Page 4 of 4
Re: A new Scratch; pre-alpha-this-will-hurt release
Posted: Sat Apr 19, 2014 9:15 pm
by simplesi
I'll start testing it out for #ScratchGPIO compatibility and working over VNC
Simon
Posted: Sun Apr 20, 2014 8:21 am
by simplesi
Just tried to download NuScratch5.tgz but link doesn't seem to work
Simon
Posted: Mon Apr 21, 2014 6:45 pm
by timrowledge
simplesi wrote:Just tried to download NuScratch5.tgz but link doesn't seem to work
Simon
Sorry about that; I've been moving away from dropbox, try -
https://copy.com/F01OLiWrf4GCP6Kf
Posted: Fri May 09, 2014 4:03 pm
by ghp
I looked for a nice feature in scratch: animated gifs. It Works in win-1.4 and legacy-1.4: import costume, it will load each frame as a separate costume then.
Unfortunately, it does not work with nuscratch5-1.4: the import first runs on a breakpoint (ok, it is beta) and then after selecting the file it simply does nothing.
See a working sample in http://wiki.scratch.mit.edu/w/images/Popular_GIF.gif
Instructions in http://wiki.scratch.mit.edu/wiki/Animated_GIF
Regards,
Gerhard
Posted: Sat May 10, 2014 10:19 pm
by timrowledge
ghp wrote:Hello,
Hah! Oddly enough I just dealt with that a couple of weeks ago; it's in the upcoming beta release. Which is being kept back while we try to get a handle on the sound lock-up problem. Which looks like a possible kernel fix is needed, since apparently there is some clash between the timer interrupt I'm using and some other important vector that ... whatever.
Posted: Sun May 11, 2014 4:30 pm
by simplesi
Just tested NuScratch5 for compatibility wit ScratchGPIO and it seems fine - sends out broadcasts and variable changes and receives sensor updates from Python :)
Simon
PS Any reason for font change from standard 1.4? Obviously makes it easy to see what version is being used but on the other hand it makes it look strange/different and that might not be best idea for young scratchers moving between PC/Mac/Pi
Simon
Posted: Sun May 11, 2014 5:29 pm
by timrowledge
simplesi wrote:Just tested NuScratch5 for compatibility wit ScratchGPIO and it seems fine - sends out broadcasts and variable changes and receives sensor updates from Python :)
Excellent. Thanks for testing it out.
simplesi wrote:PS Any reason for font change from standard 1.4?
Yup. The deeply technical and important one of "I didn't get around to doing anything about it." I've done something about it for the beta release. Which should be out soon... if the sound nonsense can be solved.
Posted: Mon May 26, 2014 4:19 pm
by timrowledge
timrowledge wrote:I've done something about it for the beta release. Which should be out soon... if the sound nonsense can be solved.
... and the beta release is now official. I had to fiddle with the VM a bit to avoid using a timer interrupt that ALSA also uses and uses incorrectly. Fortunately the current Raspbian kernel allows thread priority munging and so the alternative timer handling regime was practical. The upshot is that sound no longer seems to cause any lockups, which is nice.
We should consider this forum thread locked though and move to a new one for the Beta release(s).
Posted: Tue May 27, 2014 5:19 pm
by simplesi
You start it and we'll follow along :)
Posted: Thu May 29, 2014 5:30 am
by KeithSloan
I am new to Scratch & Squeak, but listening to Tim at http://smalltalkinspect.podspot.de/post ... -rowledge/ I would assume that the software is faster under RISC OS than Raspbian as the RISC OS Wimp is much faster than X-Windows. Are these new versions available for RISC OS
Posted: Thu May 29, 2014 3:27 pm
by simplesi
Until things are sorted and new thread created - here is link to blog post so that people can get started testing/trying
http://www.raspberrypi.org/blog/#test-t ... ratch-beta
Simon
Posted: Sat Mar 07, 2015 6:35 pm
by JarJarGeek
is NuScratch now 'standard' on Raspian .img ?? Or do you have to use the prescribed installer on this page to get it ??
Posted: Sat Mar 07, 2015 7:18 pm
by ghp
nuscratch is standard since raspbian 2014-12-24, the xmas-release. There have been some hickups with this distribution, but with current raspbian these are corrected, especially the startup script.
'old' scratch is still available, start it with sratch.old from a terminal window.
nuscratch is starting with title line 'scratch 1.4 of 14-Jan-15'.
Regards,
Gerhard
Posted: Tue Jun 23, 2015 7:17 pm
by timrowledge
So how do you folks feel about running Asteroids fast enough that it gets throttled to 'only' 50 fps?
Coming soon...
Posted: Tue Jul 14, 2015 3:35 pm
by timrowledge
timrowledge wrote:So how do you folks feel about running Asteroids fast enough that it gets throttled to 'only' 50 fps?
oh, and without throttling it now does around 200fps on a pi2.
Posted: Tue Jul 14, 2015 7:09 pm
by ghp
do you already have plans when this release is delivered to the public ?
And what is progress on bug fixes ? Kids in school complained a lot about the "sudden crashes".
Regards,
Gerhard
Posted: Tue Jul 14, 2015 7:12 pm
by timrowledge
ghp wrote:Hello,
Pretty soon; and I'll be back at the bug-fixing mines very soon. Some stuff to do with AstroPi etc first.
