novaspirit
[Guide] How to install Doom 3 on Raspberry pi 4
Fri Sep 20, 2019 2:06 pm
I put together a guide on how to install doom 3 on raspberry pi, you can also check out the video on this same process of install and also game play footage. Thanks!!
Youtube Video
https://www.youtube.com/watch?v=tMYUgfvijvY
Requirements
  • Full or Demo of Doom 3
  • Raspberry pi 4 (2gb or higher recommend)
  • at least 2gb space
Dependencies
Open the terminal and type
sudo apt-get install libfontconfig-dev qt5-default automake mercurial libtool libfreeimage-dev \
libopenal-dev libpango1.0-dev libsndfile-dev libudev-dev libtiff5-dev libwebp-dev libasound2-dev \
libaudio-dev libxrandr-dev libxcursor-dev libxi-dev libxinerama-dev libxss-dev libesd0-dev \
freeglut3-dev libmodplug-dev libsmpeg-dev libjpeg-dev libogg-dev libvorbis-dev libvorbisfile3 libcurl4 cmake
Compiling SDL2
lets download SDL2
hg clone http://hg.libsdl.org/SDL
cd SDL
./autogen.sh
./configure --disable-pulseaudio --disable-esd --disable-video-wayland \
  --disable-video-opengl --host=arm-raspberry-linux-gnueabihf --prefix=/usr
make
sudo make install
now we need to download and extract the 3 add-ons
cd ..
wget http://www.libsdl.org/projects/SDL_image/release/SDL2_image-2.0.5.tar.gz
wget http://www.libsdl.org/projects/SDL_mixer/release/SDL2_mixer-2.0.4.tar.gz
wget http://www.libsdl.org/projects/SDL_ttf/release/SDL2_ttf-2.0.15.tar.gz
tar zxvf SDL2_image-2.0.5.tar.gz
tar zxvf SDL2_mixer-2.0.4.tar.gz
tar zxvf SDL2_ttf-2.0.15.tar.gz
lets build each addon
cd SDL2_image-2.0.5
./autogen.sh
./configure --prefix=/usr
make
sudo make install
cd ..
cd SDL2_mixer-2.0.4
./autogen.sh
make
sudo make install
cd ..
cd SDL2_ttf-2.0.15
./autogen.sh
make
sudo make install
cd ..
Compile DHEWM3
lets grab the repo from git
git clone https://github.com/dhewm/dhewm3
now we need to make a build folder, cmake, and compile
cd dhewm3/neo/
mkdir build
cd build
cmake ..
make -j4
once your done you should have 4 files needed to run Doom 3
(base.so, d3xp.so, dhewm3, libidlib.a)
now copy those files over to the Doom 3 or Doom 3 Demo folder
you can either purchase the game via Steam or download the demo. you should be able to find the files in steamapps/Doom 3. Transfer whole doom 3 folder over to your raspberry pi and enjoy!
running doom 3
navigate over to your doom 3 folder and execute
./dhewm3
for FPS and CPU counter
GALLIUM_HUD=simple,fps,cpu ./dhewm3
thanks for following along!! hope you enjoy!!!!
Novaspirit Tech
YouTube @ youtube.com/novaspirittech
bomblord
Re: [Guide] How to install Doom 3 on Raspberry pi 4
Fri Sep 20, 2019 10:50 pm
What kind of performance do you get on it?
novaspirit
Fri Sep 20, 2019 11:10 pm
my setup:
gpu @620mhz
resolution @ 960x540
normal walking around 30fps~
lots of particals like fire and steam 14fps~
Novaspirit Tech
bomblord
Fri Sep 20, 2019 11:32 pm
my setup:
gpu @620mhz
Good to know thanks!
graphicw
Sun Sep 22, 2019 11:29 pm
This is an excellent guide and it works flawlessly. I have Doom 3 working on my RPI 4 and it is very pleasantly playable at 720p with 2ghz CPU and 600 mhz GPU overclock. Sure it will perform even better as the Mesa drivers mature though it is playing quite fluid as is. Excellent work. Thanks for this wonderful guide.
graphicw
Sat Sep 28, 2019 9:42 pm
I have found one other easily overlooked thing to improve Doom 3 playback on Pi 4. With my monitor, the refresh rate defaults to 75 hz. By setting it for 60 hz instead, it oddly had a very positive effect on Doom 3 frame rate. I am have my CPU clocked at 1.8 Ghz and my GPU set to 600 Mhz. My resolution in game is set to 720P with graphics set to the highest setting and all effects on and the frame rate is quite smooth for the most part. This game is well worth installing as it will show you what the Pi 4 is quite capable of. I remember when it first came out in 04 and you had to have a $2,500 rig to be able to play this game with these kinds of setting at only 1024x768. The Pi blows through 1024x768 like it is nothing. Perfect frame rate through the whole game regardless of the action on screen.
graphicw
Sat Sep 28, 2019 9:45 pm
One last tip is to run the game from an external USB 3.0 hard drive or SSD. Load time is much faster than trying to run the game from SD card.
lorapage
Tue Oct 08, 2019 2:34 am
That was interesting, actually i would propose try to run yamagi-quake2, it is a Enhanced Quake II engine optimized for modern systems. I'm interested, will it work with hd resolution or not. i suggested this version because google street view it has all sorts of modes and resolutions built in (/home/user/.yq2/baseq2/config.cfg custom resolution and just in video options change to custom & full screen switch resolution, you can choose versions of openGl too) best wishes.
pi-tastic
Fri Oct 11, 2019 5:55 pm
sorry to post this here and not somewhere else.
i was wondering if you could compile this for the raspberry pi.
https://github.com/unetbootin/unetbootin/wiki/compile
I figured you were smart enough to make doom3 work, surely you could make this work!
Thanks!
maccaps.com - bringing life to dead electronics.
VitalSpark
Thu Mar 04, 2021 12:51 pm
Where can I get the doom3 files from Linux?
Want to even buy it but cannot find anything apart from the pc version on Steam or a doom bfg in disk format?
Can anyone advise where to obtain?
There are only 10 types of people in the world: Those who understand binary, and those who don’t!
BossCoding
Thu May 13, 2021 8:35 pm
lol takes a long time but whatever
RaspbianUser1
Thu May 13, 2021 9:44 pm
You are compiling a entire game, of course it takes a lot of time
Running with a Raspberry Pi 4B 4GB with Raspberry Pi OS with MATE Desktop
Why not overclock, push some more performance out of your computer!
Think before you delete something a stranger on the internet told you to.
leilei
Sat May 15, 2021 4:06 am
If buying on Steam isn't an option, then you'll have to go for secondhand retail versions of the original CD release and fetch the pk4s with a computer that has a CD/DVD rom drive and/or an external CD/DVD drive, and then download the latest patch files (gamedatapackager should be able to handle this). You'd also have to compile dhewm3 (which really isn't daunting. a Pi3 can do it)
Return to “Gaming”
