kryptalivian
PS3 controller config for MAME and FBA
Thu Nov 12, 2015 9:42 pm
Could someone please assist me in setting a button to the insert coin hotkey.
I was thinking about using the PlayStation Button in the middle of the controller. How do I know which number refers to which button on the controller.
Thanks,
CJ
saulart
Re: PS3 controller config for MAME and FBA
Fri Dec 04, 2015 10:24 am
Install the system Recalbox and be happy!
Neil Munday
Mon Dec 07, 2015 7:21 pm
If you install the "jstest" utility then you can find out the button and axis IDs and values.
E.g.
jstest /dev/input/js0
Press Ctrl + C to exit the program.
If it helps, the PS button is button number 16.
Cheers,
Neil.
http://pes.mundayweb.com -> The Pi Entertainment System for all your gaming needs
Jako
Mon Dec 07, 2015 9:29 pm
This is my working config for FBA
[Joystick]
# Get codes from "jstest /dev/input/js0"
# from package "joystick"
JA_LEFT_1=7
JA_RIGHT_1=5
JA_UP_1=4
JA_DOWN_1=6
A_1=15
B_1=12
X_1=14
Y_1=11
L_1=10
R_1=13
START_1=3
SELECT_1=0
#Joystick axis
JA_LR_1=0
JA_UD_1=1
#player 2 button configuration
JA_LEFT_2=7
JA_RIGHT_2=5
JA_UP_2=4
JA_DOWN_2=5
A_2=15
B_2=11
X_2=13
Y_2=14
L_2=10
R_2=12
START_2=3
SELECT_2=0
#Joystick axis
JA_LR_2=0
JA_UD_2=1
Only Joysticks works for directions :-(
With mame use the TAB key to config, if you use imame4all for example.
Sorry, my english is awful, like me. XD
Return to “Gaming”
