timof121
Re: How to setup Minecraft 1.12.2 + Optifine + Forge On a Raspberry Pi 2B, 3B, 3B+ (Untested on Pi 4B)
Wed Mar 11, 2020 8:08 pm
Hello. Now that i'm on a RPi 4 with 4GB RAM everything works very good. I used RpiMike tutorial for the first part of the tutorial. Thanks!
Do you have any idea about running minecraft custom clients (that are placed in versions, not mods) like Wolfram
dominic03
Sat Mar 21, 2020 3:44 pm
Not working on Pi4 4GB.
Here is the error when starting the game (not from the launcher):
Java HotSpot(TM) Server VM warning: Using incremental CMS is deprecated and will likely be removed in a future release
Error: Could not find or load main class net.minecraft.launchwrapper.Launch
Raspberry Pi 4B running Raspbian Buster v3.1 (via PINN)
Kingston 32 GB C10 (U1) microSD
Sceptre E225W 22" 75hz 1080p monitor
Flash drive for backups and swap
-or-
pi-top 3 running Raspbian with drivers and pi-topHUB 2.0 / 16GB SanDisk C10 microSD
DarkPlatinum
Contact: Website YouTube
Tue Mar 24, 2020 2:31 pm
Hi Tim, sorry I have never done anything with wolfram or custom clients so I have no idea unfortunately.
1 * Raspberry Pi Zero W, 1 * Raspberry Pi 2, 1 * Raspberry Pi 3 1 * Raspberry Pi 3B + :mrgreen:
Check Out My Raspberry Site (Run on a Raspberry Pi 3B :) ): https://html.dynu.net
timof121
Fri Mar 27, 2020 8:29 pm
Np, i found a solution
Thanks for the reply and the tutorial!
Return to “Gaming”
