willywillywily0
Wii video capture/streaming driver issue
Sat Jun 09, 2018 9:24 pm
I am trying to make a device that i could just turn on, press a button and live stream to twitch from the raspberry pi
the idea for this build came from this youtube video from someone who made a similar project: https://www.youtube.com/watch?v=ob-V1xI7c8I and this video about how he made it: https://www.youtube.com/watch?v=FF4ToiF ... dex=2&t=0s
essentially i want to make that or something like that only using composite input instead of hdmi so i can stream from my wii or gamecube or other older systems.
I have a usb composite capture card but i cant get it to work. This is what the output is when i use lsusb in terminal:
[email protected]:~ $ lsusb
Bus 001 Device 063: ID 1c88:0007 Somagic, Inc. SMI Grabber (EasyCAP DC60+ clone) (no firmware) [SMI-2021CBE]
Bus 001 Device 062: ID 05ac:021d Apple, Inc. Aluminum Mini Keyboard (ANSI)
Bus 001 Device 061: ID 05ac:1005 Apple, Inc.
Bus 001 Device 053: ID 0424:ec00 Standard Microsystems Corp. SMSC9512/9514 Fast Ethernet Adapter
Bus 001 Device 052: ID 0424:9514 Standard Microsystems Corp. SMC9514 Hub
I've been searching for hours trying to figure out how to make it work and this is probably the most promising thing that I found: viewtopic.php?t=64077 but i have no idea what to actually do with any of it, im a toal beginner with linux stuff so any help at all would be greatly appreciated
Rodney_Rhodes
Re: Wii video capture/streaming driver issue
Tue Jul 03, 2018 9:08 am
Is it really work friend?
byneheh
Sat Sep 08, 2018 11:33 am
essentially i want to make that or something like that only using composite input instead of hdmi so i can stream from my wii or gamecube or other older systems. Maybe I have to use some patcher
I've been searching for hours trying to figure out how to make it work and this is probably the most promising thing that I found: https://www.raspberrypi.org/forums/view ... hp?t=64077 but i have no idea what to actually do with any of it, im a toal beginner with linux stuff so any help at all would be greatly appreciated
Is this really working? can We develop something similar but for nintendo switch?
rahulyyadav
Fri Sep 28, 2018 12:34 pm
Someone please give an update whether it is working.
sherylbrock7
Fri Jan 11, 2019 8:15 pm
Is this only for Steam? Is there a way to configure emulators to stream to my Retropie box? So if I want to play N64, Saturn, Wii, Wii U, PS3, etc that my PC can run but the Pi can't
aptoide ios
rossgellen00
Wed Apr 03, 2019 10:35 am
avensis wrote:
Sat Oct 27, 2018 12:25 am
Does it really work? I really wanna try it :roll:
________________________________________________________________________________________________
ShowBox Tutuapp nox
Already it and working great for me.
mgc1954
Sun Dec 08, 2019 9:42 am
Hi I have finally been able to get the Somagic EasyCap USB Grabber SMI-2021CBE working very well with a Raspberry Pi 4B+ 4 gb.
The ID is 1c88:0007 for a non initialised device. You can plug in the grabber and check this in a terminal with lsusb.
I have posted all the files to a public folder on my github site. There is a file installme.odt that guides you through the process.
The files are now available on github.
https://github.com/mikegcrean/MyRpiStuff
Best regards to all
Mike
noodling
Fri Jan 10, 2020 12:32 am
Hey Mike - I’m interested in buying the same hardware but I read at the link below that it’s pretty unpredictable what you might get - did you buy yours online for shipment to the US? Care to share where ? Thanks !
https://linuxtv.org/wiki/index.php/Easycap
Alex Herry
Thu Mar 26, 2020 2:02 pm
The Vidmate 2020 HD video downloader android version 3.5403. Get a high-speed download link for HD video downloader. It's mainly used to download Free videos from YouTube.
Download Here: https://androidblue.com/vidmate-video-d ... -download/
Return to “Gaming”
