evening.
fun stuff for technics enthusiasts: www.petrockblock.com
smartroad
Tue Oct 29, 2013 10:03 am
I am having issues comiling the N64 core, I noticed this post:
http://www.raspberrypi.org/phpBB3/viewt ... ie#p437668
The problem for that issue is the lack of RAM for the comilation. I have an idea that if I allocated for RAM to for compilation to the CPU and maybe see about increasing the size of the SWAP that it might improve the chance of compilation.
Is this a good/bad idea?
welshy
Tue Oct 29, 2013 10:45 am
smartroad
Mupen64plusRpi should compile on a 256MEG Rpi with no 'Swap file' so long as a MAXIMUM of 64MEG is applied to the GPU. If in doubt, just apply 16MEG the GPU then reset to your usual settings when the compile is completed.
See Here - http://www.raspberrypi.org/phpBB3/viewt ... 78&t=58395
"The list of things I have heard now contains everything!"
Sato
Tue Oct 29, 2013 11:12 am
petrockblog wrote:I know that the PPSSPP emulator is currently making problems and I do not know a solution to make it compile myself. The other emulators should work. I need to have a look into that this evening.
Okay, thanks :)
gilbdeth
Wed Nov 20, 2013 5:38 pm
hi i installed and setup retropie months ago and it always bugged me that the text in emulation station was really blocky and crap but never thought anymore about it, until i saw a screen cap on aloshi's github page of a lot nicer text
anyone have any ideas what i did wrong or what i can do to fix this?
KitchUK
Thu Nov 21, 2013 8:22 am
gilbdeth wrote:hi i installed and setup retropie months ago and it always bugged me that the text in emulation station was really blocky and crap but never thought anymore about it, until i saw a screen cap on aloshi's github page of a lot nicer text
You can simply go into the system theme file in home/pi/.emulationstation (its a hidden foleder) then open up the xml file that corresponds to that particular system. Once open you should see a section mentioning fonts. Just delete that section and the font you see on Aloshi's website will be shown instead of the retro blocky one.
If you want you could also place you own font .tff file onto the pi and then use any font you wish! :D
plciula
SD Card Issues/Fills up too fast
Sat Nov 23, 2013 1:00 am
I installed RetroPie 1.8.1 on a 16GB Class 4 SD card. When I fill it up with about 1GB of roms, the SSH program I'm using(WinSCP), tells me it can't copy because of an unforeseen error. When I go into the command line to check the total storage ("df -h") it tells me its 100% full. Can anybody help me solve this? Btw, I am completely new to anything linux, so I would ask that anyone clearly specify commands and instructions. Thanks in advanced!!
KitchUK
Re: SD Card Issues/Fills up too fast
Sat Nov 23, 2013 11:18 am
plciula wrote:I installed RetroPie 1.8.1 on a 16GB Class 4 SD card. When I fill it up with about 1GB of roms, the SSH program I'm using(WinSCP), tells me it can't copy because of an unforeseen error. When I go into the command line to check the total storage ("df -h") it tells me its 100% full. Can anybody help me solve this? Btw, I am completely new to anything linux, so I would ask that anyone clearly specify commands and instructions. Thanks in advanced!!
Have you expanded the file system? On the command line type sudo raspi-config then once the script is up select 'expand file system'.
zziggy
Mon Nov 25, 2013 12:30 am
I am unable to hear any audio output.
The strangest thing happened. I couldn't get my video to display (HDMI) for the longest time, but I could hear the audio in game (theme music, etc). I eventually changed the '1' to '2' in the es_system file for each emulator and the video finally displayed for each rom. Yay! But in this process, I pulled out my TV so I could reach an ethernet cord with my Pi. When I put the TV back and rehooked up the system, my audio would not work in or out of game (eg. playing wav files).
The problem is not the TV. I can use HDMI with my laptop or other device to play video and audio still. It appears that the fact that I moved my TV has nothing to do with the issue I'm having, and something went screwy while I was playing with video settings.
But so far I've tried:
- Rewriting RetroPie image, starting from scratch. Nothing.
- Tweaking boot config.txt settings. Although I could be missing something.
- Tweaking retroarch config. But that shouldn't prevent me from hearing audio files playing from the cmdline.
What do I do? I've been stuck on this for days now. I can post my current config if necessary.
plciula
Mon Nov 25, 2013 4:12 am
Thanks a bunch! That did fix it.
gilbdeth
Wed Dec 04, 2013 8:35 pm
Hi
I added some roms to the megadrive on my RetroPie setup yesterday and then updated the gamelist
now the gameslist doesn't load it just deafults to the list of files in the rom dir...
i have done this countless times while setting everything up and never had a problem before
I did recently do "sudo apt-get update" and "sudo apt-get upgrade" to get my system to work on another rpi
but it was fine until I updated the gamelist.xml file
anyone got any ideas what ive done wrong?
the 2 games i added with there entrys to the gamelist
<game>
    <path>/home/pi/RetroPie/roms/megadrive/Desert Strike - Return to the Gulf (U) [!].bin</path>
    <name>Desert Strike</name>
    <desc />
    <image/home/pi/RetroPie/roms/megadrive/Desert_Strike.png/>
    <releasedate />
    <publisher />
    <developer />
    <genres />
  </game>
  <game>
    <path>/home/pi/RetroPie/roms/megadrive/Urban Strike (UEJ) [!].bin</path>
    <name>Urban Strike</name>
    <desc />
    <image/home/pi/RetroPie/roms/megadrive/urbanstrike.jpg/>
    <releasedate />
    <publisher />
    <developer />
    <genres />
  </game>
Aloshi
Fri Dec 06, 2013 2:07 am
Your formatting not valid XML.
should be
<image>/home/pi/RetroPie/roms/megadrive/Desert_Strike.png</image>
(and similar for the other one)
Lexusjjss
Tue Dec 10, 2013 1:45 am
Quick question just to be sure, compiling/installing just Mupen64 via source-based installation in the setup script shouldn't affect my tweaked config files/other emulators?
petrockblog
Tue Dec 10, 2013 6:15 am
Lexusjjss wrote:Quick question just to be sure, compiling/installing just Mupen64 via source-based installation in the setup script shouldn't affect my tweaked config files/other emulators?
If you select only Mupen 64 RPi in the RetroPie Setup Script, you can find the exact actions of the script at https://github.com/petrockblog/RetroPie ... shinc#L468. As an answer to your questions: no other config files will be touched. Generally, though, it might be a good idea to backup your tweaked files, if you spent a considerable amount of time with it.
ceterumnet
Sun Dec 22, 2013 2:58 am
I've managed to get everything installed and running more or less.
However, I'm trying to track down the cause of an issue I'm having with my Gamecube controller. I've wired the GC controller to the GPIO and I am using the gamecon_gpio_rpi kernel module. I can run jstest against the device, and I can see all of the buttons and axes working per the output of the test.
The issue I am running into is that the actual input setup phase when initially setting up (when first running emulationstation) is that there seems to be a large amount of lag with the controller.
I am wondering if anyone has any specific advice regarding the setup of the GC controller and emulationstation. I'm guessing the issue is with gamecon_gpio_rpi - even in the test it appears that there is some lag.
Best,
Dave
marqs
Thu Dec 26, 2013 10:55 pm
ceterumnet wrote:I've managed to get everything installed and running more or less.
Best,
Dave
The driver polls controller(s) in 10ms intervals, so it shouldn't add too much latency in itself. If a read fails for some reason, additional lag could occur. Are you using official or 3rd-party GC controller? I've only tested the official, which worked reliably for me.
Note that there always seems to be minor input lag with emulators on Pi, which I guess is due to graphics drivers / HW. However, the lag should be no more when using a controller instead of keyboard.
spongman
Mon Feb 17, 2014 8:52 pm
did i miss a warning against installing this on raspbmc? i just did that and now xbmc doesn't run.
i get
 ERROR: EGL error in InitDisplay: 3001
 ERROR: InitWindowSystem: Could not create display
 FATAL: CApplication::Create: Unable to init windowing system
ad nauseam.
nicosalto
Sun Mar 09, 2014 7:25 am
I just installed retropie with the petrokblcock tutorial and wheni try to launch emulationstation i get this error:
/home/pi/RetroPie/supplementary/EmulationStation/emulationstation: error while loading shared libraries: libboost_filesystem.so.1.49.0: cannot open shared object file: No such file or directory
i installed the libboost library and still get the same error.
I have a raspberry pi model B and a 16GB SD Card.
I use the lastest version of raspbian 2014-01-07-wheezy with NOOBS 1.3.4.
I followed this tutorial step by step.
http://blog.petrockblock.com/2013/02/22 ... -a-recipe/
I am not sure where i went wrong, does anyone know which version of raspbian you need to install retropie with this setup ?
ProfessorKaos64
Sat Mar 15, 2014 9:33 pm
nicosalto,
I just went through my tutorial about 10 times this morning. I have a full table of contents and step by step instructions that cover much more than the basic set on GitHub. I'm adding more and more as I test out ROM situations. Take a look :mrgreen: :
http://www.thelinuxcauldron.com/2014/03 ... sperry-pi/
cdtpepette
Sat Mar 15, 2014 11:30 pm
I'm not able to configure the 2nd player on final burn alpha pi.
THT Arcade console 2P USB Player is detected as only one joystick "js0" with 4 axes and 22 buttons.
jstest /dev/input/js0
Axes: 0: 0 1: 0 2: 0 3: 0 Buttons: 0:off 1:off 2:off 3:off 4:off 5:off 6:off 7:off 8:off 9:off 10:off 11:off 12:off 13:off 14:off 15:off 16:off 17:off 18:off 19:off 20:off 21:off
Every axes and buttons work in jstest, retroarch and gngeo but not with final burn alpha pi.
fba2x.cfg:
[Joystick]
# Get codes from "jstest /dev/input/js0"
# from package "joystick"
A_1=0
B_1=1
X_1=2
Y_1=3
L_1=4
R_1=5
START_1=7
SELECT_1=6
#Joystick axis
JA_LR=0
JA_UD=1
#player 2 button configuration
A_2=10
B_2=11
X_2=12
Y_2=13
L_2=14
R_2=15
START_2=16
SELECT_2=17
#Joystick axis
JA_LR_2=2
JA_UD_2=3
Thanks for your help.
Return to “Gaming”
