i comiled the latest source and suddenly DOS commands on my boot HD folder are coming up as 'not executable'
reverted back to 0.4 (i think - whatever is bundled with RetroPie) and all is fine again ....
Using enhanced a600-like setup, kick 3.1 , two folder mounted as drives, standard dos commands, all files held in roms/amiga with permissions reset etc.
Downloaded source fresh from GitHub master zip this morning
Also, I am part of a Facebook group looking to improve the experience of uae4arm on Retropie by using whdload.
One thing that was noticed is its now necessary to manually select the controller driver from the input tab.
Dpad as joy doesn't seem to work "out of the box" as it were.
Given out need to share 1000s of .uae configs for each game, and the many variants of controller out there, could it be made that if the controller is not selected (or there is a "compatibility mode") then the defiant joypad/stick is used?
Either that or the current options are not behaving as the should....
