Unreal Speccy Portable manual
Posted: Fri Jun 05, 2015 2:38 pm
by traidna
Does anyone have a link for a user guide, manual, or similar for unreal speccy, I am trying to figure our how to save programs written in the emulator on the Raspberry Pi,
Thanks,
Tom
Re: Unreal Speccy Portable manual
Posted: Mon Jun 08, 2015 5:36 pm
by traidna
I contacted @unrealSpeccyPortable on twitter and received a nice and prompt response:
"you can only store snapshots, then load/store them to .tap on PC"
I also learned by trial and error that snapshots only work when running as root or sudo. Also from what I tried running unreal_speccy_portable from withing PiPLAY or Chameleon it is not run as root.
so when unreal_speccy_portable is loaded from pi store it is the following directory :
/usr/local/bin/indiecity/InstalledApps/rpi/Full/usp_0.0.64 (where usp_0.0.64 is the latest version of the emulator)
then running sudo ./unreal_speccy_portable allow me to save state and load state, you can also load .tap files downloaded from another emulator or tool.
hope this helps anyone else trying this.
Posted: Mon Jun 08, 2015 7:22 pm
by AmigaGamer
Hi Traidna
As an alternate suggestion : Instead of using PI store, you can get unreal speccy from the author here https://bitbucket.org/djdron/unrealspeccyp/downloads .
You can extract the usp_0064 folder to your home directory, for example /home/pi This should give it the correct permissions for you to savestate without running with sudo.
Posted: Tue Jun 09, 2015 5:19 pm
by traidna
Thanks, I'll give that a try as well.
I did set up a simple bash script to change to the directory and run the emulator too, that has simplified things as well.
Cheers
Posted: Fri May 18, 2018 8:46 am
by Andrey
Hi Tom!
There are good news for you)
Newest version is able to store changed disk images & slots support.
You can get it here.
