simplesi
Scratch 2.0 is out 9th May
Sun Apr 28, 2013 9:58 am
Scratch 2.0 goes official on 9th May
http://scratch.mit.edu/forums/viewtopic.php?id=117391
Not of any practical use to RPi users of course since its all in Flash and web based :(
But, once the Scratch Team have ironed out the little bugs that no doubt will need sorting , then hopefully they can turn their attention to a "proper" :) downloadable version that we can run on the RPi that will let us get at the goodies such as making our own blocks :)
FAQ on Scratch 2.0 transition http://beta.scratch.mit.edu/discuss/topic/1168/
Simon
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
TRocket
Re: Scratch 2.0 is out 9th May
Sun Apr 28, 2013 10:44 am
The downloadable version won't work on the pi.
It will be an adobe air style application...
simplesi
Sun Apr 28, 2013 11:05 am
Says who/where did they say it? :)
Simon
TRocket
Sun Apr 28, 2013 12:19 pm
simplesi wrote:Says who/where did they say it? :)
Simon
http://scratch.mit.edu/forums/viewtopic ... 8#p1378278
SimonSmall
Sun Apr 28, 2013 1:26 pm
I hope that I am wrong but it looks like Scratch 2 will be a web-only, flash based language, focussing on any programs being saved "cloud-style" on the Scratch 2 website. To use it "offline" seems to mean that it requires use of an obsolete, unsupported version of flash
I have been impressed by the concept of Scratch and, apart from a quick "play-around" to make the cat bounce from side to side, I have not spent a lot of time on it. I had thought that I might do this later
I am now worried that Scratch might be a dead end project for me. I am not clear where this leaves the things that have been done on the Pi, given that the Pi Foundation made such a big thing out of Scratch. I would appreciate a list of decent links to information about Scratch as a programming language; their website seems to be all community, this forum and the Pi wiki does not provide enough detail
simplesi
Sun Apr 28, 2013 2:09 pm
From link by TRocket
As for offline - probably we'll end up using something like air, so the application looks / works the same online as it does off. It's *really* hard to get consistent performance and behavior with implementations written in different languages, so that's why we wouldn't try to make it in C or anything. But you are welcome to use the ideas from Scratch to make your own app!
Well - that pretty much looks like the last nail in coffin in our hopes for an offline Scratch 2.0 :(
So, we'll just have to use what we've got - which is Scratch 1.4 :)
Its still the original and although it may not waht we want - its still the best programming language for kids to learn and is the brand leader by a very long way :)
We still need to get it run at least twice as fast as it presently does on a non-pverclocked RPi - whether this effort would be best served by everyone piling in on TRocket's C++ port or just trying to get a faster squeak enviroment is just one of the questions to be answered.
I think there are some hard choices to be made :(
Simon
TRocket
Sun Apr 28, 2013 3:09 pm
simplesi wrote:From link by TRocket
Simon
In terms of speed c++ would probably be a hell of a lot faster than smalltalk(squeak is essentially a smalltalk vm) and c++ is a much more popular language than smalltalk/squeak...
I haven't been that active on itchy++ recently due to lack of developers.(it's really just me atm)
timrowledge
Sun Apr 28, 2013 5:35 pm
There is a lot of work being done to improve Scratch (and Squeak) performance on the Pi. If you care to download the test image from
https://www.dropbox.com/s/j8ellgf93w01y ... .image.zip (NB this is a test image and if you're reading this much after April '13 it probably won't be there!)
(and assuming I got the Dropbox settings right so you can get to it) then you should find a decent improvement for many projects - some of our benchmarks have doubled. Don't forget to save the original Scratch image somewhere safe in case you find bugs.
This image is all just work on improving the Smalltalk code that implements Scratch and there is still quite a bit to do. Work is underway to massively improve the performance of bitblt (the Smalltalk graphics operation) and to get the more recent and much faster Squeak virtual machines running on the Pi.
You can help this work by supplying projects that cause problems for us to benchmark and analyse.
Making Smalltalk on ARM since 1986; making your Scratch better since 2012
simplesi
Sun Apr 28, 2013 7:14 pm
Who/where is this team of elves and why are they working secretly in the dark? :)
Simon
simplesi
Sun Apr 28, 2013 8:11 pm
Just to help peopl testing out other Scratch images you can use the following procedure to simply have a new icon on the desktop to run it which leaves your original Scratch alone
Download the test image from the Dropbox link above and lets say you save it \\home\pi
Launch a LXTerminal session
sudo cp //home/pi/Scratch.image /usr/bin/share/scratch/ScratchTest.image
cp //home/pi/scratch.desktop  //home/pi/scratchtest.desktop
nano //home/pi/scratchtest.desktop and change it to
[Desktop Entry]
Encoding=UTF-8
Version=1.0
Type=Application
Exec=/usr/bin/scratchtest.sh %f
Icon=scratch
Terminal=false
Name=ScratchTest
Comment= Programming system and content development tool
Categories=Application;Education;Development;
MimeType=application/x-scratch-project
save it (Ctrl-X then Y then Enter)
create a new file
sudo nano /usr/bin/scratchtest.sh
and then copy this code and paste it into nano
#!/bin/sh
# File:            scratchtest
# Description:     Script to start the Squeak VM binary with the scratch image
# Original Author: Bert Freudenberg
# Adapted by:      Miriam Ruiz and Simon Walters to run a test Scratch Image called ScratchTest
VM_VERSION=`find /usr/lib/squeak/ -name "squeakvm" -type f|cut -f5 -d"/"`
SQ_DIR=/usr/lib/squeak/$VM_VERSION
VM="$SQ_DIR/squeakvm"
VMOPTIONS="-encoding UTF-8 -vm-display-x11 -xshm -plugins /usr/lib/scratch/plugins/:$SQ_DIR/"
IMAGE="/usr/share/scratch/ScratchTest.image"
IMOPTIONS=""
DOCUMENT=""
WRAPPER=""
#set to 1 to work around OLPC bug #8008
export SQUEAK_FAKEBIGCURSOR=0
# default directories (used if not running as Sugar activity)
[ -z "$SQUEAK_SECUREDIR" ] && export SQUEAK_SECUREDIR="$HOME/.scratch/private"
[ -z "$SQUEAK_USERDIR" ] && export SQUEAK_USERDIR="$HOME/Scratch"
[ ! -d "$SQUEAK_SECUREDIR" ] && mkdir -p "$SQUEAK_SECUREDIR" && chmod 700 "$SQUEAK_SECUREDIR"
[ ! -d "$SQUEAK_USERDIR" ] && mkdir -p "$SQUEAK_USERDIR"
[ ! -d "$HOME/Documents" ] && mkdir -p "$HOME/Documents"
usage()
    echo "Usage: scratch [--param value] [-vmopt value] [arg value]"
    echo "       where --param is --vm, --image, or --document;"
    echo "       -vmopt is an option passed to the Squeak VM;"
    echo "       and args are passed to the Squeak image."
if [ $# -eq 1 ] ; then
	case "$1" in
	    /*) DOCUMENT="$1"
	    *) DOCUMENT="$PWD/$1"
	esac
	shift
else
    while [ -n "$1" ] ; do
	if [ -z "$2" ] ; then
	        usage
		exit -1
	fi
	case "$1" in
	        --help)
			usage
 			exit
	        --document)
			case "$2" in
			    /*) DOCUMENT="$2"
			    *) DOCUMENT="$PWD/$2"
			esac
 			shift
	        --image)
			case "$2" in
			    /*) IMAGE="$2"
			    *) IMAGE="$PWD/$2"
			esac
 			shift
	        --vm)
			case "$2" in
			    /*) VM="$2"
			    *) VM="$PWD/$2"
			esac
 			shift
		-*) VMOPTIONS="$VMOPTIONS $1 $2"
			shift
		*)  IMOPTIONS="$IMOPTIONS $1 $2"
			shift
	esac
	shift
    done
fi
# do not crash on dbus errors
export DBUS_FATAL_WARNINGS=0
# make Compose input methods work
# 30/01/2013: apprently this causes issues, so comment out. [email protected]
#[ -z "$LC_ALL" ] && export LC_ALL="$LANG"
VMOPTIONS="$VMOPTIONS -vm-sound-alsa"
# VM, Image, and Document are non-optional
# Document has to be present even if empty for IMOPTIONS to work
echo Executing: $WRAPPER "$VM" $VMOPTIONS "$IMAGE" "$DOCUMENT" $IMOPTIONS
exec $WRAPPER "$VM" $VMOPTIONS "$IMAGE" "$DOCUMENT" $IMOPTIONS
and then save by Ctrl-X then Y then Enter
and then finally
sudo chmod +x /usr/bin/scratchtest.sh
simplesi
Sun Apr 28, 2013 8:40 pm
@timrowledge
The "test suite" that we've been using is the one from the thread that kicked all the discussion off - @Cliffords Asteroid Blaster
http://scratch.mit.edu/projects/cliffor ... be/2697920
I simply time how long it takes to fire a missile into the corner
The normal scratch (I mean the last time Alex Bradbury updated it) is takes about 2.8 secs to hit the corner of the screen in medium window and its failry agreed that its not really playable
in full screen mode it takes about 1.7 in full screen
This is on 700MHx RPi
I think its playable in full screen on a 1GHz turbo mode RPi but since all my RPi corrupt SD cards at 1Ghz I've given up on that approach as a workable solution :)
I'm not noticing any noticeable speed increase in the image you've linked to BTW
What Scratch code would show off the improvements?
regards
Simon
timrowledge
Mon Apr 29, 2013 12:29 am
OK, haven't come across Asteroid Blaster before; I'll give it a try.
The big scary benchmark we have been using is a very complete PacMan http://scratch.mit.edu/projects/aoliver2/2345919
On a vanilla Pi/Raspbian/Scratch I see slightly less than 2 frames/sec (about 600mS per cycle) and on the newer image around 250mS/cycle.
By way of a comparison with big desktop machines my 3GHz iMac can just barely manage 24mS with vanilla Scratch but ~19mS with the new image.
So - on my non-overclocked Raspbian Pi I get 16-20 frames/sec on asteroids with the new image. It's oddly jerky which certainly needs looking at, and it exposes an error that I've not been hit by before, which is always useful to know about. I'll get that fixed soon.
When you say
what exactly do you do? Are you moving the ship to a corner and firing to the opposite corner? Firing from the centre?
Try clicking on the 'R' in the Scratch at tope-left with the shift key down, choosing 'turn fill screen off' and then on the newly exposed desktop area use the middle-mouse-button to get the 'World' menu, choose 'new morph…' and then 'Demo>' & 'Frame rate morph'. Drop the morph somewhere visible and it will keep you appraised of the frame rate (duh).
Mon Apr 29, 2013 2:08 am
TRocket wrote:The downloadable version won't work on the pi.
Going with Flash, an outdated and about to be deprecated (already on mobile devices) system, was an almost criminal decision by the Scratch developers IMO. I think many will need to stick with 1.4, and not just on the Raspi.
simplesi
Mon Apr 29, 2013 6:33 am
Just sit in the middle and fire into top left corner.
But basically it all about whether its considered playable by an 8 year old that counts :)
II'llkk give the Pacman game a whirl and use your frame rate tool - ta :)
Going with Flash... was an almost criminal decision by the Scratch developers IMO. I think many will need to stick with 1.4, and not just on the Raspi.
I think it more just bad timing than criminal.
It stemmed from the fact that a few years ago they developed an on-line flash player instead of their Java one and when they started on Scratch 2.0 - flash still ruled everywhere except on Pads Its just taken them so long to get Scratch 2.0 out of the door that it now looks silly to us.
I don't know if sticking to 1.4 will be possible (on main clasrroom computers) because once the kids are into Scratch- they'll go home and use 2.0 and then they are going to come back and ask why we aren't using it in school - it'll make us look like Dinosaurs - they won't care about using the wrong platform.
But on the RPi - its going to be 1.4 - which is still good of course
Simon
Mon Apr 29, 2013 6:50 am
Simon
Going with a propriety system like flash where you are at the whim of the technology owner is where, I guess, it all went wrong. Adobe decides no more Flash, and out it goes. Flash isn't even a good choice anyway, slow and full of bugs.
simplesi
Mon Apr 29, 2013 7:04 am
The Scratch team are all about share and enjoy and this was arguably the best tool for doing that at the time they started.
It might have good consequcnes in that that the "community" might finally rally around a true open-source,multi-platform, block based teaching language and just leave Scratch 2.0 as a home activity for making games
Simon
timrowledge
Mon Apr 29, 2013 9:01 pm
Try filing the attached very, very, trivial changes file to fix the buglet Asteroid Blaster exposed. As the file comment says, I'm surprised by this since I ran dozens of projects for hundreds of hours without seeing the problem. I think it probably says a lot about the wide variety of programming styles in Scratch projects.
Roughly timing on my Pi, firing from the centre of the screen to the bottom-right corner, timed by using the stopwatch on my iPhone, I get about 1.5secs
011-Non-BlockMorph-unhighlight.1.cs.zip
(971 Bytes) Downloaded 307 times
<- zipped because the forum software dislikes '.cs' files.
simplesi
Mon Apr 29, 2013 9:24 pm
Which window mode - small - medium or full screen ?
timrowledge
Mon Apr 29, 2013 10:50 pm
Medium - the normal 480*360 screen
simplesi
Tue Apr 30, 2013 12:03 pm
mm - something not quite right then at my end - I can only get down to 1.5 secs by running in presentation mode - what timings do you get in presentation mode?
But don't let me deviate you from trying to improve things - if your seeing significant speed increases at your end - great :)
I'll get back trying finish off my GPIO stuff (Which doesn't need the speed boost as much :) )
Simon
timrowledge
Thu May 02, 2013 5:23 pm
That's very odd; I get a consistent 1.6/7 secs for that little test, whether ¼ screen, normal screen or full screen.
Any chance you're not actually running the newer image? That's one problem with updating something and having to make it look exactly like the old thing - how do you tell?
simplesi
Thu May 02, 2013 7:09 pm
What do you get on the last asb updated image - do you get diffs between 1/4,normal and full screen?
Is there a way of inspecting something in the image I think I'm running (I'm no squeak expert but is there a procedure or something that I could check to see if its the right one?)
You are running at standard 700MHz?
Simon
timrowledge
Tue May 07, 2013 5:17 pm
My Raspbian Pi is not over clocked at all (at least not by me).
The changes I've been making have some curiously different effects between RISC OS and Raspbian; for the Asteroids game they make about a 4x difference to the frame-rate in both OSs, but for the big PacMan project I previously mentioned RISC OS gets 2x faster and Raspbian only ~1.5x. Also under Raspbian the Asteroid game shows a strange 'speed pulsing' effect that doesn't appear under RISC OS - the asteroids seem to scurry then hesitate, scurry some more etc. Obviously I'm going to have to investigate that sometime.
I did have some suspicions about the sound driver being responsible but some hacking to completely turn off the sound drivers in Squeak showed no change, so obviously not the problem.
simplesi
Tue May 07, 2013 6:57 pm
I wonder if we could get a baseline agreement between us on standard Raspbian image :)
Asteroids - medium window - 3.6 secs to fire into bottom right corner
1.6 secs in full screen
this is with ship sprite code showing
Simon
timrowledge
Wed May 08, 2013 2:33 am
Odd - on my Pi the times are very much the same for medium/full-screen.
I actually video'd the original image and my modified one with my iPhone to try to get a better timing - old image ~ 3.5s, new ~1.6, again pretty much the same whatever the display setting.
I even tried turbo mode to see the effect with some actual timing -
old image ~1.6, full-screen ~1.7
new image ~0.5, full-screen ~0.7
There should be a little more to come if a new VM build can be used since I added a very fast pixel-peek primitive that speeds up some of the 'am I touching' type operations; on RISC OS it was well worth it. There are some more complex 'is this colour touching that colour and is it a full moon next thursday unless it is raining' tests that should be massively improveable too.
Return to “Scratch”
