Here's my component list. These are items I either already had, received, or am awaiting to receive.
- Raspberry Pi 2 - Model B
- 5V 2A (2000mA) switching power supply - UL Listed
- Shutdown circuit (use your own switch)
- UPS Pico and Fan Kit
- Miniature WiFi (802.11b/g/n) Module: For Raspberry Pi and more
- Bluetooth 4.0 USB Module (v2.1 Back-Compatible) CSR8510
- Panel mount cables and required adapters
- Seimitsu PS14-KN 30mm arcade button. Smoke body with green plunger cover. Added a vinyl power logo to the plunger and FocusAttack foam button silencer. 30mm pele ring for led.
- 32GB Sandisk Ultra Micro SD (features wear leveling)
I plan on using my PS3 controller (s) via bluetooth. With a 2000ma power supply, I am hoping the raspberry pi 2 can supply enough power to the front 2 usb ports to charge the controllers. Finding another power supply or dock to charge them is a pet peeve of mine.
The case/enclosure I am looking at is the Polycase DC-96P. I made a cardboard test box to the dimensions. It's large and I can definitely squeeze everything into one of their smaller cases of similar style. I'll test fit everything once the shutdown circuit and ups pico arrive from the mail.
Do you guys think the wifi and bluetooth modules I got will be powerful enough to still work well inside the case? I am worried that I went too cheap.
