Nobody5050
How to install and play Minecraft Pi Modded for FREE!
Sat May 01, 2021 12:00 am
Hello!
In this post I’m going to teach you how to install Minecraft pi modded both with and without pi apps, and how to get started playing survival and multiplayer.
Before we get started I’d like to point out there’s already a thread for survival in Minecraft pi here: viewtopic.php?f=78&t=275359&hilit=Minecraft+for+free But sadly it’s using older mods and needs updating.
I also want to point out that there’s a thread for mcpi-revival here: viewtopic.php?f=78&t=287089&p=1735437&h ... l#p1735437 But it’s also somewhat outdated and it’s installation tutorial is no longer functional.
Using Pi-Apps
The easiest way to install Minecraft pi modded is with botspot’s pi apps program. It has the install scripts for many apps that are nice to have on a raspberry pi such as zoom and discord.
To install it:
wget -qO- https://raw.githubusercontent.com/Botspot/pi-apps/master/install | bash
Once you’ve installed it, it should automatically launch.
From there click on games, and double click Minecraft Pi (Modded)
To install select the install button at the bottom of the window.
Without Pi Apps
Since we understand you may want to use Minecraft pi modded without having pi apps installed, there’s a way to install mcpil completely from the terminal.
wget -qO- "https://raw.githubusercontent.com/Botspot/pi-apps/master/apps/Minecraft%20Pi%20(Modded)/install" | bash
Once the script runs mcpil should appear in your app launcher under games
Have fun playing mcpi!
Playing Minecraft Pi
Now that you’ve got it installed let’s get started playing Minecraft!
Go to your app launcher, choose mcpil and a new window should pop up that looks like this:
You can always select classic MCPI if you want the original unmodded version but the other options are generally considered better.
Modded MCPI will give you the classic mcpi GUI but with survival mode accessible in the world creation menu and some graphical improvements.
Classic MCPE will launch Minecraft pi with the pocket edition ui, this will give you a better survival experience but there wont be any other mods.
Finally, Custom Profile will let you control which mods are enabled and when by selecting them in the features tab and hitting save.
Now that we’ve chosen a profile, let’s play!
Singleplayer
Firstly, singleplayer. If you’ve created any worlds in un-modified Minecraft pi they should be accessible to you just by hitting play and choosing them from the list.
For survival worlds, we recommend picking modded MCPI or classic MCPE to load them otherwise you’ll experience some buggy gameplay.
Multiplayer!
Onward to multiplayer! Minecraft Pi edition has a rich and active community as well as a few multiplayer servers.
By default mcpil will connect you to https://thebrokenrail.com:19132. You can connect to it by choosing modded MCPI or classic MCPE and choosing Join Game. From there it should show up in the list of servers, and you can connect by clicking on it.
Another server, pbpt anarchy isn’t listed by default but can be added by going to the multiplayer tab in mcpil and entering the following:
IP address: pbptanarchy.tk
Port: 19132
After that you can hit save it should show up in the server list.
For more info on servers go to https://mcpirevival.tk/servers.html
That’s all folks!
Thanks for reading this post! I had a lot of fun making it and I hope it helped you get the most out of Minecraft on the pi. For more info we have a wiki at https://wiki.mcpirevival.tk and some more in depth tutorials at https://mcpirevival.tk
If you run into any issues at all with the above steps don’t hesitate to make a reply below, or join our discord server, linked in my signature.
Have a good day!
hi. i do mcpi stuff. https://discord.gg/DCwcpyf
Botspot
Re: How to install and play Minecraft Pi Modded for FREE!
Tue May 04, 2021 4:59 pm
Great tutorial. Well done. 8-)
Pi-Apps - #1 most popular Raspberry Pi app store with >100,000 users.
Includes the Zoom desktop app, 3 ways to run Minecraft, 7 web browsers, appearance themes, and 72 more.
More info: https://github.com/Botspot/pi-apps
Nobody5050
Tue May 11, 2021 9:41 pm
Thanks!
Unounited
Wed May 12, 2021 1:22 am
Hi
If anyone is still in this topic, I tried getting the minecraft pi modded command without pi-apps installed:
wget -O - https://raw.githubusercontent.com/Botspot/pi-apps/master/apps/Minecraft%20Pi%20(Modded)/install | bash
And it says:
bash: syntax error near unexpected token `('
Then I tried this:
wget -O - "https://raw.githubusercontent.com/Botspot/pi-apps/master/apps/Minecraft%20Pi%20 | bash"
Now it gives me:
Proxy request sent, awaiting response... 404 Not Found
2021-05-11 19:19:07 ERROR 404: Not Found.
Is the command broken or did I do the commands wrong?
Solution needed, Thanks!
Botspot
Wed May 12, 2021 2:28 am
Then I tried this:
wget -qO- "https://raw.githubusercontent.com/Botspot/pi-apps/master/apps/Minecraft%20Pi%20 | bash"
Oh I see what happened. Your last quotation mark was placed a bit too far.
It should be this:
@Nobody5050, consider updating your main post to include this fix.
Unounited
Wed May 12, 2021 2:50 am
Opps.. I did put the quotation mark in the wrong place, However it still said
ERROR 404 NOT FOUND on the command line.
Botspot
Wed May 12, 2021 2:54 am
My bad. I copied the link you posted, not realizing you had changed the link to be invalid.
I've edited my reply with a working link this time.
Unounited
Wed May 12, 2021 2:08 pm
And it was a working link, so it works this time.
Thanks for your help Botspot!
Nobody5050
Thu May 13, 2021 5:23 pm
Should be fixed.
Return to “Gaming”
