Gnaprout
Raspberry 4 & minecraft server?
Mon Jul 01, 2019 7:10 am
Hi everyone,
Since Java8 is no longer supported with Raspbian Buster, do you have a tutorial to install a MC server on Raspi 4?
Gavinmc42
Re: Raspberry 4 & minecraft server?
Mon Jul 01, 2019 8:29 am
You might have to wait until there is a 64bit OS for the Pi4
https://www.raspberrypi.org/forums/view ... 4&t=231660
I'm dancing on Rainbows.
rpiMike
Mon Jul 01, 2019 8:39 am
You can download Oracle Java8 and install it :
https://www.oracle.com/technetwork/java ... 33151.html
or my Minecraft install does this for you:
https://www.raspberrypi.org/forums/view ... 8&t=243946
Gnaprout
Mon Jul 01, 2019 9:14 am
Thanks for answers !
I follow this tutorial and it seems to work (just have to replace the version number) : https://blog.livthomas.net/installing-j ... erry-pi-3/
Jtreferee
Mon Jul 08, 2019 12:53 pm
Hi - have you got this working? If so, how does it run? I'm very interested in getting this running but can't afford to buy an RPi only for it to not work..
Thanks!
JT
ayitzyaboi
Fri Jul 12, 2019 6:42 am
Hey, so I have my server up and running on my Pi 4, so far runs pretty great. I’ve had no connection issues, Ram issues, or power issues yet. The only problem I can see arising is that I can’t seem to get more than 2GB to allocate for the server. Basically, when I run the java file, I can only specify up to 2000 MB using the Xmx modifier. Anything passed that and I get an error. Anyone else having this issue?
I’m running Raspbian stretch with a spigot server.
Return to “Gaming”
