T_Oldskool
Retropie Issue
Tue Nov 19, 2019 10:29 am
Hi folks, having some issues with my Pie running Retropie, I've had
it for a few years, just recently looked it out for a bit of gaming.
Every time I boot up, it askes me to map my controller, and then
when I go in to a game, play for a bit, exit back to the menu
it freezes, I can't move up or down to select another game, or go back
to the main retro pie menu. I have to switch it off, then back on again & same
scenario, it asks to config the controller, most annoying!!
I'm using Bluetooth controllers, I have 2 of them. I also have
a USB controller which I also tried, just the same scenario...
Same with keyboard, when exit game, freezes.
Any help would be great.
T.
NotRequired
Re: Retropie Issue
Tue Nov 19, 2019 11:45 am
Not sure if this is a RbPi issue or a RetroPie issue.. Have you tried to examine the syslog and/or dmesg for any clues? As I remember, in emulation station you press F4 to go to a terminal and then you can scroll through the syslog with:
less /var/log/syslog
You can go to newest entries by pressing "B" (for Bottom) and then scroll upwards with up-arrow. You can review messages from the kernel, which may also give a hint, with the command:
dmesg
If there are no clues, I would try another SD-card.
Please do not ask questions in private messages, they will not help others.
T_Oldskool
Re: Retropie Issue
Tue Nov 19, 2019 12:37 pm
Thanks for the reply, I've tried a different card as well...
Return to “Gaming”
