Performance issues using ´Scratch 2.0
Posted: Tue Dec 25, 2018 10:57 am
by ekelundPi
I am a total beginner to Rasberry Pi and Scratch 2.0. Bought a Rasberry Pi 3 to my daughter in Christmas gift and a pre-installed card with Noobs. Installation worked fine, and I also updated to the latest software.
However, now when running Scratch 2.0 on the Pi it has obvious performance issues. I am running really beginners projects following a text book Scratch for Kids, but we cannot follow the examples as they start lagging immediately.
Are there any settings that I can change on the Pi to optimize performance with Scratch 2.0?
Are there any known obvious bugs working with Scratch 2.0 that I can correct?
I was considering if screen resolution could be the problem, (use HDMI to a small tv) but have not managed to change to settings that improve. I use default setting.
Can it be some other application running in the background that takes all the performance. I have tried to open up task manager, and a couple of applications are running, but í believe those are related to wifi and others. I have not started up any other program on the Pi.
Or is simply the Pi to weak for running Scratch 2.0?
Any inputs are most helpful. The intension was to learn the daughter the some first simple steps in coding, and basically only to run scratch on the unit.
Thanks!
Re: Performance issues using ´Scratch 2.0
Posted: Tue Dec 25, 2018 5:23 pm
by ghp
Hello, most books written for scratch have a laptop or desktop environment in mind. Performance is no issue there. For the raspberry environment, performance is a bottleneck.
One of the most common patterns found are loops which check for some condition. Adding small delays (in most cases acceptable) improve situation.
For scratch 1.4, I have written a blog post about performance. See http://heppg.de/ikg/wordpress/?p=125
If possible, post your script here.
Posted: Tue Dec 25, 2018 5:25 pm
by fruitoftheloom
Thanks!
The RPF provide resources, see:
https://projects.raspberrypi.org/en/pro ... th-scratch
https://www.raspberrypi.org/magpi/scrat ... -tutorial/
Posted: Wed Dec 26, 2018 2:04 am
by timrowledge
Try nuScratch - by choosing “Scratch 1.4” from the menu - instead. It may be older but since it was written in a sensible language we were able to rather drastically improve the performance.
You won’t have a few of the blocks the Scratch 2 provides, and the screen layout is slightly different but pretty much any tutorial will be usable. Besides, there are a load of example projects included. The biggest issue is that downloading projects from mit won’t work because they carefully removed that support from us.
Posted: Wed Dec 26, 2018 5:03 pm
by ekelundPi
Thanks a lot fohose reply's
Moving to scatch 1.4
Posted: Sat Dec 29, 2018 11:30 am
by mim42
I'm having the exact same issue with a 3B+ and pre-installed card. Scratch 1.4 works well but Scratch 2 is laggy, both in the web version and installed version. Could it be flash related? Scratch 2 is the only flash application that seems to be having trouble so far, though. It would be nice to get the latest version working. The new Scratch 3 beta has the same performance issues as well.
Posted: Thu Jan 17, 2019 10:36 pm
by Botspot
Try avoiding all graphics effects, especially color effect and brightness.
You can also try holding down the shift key and simultaneously pressing the green flag. This enables "turbo mode".
Press Ctrl-Alt-Delete while Scratch 2 is running. This opens the task manager. Scroll down to the process "Scratch2". Right click it, then set the priority to 10. That should snap it up a bit.
You can also experiment with setting the "GPU Memory" to different amounts to optimize memory usage.
Just run
sudo rc_gui
and then head over to "Performance".
Even with these improvements, Scratch 2 was still undesirably slow until I overclocked my pi.
It now runs just as fast as on my laptop.
