Wildern
ATLauncher : Minecraft Launcher with Microsoft account support
Fri Mar 26, 2021 1:38 pm
ATLauncher : A launcher that runs minecraft on the Pi, with Forge + Fabric pre-installed, hundreds of mods to choose from and install with a click + Microsoft account support, I have to say I'm pretty amazed.
www.youtube.com/watch?v=wCY-IOLIGbM&t=44s for the youtube tutorial.
Easily install from https://atlauncher.com (download the .deb file and your set).
Once launched, select "Accounts" and sign in with your minecraft account.
Now, to install a version, go to "Vanilla Packs" and either select Vanilla Minecraft(minecraft with no mods), Minecraft with Forge(allows you to use mods) or Minecraft with Fabric(same as Forge). If you want to use Optifine with this I recommend using Forge.
Now after you've installed that, it's time for some code. Select instances, then the version you installed and then settings.
Go onto the Java Parameters and paste this code above where it says "-XX:+UnlockExperimentalVMOptions -XX:+UseG1GC -XX:G1NewSizePercent=20" :
For 32bit:
< 1.13 :
-Dorg.lwjgl.librarypath=/home/pi/lwjgl2arm32
= 1.13 :
-Dorg.lwjgl.librarypath=/home/pi/lwjgl3arm32
For 64bit:
Replace the open jdk path with the oracle jdk path:
/opt/jdk/jdk1.8.0_251/bin/java
Add the following to the beginning of the arguments to specify lwjgl3 (if using a user other than 'pi' change accordingly):
= 1.13 :
-Dorg.lwjgl.librarypath=/home/pi/lwjgl3arm64
(Above : Extract from rpiMike's tutorial)
Go to the start of the G1NewSizePercent arg (its right after the lwjgl arg) press backspace, and then press space(otherwise you get a nasty error).
Finally, select Java Path and change it to
/opt/jdk/jdk1.8.0_251/bin/java (32-bit)
Press save and Play! :D
I’ll tell you a DNS joke but be advised, it could take up to 24 hours for everyone to get it.
https://discord.gg/GmzjdHxkgS
My friend finally came to the conclusion that Raspberry Pi's are small.
Read more...
FinnisAmerican
Re: ATLauncher : Minecraft Launcher with Microsoft account support
Fri May 07, 2021 4:10 am
It shows up with this error
 Caused by: java.lang.RuntimeException: java.lang.UnsatisfiedLinkError: Failed to locate library: liblwjgl32.so
does anyone know how to fix this?
Wildern
Sat May 08, 2021 1:57 pm
Hmm, does this happen when you try to run atlauncher, or launch an instance?
Maybe try this
wget https://github.com/mikehooper/Minecraft/raw/main/lwjgl2arm32.tar.gz
wget https://github.com/mikehooper/Minecraft/raw/main/lwjgl3arm32.tar.gz
It installs the lwjgl args, maybe you didn't have that already?
Also, just in case try this to:
sudo apt-get update
sudo apt-get install oracle-java8-installer
sudo apt-get install oracle-java8-set-default
It installs java8 which you will need for atlauncher.
Read more...
smulrine
Fri Jun 11, 2021 3:41 pm
I have both Pixelmon and Pokehaan Craft working on an 8GB Pi 4 running 64-bit Raspberry Pi OS, using the Oracle 8 JDK which I downloaded and extracted manually. ATLauncher has a dependency on some Java component which the manual Oracle 8 JDK installation does not satisfy, and both of the aforementioned packs require Minecraft 1.12.2 and therefore the appropriate lwjgl library. Additionally, there was no sound at all due to another missing library. I believe the following would resolve all of these issues:
apt install openjdk-11-jre liblwjgl-java-jni libopenal-dev
Then ATLauncher can be installed. In Settings -> Java/Minecraft, set the Java path to your Oracle 8 JDK installation, and add -Dorg.lwjgl.librarypath=/usr/lib/jni to your Java parameters. I also had to disable the FoamFix and Treasure2 mods to get my Pokehaan Craft instance to load.
Last bumped by Wildern on Fri Jun 11, 2021 3:41 pm.
Return to “Gaming”
