Vince Swu
Re: GUIDE: Installing Minecraft Survival on the Raspberry Pi (free)
Thu Jan 21, 2021 10:35 am
Instead of taking trouble writing codes or downloading Maps, Just Download The MCPI Survival Mod and Launcher https://raspiantactics.blogspot.com/202 ... patch.html
Unounited
Thu Jan 21, 2021 2:58 pm
Weird that website you showed me expired but it doesn't matter anyway because Minecraft Pi just got modded.
KMD81
Mon Feb 01, 2021 3:09 pm
well, im tryna use mozo and every time I try to new item minecraft pi it says "OSError [Errno 2] no such file or directory" even though it should know that it's a file on my pi and that I'm using the file to make a new item, it's wierd man, you know how to fix this??
Unounited
Sun Apr 18, 2021 10:17 pm
:?: I don't quite understand what your situation is, I'm guessing you didn't do exactly what Gubba Monster told you to do. You could try using main menu editor instead of mozo. It should be located in Preferences in your pi menu, if not copy and paste this command:
sudo apt install alacarte
Then go to Preferences again to see if it's installed.
That's all I can tell you I'm afraid!
Wildern
Thu Apr 22, 2021 4:30 pm
Looks like you can now get MCPIL with a few clicks on pi-apps(or github) - https://github.com/MCPI-Revival/MCPIL for more info
I’ll tell you a DNS joke but be advised, it could take up to 24 hours for everyone to get it.
My friend finally came to the conclusion that Raspberry Pi's are small.
Read more...
Unounited
Thu Apr 22, 2021 5:16 pm
Looks like you can now get MCPIL with a few clicks on pi-apps - https://github.com/Botspot/pi-apps for more info
True, and it no longer needs the survival patch :D.
Gubba Monster
Sun Apr 25, 2021 11:32 pm
That's great. I remember the patch had several annoying bugs because it was made a long time ago.
dawnbailey1974
Tue May 18, 2021 7:41 am
Unounited wrote:
Sun Dec 06, 2020 4:52 pm
I have been looking for the code too. The code you might be trying to look for is the python code for minecraft pi, which I think the code is in this website: https://www.the-essays.com/
If it's not what your looking for, let me know
Thanks!
Thanks! This is helpful.
Unounited
Tue May 18, 2021 1:24 pm
I have been looking for the code too. The code you might be trying to look for is the python code for minecraft pi, which I think the code is in this website: https://raw.githubusercontent.com/raspb ... rksheet.md
Thanks!
It was meant to be the survival patch source code which I don't think will ever be released, but I actually did the minecraft pi tutorial source code, which was my mistake, but glad you have learned about the minecraft pi tutorial code.
tnt8888
Mon May 24, 2021 3:56 pm
it doesn't run on retropie!!!
Unounited
Wed May 26, 2021 3:17 pm
:? What exactly do you mean it doesn't run on retropie?
OH, are you saying that the modded minecraft pi doesn't run on retropie?
Return to “Gaming”
