hackedmacbook111
Contact: YouTube
Minecraft Java 1.14.4 or 1.15.2 Need Help Downloading
Fri May 22, 2020 4:12 am
I used fourm
viewtopic.php?t=249875
when I use command cd ~/Minecraft && java -jar Minecraft.jar
Launcher loads but when I try to install 1.14.4 it says preparing doesn't fully install
Another note is that I successfully installed 1.12.2 optifine with fourm
viewtopic.php?t=243946
Is there an alternative launcher I can use that can get me 1.14.4
or at least get it installed so I can use rest of commands to upgrade to 1.14.4 from 1.12.2
please help
HawaiianPi
Re: Minecraft Java 1.14.4 or 1.15.2 Need Help Downloading
Fri May 22, 2020 5:43 am
Try here: How to setup Minecraft 1.15.2 on Pi4
In my experience the Pi is not a very good client for running the game (low graphics settings and short render distance). You can make a good server for older versions (my Creeper Pie SMP server for 1.12.2 runs on a 3B+). Pi4 might make a better server, but I'd be surprised if it could play the game well.
hackedmacbook111
Contact: YouTube
Fri May 22, 2020 1:37 pm
I already have a minecraft server running through minehut with plugins viaversion and via backwards
I am looking for a way to play the game on a raspberry pi 4 B 4GB
I will use your website
hackedmacbook111
Contact: YouTube
Sat May 23, 2020 12:30 am
Finnally I can get more alts
hackedmacbook111
Contact: YouTube
Sat May 23, 2020 12:55 am
I got minecraft 1.15.2 to load then almost launch but after red bar loads it disappears minecraft isn't showing
I followed your instructions someone please help or should I use 1.14.4 instead
sometimes the minecraft 1.15.2 freezes while loading red bar
I got it load is there a way to fix this so it always loads
hackedmacbook111
Contact: YouTube
Sat May 23, 2020 12:57 am
While loading a Minecraft Server it connected and less than a minute later Minecraft 1.15.2 crashes
I think I will try 1.14.4 if 1.15.2 doesn't load correctly
Using currently Raspberry pi 4 B 4GB not overclocked
hackedmacbook111
Contact: YouTube
Sat May 23, 2020 1:19 am
Someone please help me if possible to run 1.15.2
Return to “Gaming”
