gkendall99
Raspberry Pi 2 Full Linux Minecraft Install
Wed Feb 25, 2015 7:40 am
I have a Raspberry Pi 2 running Raspian Wheezy. I know that this version has a free "Minecraft Pi" version installed on it, but this version is a bit too watered down for me. From what I understand, Minecraft server will run on it as well. I would like to run the full Linux Minecraft version from the https://minecraft.net/download site.
Minecraft for Linux / Other
Download Minecraft.jar (86 KB). The jar is executable and should work as-is, also please use Oracle's JVM.
I have tried the game with the default java, I have tried the game with Oracle's JVM. I can log in with my Minecraft account, and I can update all of the files. But when I click on "PLAY", I get the following error.
game ended with bad state (exit code 1)
I have looked online and I cannot seem to find any information on the Raspberry Pi 2 as it relates to full Linux version of Minecraft. Will this game work on Raspberry Pi 2 running Raspbian Wheezy?
Hiradur
Re: Raspberry Pi 2 Full Linux Minecraft Install
Wed Feb 25, 2015 2:15 pm
Minecraft requires OpenGL which the Pi doesn't support (only OpenGL ES which is different).
C-Fu
Wed Feb 25, 2015 4:43 pm
gkendall99 wrote:Hello,
Minecraft uses LWJGL, how did you get LWJGL to compile on Pi 2?
http://www.raspberrypi.org/forums/viewt ... 34&t=19532
gkendall99
Wed Feb 25, 2015 11:35 pm
Thank you for the replies. That explains it. As far as the compiling question, I didn't compile anything.
Thanks again.
GizmoTheGreen
Thu Feb 26, 2015 4:19 am
the openpandora uses GLShim to run java minecraft under ARM/opengles. should work on pi too.
I would try some stuff but I don't have access to a tv right now.
roadrunner7
Fri Feb 27, 2015 3:07 pm
Have you gotten any farther. I am going to see if I can work on this a little this weekend.
WalkingDeadFan
Mon Mar 16, 2015 6:20 am
Why does the personal edition of minecraft work? It must use a different graphics system.
Just tried full minecraft with the default java on the raspberry pi 2, hotspot java or something. fails with stack dump.
Any updates?
Mon Mar 16, 2015 8:39 am
The regular game fails for two reasons.
1. It uses a graphics mode that doesn't run on a RPi
2. It uses JNI (Java native interface) code that is specific to the hardware it runs on.
Microprocessor, Raspberry Pi & Arduino Hacker
Mainframe database troubleshooter
MQTT Evangelist
Twitter: @DougieLawson
2012-18: 1B*5, 2B*2, B+, A+, Z, ZW, 3B*3, 3B+
Please post ALL technical questions on the forum. Do not send private messages.
Pause_PlusPause
Fri May 19, 2017 12:16 pm
The full version is able to run on the raspberry pi 2-3, because you can install otional GL drivers.
viewtopic.php?f=78&t=137279
The instructions work for both the raspberry pi 2 and 3 (I said that already, did'nt I?)
Return to “Gaming”
Who is online
Users browsing this forum: No registered users and 11 guests
