lfc123
Minecraft crashes every time I launch it with Optifine
Fri May 07, 2021 5:13 pm
I downloaded minecraft java through pi-apps on my pi4 using the standard raspberry pi os. The game will launch fine from the non-optifine profile. It was pretty slow, so I downloaded optifine following this tutorial:
viewtopic.php?f=78&t=303557&p=1817724&h ... e#p1817724
It crashes when I try to launch it, so i tried versions 1.16.1 to 1.16.5, but its the same with each one. Crash report says this:
java.lang.ExceptionInInitializerError
at dkd.<init>(GameSettings.java:177)
at djz.<init>(SourceFile:440)
at net.minecraft.client.main.Main.main(SourceFile:177)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:62)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:43)
at java.lang.reflect.Method.invoke(Method.java:498)
at net.minecraft.launchwrapper.Launch.launch(Launch.java:159)
at net.minecraft.launchwrapper.Launch.main(Launch.java:30)
Caused by: java.lang.RuntimeException: java.lang.UnsatisfiedLinkError: Failed to locate library: liblwjgl32.so
at deo.<clinit>(SourceFile:46)
... 9 more
Caused by: java.lang.UnsatisfiedLinkError: Failed to locate library: liblwjgl32.so
at org.lwjgl.system.Library.loadSystem(Library.java:147)
at org.lwjgl.system.Library.loadSystem(Library.java:67)
at org.lwjgl.system.Library.<clinit>(Library.java:50)
at org.lwjgl.system.MemoryAccessJNI.<clinit>(MemoryAccessJNI.java:13)
at org.lwjgl.system.Pointer.<clinit>(Pointer.java:28)
at org.lwjgl.system.Platform.mapLibraryNameBundled(Platform.java:80)
at org.lwjgl.glfw.GLFW.<clinit>(GLFW.java:674)
at sun.misc.Unsafe.ensureClassInitialized(Native Method)
at java.lang.invoke.DirectMethodHandle$EnsureInitialized.computeValue(DirectMethodHandle.java:330)
at java.lang.invoke.DirectMethodHandle$EnsureInitialized.computeValue(DirectMethodHandle.java:327)
at java.lang.ClassValue.getFromHashMap(ClassValue.java:227)
at java.lang.ClassValue.getFromBackup(ClassValue.java:209)
at java.lang.ClassValue.get(ClassValue.java:115)
at java.lang.invoke.DirectMethodHandle.checkInitialized(DirectMethodHandle.java:351)
at java.lang.invoke.DirectMethodHandle.ensureInitialized(DirectMethodHandle.java:341)
at java.lang.invoke.DirectMethodHandle.ensureInitialized(DirectMethodHandle.java:373)
at deo.<clinit>(SourceFile:43)
... 9 more
A detailed walkthrough of the error, its code path and all known details is as follows:
-- Head --
Thread: Render thread
Stacktrace:
-- Initialization --
Details:
Stacktrace:
-- System Details --
Details:
Minecraft Version: 1.16.5
Minecraft Version ID: 1.16.5
Operating System: Linux (arm) version 5.10.17-v7l+
Java Version: 1.8.0_251, Oracle Corporation
Java VM Version: Java HotSpot(TM) Server VM (mixed mode), Oracle Corporation
Memory: 99624192 bytes (95 MB) / 349773824 bytes (333 MB) up to 523501568 bytes (499 MB)
CPUs: 4
JVM Flags: 5 total; -Xmx512M -XX:+UseConcMarkSweepGC -XX:+CMSIncrementalMode -XX:-UseAdaptiveSizePolicy -Xmn128M
Launched Version: 1.16.5-OptiFine_HD_U_G7
Backend library: LWJGL version 3.2.2 build 10
Backend API: ~~ERROR~~ NoClassDefFoundError: Could not initialize class org.lwjgl.glfw.GLFW
GL Caps:
Using VBOs: Yes
Is Modded: Very likely; Jar signature invalidated
Type: Client (map_client.txt)
CPU: <unknown>
OptiFine Version: OptiFine_1.16.5_HD_U_G7
OptiFine Build: 20210305-003221
Shaders: null
OpenGlVersion: null
OpenGlRenderer: null
OpenGlVendor: null
CpuCount: 0
I've been looking around for information on LWJGL, but I can't find anything for using it with a pi. I'm relatively new to programming, so if this is way simpler than I'm making it out to be, sorry! Thanks in advance! :D
Wildern
Re: Minecraft crashes every time I launch it with Optifine
Sat May 08, 2021 2:04 pm
Go onto the minecraft launcher and if the profile is selected as "OptiFine" change it to one with your minecraft account name on. Click "Edit Profile", then "Use Version" and select the OptiFine version you want to use.
I’ll tell you a DNS joke but be advised, it could take up to 24 hours for everyone to get it.
https://discord.gg/GmzjdHxkgS
My friend finally came to the conclusion that Raspberry Pi's are small.
Read more...
Return to “Gaming”
