gtoilet
arcade controller question
Thu Jun 17, 2021 6:06 am
my friends got an old raspberry pi 0 with the classic retropi install
hes wondering if a arcade controller set up like this if it would interface with that old board
https://www.amazon.com/dp/B00WDQWK5M/re ... 8wk3jHISLY
pcmanbob
Re: arcade controller question
Thu Jun 17, 2021 8:42 am
Hi.
As everything appears to be switch based you could certainly connect the switches directly to the gpio pins.
I am not sure about the USB controllers they may need a driver..
gtoilet
Thu Jun 17, 2021 3:34 pm
well that would mean i would have to work on it lol
hes kinda dumb when it comes to things that require work
if it dont plug and play he struggles
drtechno
Thu Jun 17, 2021 7:34 pm
Well if you don't have drivers in Windows, most likely it won't have any in linux because it will use a usb compliant driver.
So I'm guessing its one of these.
otherwise:
A HID driver based joystick would have drivers you have to install regardless of OS.
pcmanbob
Fri Jun 18, 2021 12:38 pm
Having looked at this again you might be lucky if the information in the product description is correct .
Compatible model
Win8/Win7/Vista/XP/2000/98, Linux, MAC OS, Android.Raspberry Pi 1/2/3/3B Retropie Arcade DIY Projects,MAME DIY projects,USB MAME cabinet arcade DIY projects & PC controller computer game etc.
It does list some models of pi and retropie.
gtoilet
Sat Jun 19, 2021 12:11 am
Compatible model
true didnt see that at the bottom , appreciate the point out
i made him the raspberry pi 0 , 3/4 yrs ago for that retropi setup atari/super/sega/nes
Return to “Gaming”
