PeterPi09
Scratch Screen Saver Project
Tue Jan 01, 2013 5:52 pm
I am kind of new to programming so I decided my first scratch project would be a screen saver. I took 6 tennis ball scripts and have them bouncing around the screen by using the glide feature. How can I make this my actual screen saver for the raspi?
Thanks,
Peter Kaminski
simplesi
Re: Scratch Screen Saver Project
Wed Jan 09, 2013 7:40 am
Nothing is usually impossible in the computing world but your request would be strong contender for that description :(
It would be a very challenging project for an advanced programmer !
Simon
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
MightyMat
Tue Jan 15, 2013 9:00 pm
The only thing you could do is to switch to your scratch program when you stop using your computer for a bit. Sorry I couldn't be much help :(
simplesi
Tue Jan 15, 2013 9:56 pm
i like your out-of-the-box thinking there :)
Simon
-rst-
Wed Jan 16, 2013 10:58 am
Hmm, I wonder if this 'screensaver module' can be any executable file http://www.dis.uniroma1.it/~liberato/screensaver/ (http://www.dis.uniroma1.it/~liberato/sc ... stall.html)?
...maybe it could be a shell script that starts the Scratch app? Or in the worst case it could be a simple C program that starts Scratch... A pity I don't have my RPi at hand to test :oops:
http://raspberrycompote.blogspot.com/ - Low-level graphics and 'Coding Gold Dust'
NathanBookham
Wed Jan 23, 2013 9:12 am
I have a funny feeling that Scratch has a command line argument that opens a project in fullscreen. Hopefully you can pass this on to the screensaver application.
This account is now inactive.
I am now known as 'InverseSandwich'
DavidS
Wed Jan 23, 2013 2:06 pm
Just create an application directory containing only an obey script named !Run that invokes Scratch to run your Scratch script full screen, then put it in the "$.!Boot.RO500Hook.Res.Configure.ScrSavers" directory.
An application directory is just a normal directory that begins with a pling '!' charactor. You have probably noticed that most programms have this form to there name, most of them are actually application directories that contain the program along with any resources (including the applications icon sprite).
RPi = The best ARM based RISC OS computer around
More than 95% of posts made from RISC OS on RPi 1B/1B+ computers. Most of the rest from RISC OS on RPi 2B/3B/3B+ computers
-rst-
Wed Jan 23, 2013 2:39 pm
DavidS wrote:Just create an application directory containing only an obey script named !Run that invokes Scratch to run your Scratch script full screen, then put it in the "$.!Boot.RO500Hook.Res.Configure.ScrSavers" directory.
Nice one ...provided that one is running RISCOS ;)
-rst-
Fri Jan 25, 2013 10:50 am
-rst- wrote:Hmm, I wonder if this 'screensaver module' can be any executable ...
Yes, it seems so ...in Linux that is.
I tested this yesterday ...with varying results and issues depending on the executable... (not a good idea to run a 'plain frame buffer' app that changes display resolution :oops: ) - prepare to have to swing your mouse around the desktop and maximise+normalise some window to get X to redraw the desktop :mrgreen:
Steps:
- check if screensaver already installed in LXDE, is "menu -> Preferences -> Screensaver" present
- if not installed: sudo apt-get install xscreensaver
- create file ~/.xscreensaver (that is a file named ".xscreensaver" in the user's home directory, '/home/pi' by default)
- add this line in the file:
programs: myownscreensaver
- restart X (close X and 'startx' ...not sure how this works if you have 'autostart X' enabled - might need to boot)
- go to: menu -> Preferences -> Screensaver
- find the 'myownscreensaver' in list of scrteensaver modules and select
- click 'Settings...' and in the settings popup 'Advanced >>>'
- edit command line to point to your executable
Scratch projects can be run in 'fullscreen' autorun 'presentation' mode using (this would go to the command line above):
scratch presentation path-to/filename.sb
...something along:
scratch presentation "/home/pi/Documents/Scratch Projects/Test.sb"
...best to test first from Run command-box (Alt+F2) or from LXTerminal.
So, if you are desp...determined enough to want to try this :lol:
timrowledge
Sat Aug 31, 2013 5:24 pm
Hmm, this would be an interesting project to make properly integrated into the desktop. There is presumably some hook, vector, signal, call, or whatever that is used to let the desktop know that it is time to start the screensaver; if that is so then in principle we could enhance the Squeak/Scratch code to recognise that and activate you project. You'd also need to handle whatever signal is used to stop the screen saver and return to the desktop.
The *nix Squeak vm has some mechanisms already in place to deal with at least a few OS signals so it might not be terribly difficult once the interface to the desktop is known.
It would probably be easier as a deployment exercise to take the algorithms for your bouncy-balls and simply use them in a full Squeak image to drive seem Morphs around; that way you'd drop the Scratch overhead (it does a *lot* of stuff under the covers and for a relatively simple animation it can cost a goodly amount of time - I'm gradually reducing that but it's hard word!) and would be able to use any screen resolution you like.
Find out those interfaces to the screensaver first; there really ought to be clean api in there somewhere!
Making Smalltalk on ARM since 1986; making your Scratch better since 2012
Return to “Scratch”
