BluPI2
Manaplus client not found
Sun May 10, 2015 4:04 am
I'm trying to install the client for The Mana World in Raspbian on my raspberry pi 2. First I tried installing using "sudo apt-get install tmw" but that client is outdated and no longer works. The current client is manaplus located here: http://mirrordirector.raspbian.org/rasp ... /manaplus/
The problem is when I enter the command "sudo apt-get install manaplus" it gives me a package not found error, yet it is clearly in the repos.
What am I doing wrong? Any help greatly appreciated.
Proud Owner of a Raspberry Pi 3B and 3B+ running Ubuntu Mate
loldavid6
Re: Manaplus client not found
Sat Jul 25, 2015 10:52 am
I have also been trying to get TMW to work, but I did not know that they had a new client. I'm not very good when it comes to repositories - so i apologise if I can't be of any help, but I will browse the Internet for some answers.
super213
Sun Jul 26, 2015 1:00 am
BluPI2 wrote:I'm trying to install the client for The Mana World in Raspbian on my raspberry pi 2. First I tried installing using "sudo apt-get install tmw" but that client is outdated and no longer works. The current client is manaplus located here: http://mirrordirector.raspbian.org/rasp ... /manaplus/
You need to download the all package the armHF does not work but once you download it you need to go to the terminal and then cd to the file
then type
sudo dpkg --install (replace this with the file you downloaded here- hint use tab to type the file quick)
but i still dont know how to run it but it has installed on my machine at least! (i have no clue what this is or if what ever but i just wanted to help :] )
Zenji raffe
Wed Feb 20, 2019 3:58 pm
To run manaplus - follow theese instructions :
https://forums.themanaworld.org/viewtop ... 56&t=20568
best regars zenji raffe
Return to “Gaming”
