Kir13y
Handheld Game Emulator
Thu Apr 30, 2015 4:40 am
Hey Guys! This is my first Raspberry Pi project and I was hoping that I could get some help.
Background: I want to build a small handheld retro gaming device. I am planning to boot retro-pi onto it. I want it to look like the Nintendo DS by having a flip up screen. I want the bottom to be a modular rack for two different modules. Mini keyboard + track pad (wireless) or the game controls (wired). I think that I will have a connector on the side of the rack where the wired controls will clip into. I have purchased the keyboard(Link 1) and the Canakit with the Pi B+(Link 2). I have started designing the case for it using Tinkercad because im a noob at CAD (don't judge me).
Questions: 1. Can you recommend a display that will be about an inch bigger than the Raspberry Pi (diagonally)
2. What type of filament should I use to print the case?
3. How can I make the hinge stop at some spots?
4. Is this even possible?
5. Does anyone have a circuit diagram on wiring up an on/off switch and some game buttons?
6. What connector should I use on the side of the rack?
[New] 7. I need a hinge for the two halfs that can stop at like 140 degrees and will stay at 140
Extra: I will be posting a link to the Tinkercad page with what I have designed so far. If you need dimensions for anything I have most of them written down and I can send them to you.
Links: 1.http://www.amazon.com/iPazzPort-Wireles ... i+keyboard
2.http://www.amazon.com/CanaKit-Raspberry ... i+b%2B+kit
Closing: Thank you for taking the time to read this. Feel free to leave any suggestions or comments below and I will be updating this periodically.
Thanks,
Kir13y
Forgotten01
Re: Handheld Game Emulator
Thu Apr 30, 2015 2:47 pm
Hey there! Just wanted to say that I am working on a project very similar to this, and that this is indeed entirely possible to do. Not really sure if the screen is exactly an inch bigger, but this is what I am using
http://www.adafruit.com/products/1928
I reccomend you shop around a little before you buy it though, there are a few that have different features such as touchscreen, or lower power draw
Also, do not forget a power supply, realistically with this screen you will have a draw of at least 1.2 amps
Engineers like to solve problems. If there are no problems handily available, they will create their own problems.
Scott Adams
Kir13y
Fri May 01, 2015 2:47 am
Forgotten01 wrote:Hey there! Just wanted to say that I am working on a project very similar to this, and that this is indeed entirely possible to do. Not really sure if the screen is exactly an inch bigger, but this is what I am using
Thanks for the response. Ill keep that one in mind!
Return to “Gaming”
