veketor
Bartop and new frontend for emulation
Tue Sep 29, 2015 8:53 am
Hi, I have just finished a bartop, this is powered by a raspberry pi 2 and I wanted to show them off!
The cab contains a coin aceptor at right side, 2 players with four buttons per player.
The frontend is coded using openFrameworks and use gpio as input inteface.
The emulators are from libRetro as usual.
A video of the frontend:
https://www.youtube.com/watch?v=-aaPg5LtyvQ
mgoulart
Re: Bartop and new frontend for emulation
Tue Sep 29, 2015 1:21 pm
OMG!!! What a nice job!!!
I have two questions! Could you answer?
1 - Do you have a tutorial showing how to install this kind of coin acceptor?
2 - How I can get this frontend? Can I use a screen for each game (for example, instead we have one screen for each system, we have one screen per game)?
veketor
Tue Sep 29, 2015 2:36 pm
Thanks mgoulart :)
To install a coin aceptor, take a look at http://forums.adafruit.com/viewtopic.php?f=8&t=44883.
For now the frontend is tightly bound to the customized version of raspbian, and only accept gpio controls as inputs, in a few months will be released a modified version of the frontend, with gamepads or keyboard controls.
Use a background screen for each game: ops, this is posible, but its a lot of work make a background screen for each game. We will try to make something for the next release.
If I can help you, do not hesitate to ask.
expandables
Thu Oct 01, 2015 2:08 pm
It looks amazing and I would also love to try the front-end out.
:mrgreen:
By thinking like an engineer you can create a raspberry pi.
Michael Jackson enthusiast.
I got the PI model B, B+ and PI 2 model B.
When will I get the A? I don't know.
veketor
Thu Oct 01, 2015 3:15 pm
Thanks for your coment expandables :) .
We want to make a group of beta tester. Are you interested??
Thanks.
welshy
Thu Oct 01, 2015 6:22 pm
veketor
Agreed! Nice looking Front End/GUI, I'm sure the rest of the Pi Community will appreciate another one! Keep us informed and I can add to the Emulation Thread as an alternative to Emulation Station/AdvMENU!
"The list of things I have heard now contains everything!"
veketor
Thu Oct 01, 2015 8:13 pm
Thanks Welshy :)
We will report the progress of the frontend in this thread, for now we have to implement control with joystick and keyboard, because the only input method is with gpio , when we were ready we will release the frontend.
For now we are searching for beta testers.
expandables
Fri Oct 02, 2015 1:51 am
Yea I would like to beta test. Send me a PM. :mrgreen:
welshy
Fri Oct 02, 2015 8:01 am
veketor wrote:Thanks Welshy :)
Happy to help! I have previously assisted with RetroPie/MAME4ALLPi pre releases and have a 'Shed Load' of different Emulation Images/Pi Hardware which can be 'appropriated' for use in Testing (removing/replacing AdvMENU which is my preferred Front End/GUI).
Higgy
Fri Oct 02, 2015 12:11 pm
Excellent excellent work there. :ugeek:
Any chance of incorporating Vertical Support? One of my barcades has the monitor set-up for vertical games e.g. 1943, Donkey Kong. With MAME4ALL the menu is 90 degress out :lol: and you get a stiff neck :D :o :cry:
veketor
Mon Oct 05, 2015 7:47 am
Higgy, we put vertical support in the to-do list.
One question:
How do you drive the vertical resolution? From mame config file or from config.txt (system file)?
Thanks.
Higgy
Mon Oct 05, 2015 11:28 am
My vertical bartop is running on 256mb RPi v1 & I am driving veritical res via MAME config.
Using the rotate option in Config.txt causes too much slowdown :( I have not tried on RPi v2 to see if it can run ok via Config.txt screen rotation.
disposablereviewer
Mon Oct 05, 2015 4:30 pm
I'd like to beta test too. I have experience if that matters (Sr. QA engineer) and can help resolve bugs.
Return to “Gaming”
