mirojr
cant find python mesh scratch simple examples
Wed Apr 30, 2014 7:43 am
hi
I am looking for a simple example to get me started connecting python to scratch using mesh.
I used the examples from http://wiki.scratch.mit.edu/wiki/Commun ... Python_3.x
I have python 2.7 and 3.3
The example initially didn't work due to
    b  += a[i]
TypeError: Can't convert 'int' object to str implicitly
So I had to cast this
b  += str(a[i])
Which seems a bit rubbish being on an official scratch wiki
Anyway after changing this so it runs I get more errors in Scratch which I cant really understand yet 'message too big bad size field'
I am really after a simple example of interfacing the too programs that will give me a kick start.
It seems most of the examples are pretty poor in respect to the fact that they don't really explain how to utilise the connection (if I get it to work). I don't know how to use the broadcasts.
I am looking online but cant really find any clear simple examples
Does anyone know of any?
simplesi
Re: cant find python mesh scratch simple examples
Wed Apr 30, 2014 1:40 pm
This is a good starter in that the lower level scratch-python is handled for you.
https://github.com/pilliq/scratchpy
I've not used it myself but I've seen it in use in other progs
Simon
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
mirojr
Wed Apr 30, 2014 1:52 pm
I am actually after getting an understanding of the mesh python handling. Not many tutorials. Am having to root through code and try and figure it out. But I suppose that's the best way to learn.
Its mainly the scratch side that's seems harder. The passing of the strings etc.
I am trying to get the least obfuscated view of the process so am trying to avoid other peoples libraries, but on the other hand learn from examples.
The examples I see are also often way past beta's and then become too complicated. ha ha
I want the Hello World versions!!
ghp
Wed Apr 30, 2014 5:25 pm
the first 4 bytes are the length of the record in binary. A working sample is, out from my scratchClient software:
    def send_scratch(self, cmd):
        n = len(cmd)
        a = array('c')
        a.append(chr((n >> 24) & 0xFF))
        a.append(chr((n >> 16) & 0xFF))
        a.append(chr((n >>  8) & 0xFF))
        a.append(chr(n & 0xFF))
        try:
            self.scratch_socket.send(a.tostring() + cmd)
        except Exception as e:
            if logger.isEnabledFor(logging.INFO):
                logging.info(e)
            pass
A description is found in http://wiki.scratch.mit.edu/wiki/Remote ... s_Protocol
Good luck
Gerhard
mirojr
Thu May 01, 2014 12:38 pm
It looks like your code is for use with python 2.7
I am still wondering why the version 3 code doesn't actually work.
I am going to keep looking.
Just trying to understand this 4 byte section yet!
mirojr
Thu May 01, 2014 12:53 pm
Ok the 4 bytes I get now.
I appends this to the beginning of the string, they are hex values of bytes when displayed, but cast to strings I think
the version in python 3 doesn't perform this well.
Anyway I will keep looking
croston
Thu May 01, 2014 2:03 pm
You could also take a look at https://pypi.python.org/pypi/scratch - this works in both Python 2 and 3.
mirojr
Thu May 01, 2014 2:24 pm
I will look at this code.
will look how python 3 is handles its 4 byte buffer. It seems that the encoding on 2.7 is much more straight forward. Especially how it concatenates it all.
ghp
Thu May 01, 2014 3:30 pm
tried some things in python3, and think that something like the following snippet will solve the problem:
cmd = 'broadcast hello'
# the length is the number of bytes in the message, not the number of characters.
n = len(bytes( cmd, 'UTF-8'))
a = array('b')
# convert len to the first four bytes
a.append(((n >> 24) & 0xFF))
a.append(((n >> 16) & 0xFF))
a.append(((n >>  8) & 0xFF))
a.append((n & 0xFF))
a.frombytes( bytes( cmd, 'UTF-8'))
remark: occasionally, I dislike python.
regards,
Gerhard
mirojr
Thu May 01, 2014 3:38 pm
Ok thanks
Closest I got for my output was:
b'\x00\x00\x00\x10'broadcast"hello"
from using
def sendCMD(cmd):
    n = len(cmd)
    a = []
    a.append((n >> 24) & 0xFF)
    a.append((n >> 16) & 0xFF)
    a.append((n >> 8) & 0xFF)
    a.append(n & 0xFF)
    b = ''
    for i in list(range(len(a))):
        b  += str(a[i])
    print(str(bytes(a)) + cmd)
sendCMD('broadcast"hello"')
Not very good with python
What is array('b') for?
I
mirojr
Thu May 01, 2014 3:42 pm
Ok got it.
Typecode.
Char
mirojr
Thu May 01, 2014 3:43 pm
Well signed char should I say, for b
mirojr
Thu May 01, 2014 3:51 pm
ghp wrote:Hello,
a = array('b')
regards,
Gerhard
Why did you use array('b')
signed char
Rather than array('c')
char
Just trying to get an understanding
Cheers
ghp
Thu May 01, 2014 4:33 pm
have a look at https://docs.python.org/3/library/array ... dule-array
The 'c'-type is no longer supported. And thinking about the problem a while, I found that sockets do not handle characters, but bytes. In single-byte-charactersets, chars and bytes are same, but in utf-8, chars can be multibyte. So it is more precise to have byte arrays. In most cases this will be not a problem, when you keep texts in ascii range.
The 'u'-type will be removed in later versions, and does not help long term.
Regards,
Gerhard
mirojr
Thu May 01, 2014 5:07 pm
Great that Gerhard
Many thanks for your help
mirojr
Fri May 02, 2014 10:00 am
Finally got the thing to work in its absolute basic form. Its a Kernighan type HelloWorld GPIO at best.
I might post it with the scratch interface showing as well, because for novice like myself was a bit tricky finding out how to do very basic broadcast.
Thanks Gerhard and Thomas Preston https://github.com/piface/pifacedigital-scratch-handler
and http://wiki.scratch.mit.edu/wiki/Commun ... with_a_GUI
from array import array
import socket
import time
import sys
import RPi.GPIO as GPIO
GPIO.cleanup()
GPIO.setmode(GPIO.BOARD)
PORT = 42001
HOST = '127.0.0.1'
if not HOST:
    sys.exit()
print("Connecting...")
scratchSock = socket.socket(socket.AF_INET, socket.SOCK_STREAM)
scratchSock.connect((HOST, PORT))
print("Connected!")
while True:
    data = scratchSock.recv(1024).decode('utf-8')
    data = data[4:]
    data = data.split(' ')
    GPIO.setup(11,GPIO.OUT)
    if data:
        print(data[1])
        if data[1].strip('"') == "pin11-high":
            GPIO.output(11,GPIO.HIGH)
        elif data[1].strip('"') == "pin11-low":
            GPIO.output(11,GPIO.LOW)
Return to “Scratch”
