scottnichols
Remove Scratch
Sat Oct 27, 2012 8:30 pm
Hello
Is their a way to remove the Scratch program from the Raspberry Pi Wheezy build 2012-9-18. If yes how would I go about doing this.
Thank You
pepitoGrillo
Re: Remove Scratch
Sun Oct 28, 2012 12:52 pm
sudo apt-get remove scratch
scottnichols
Re: Remove Scratch
Sun Oct 28, 2012 1:29 pm
pepitoGrillo wrote:sudo apt-get remove scratch
Thank you
I will give that a try
simplesi
Re: Remove Scratch
Tue Oct 30, 2012 9:56 pm
I've got ask - why do you want to remove it?
Simon
Seeking help with Scratch and I/O stuff for Primary age children
http://cymplecy.wordpress.com/ @cymplecy on twitter
vallesasecas
Re: Remove Scratch
Fri Nov 02, 2012 8:12 am
If you never use it you remove it. I also do the same...
helixical
Re: Remove Scratch
Wed Oct 15, 2014 11:14 pm
I had the same issue. I accidentally selected scratch as the default startup & couldn't find documentation to change the startup. Figured deleting it would be easier
Thejoker
How to go to the terminal from scrach
Thu Feb 05, 2015 5:30 pm
I want to go to the terminal from scratch because i want to change the boot
ghp
Re: Remove Scratch
Thu Feb 05, 2015 6:17 pm
found another forum entry about 'escape from boot to scratch'.
http://www.raspberrypi.org/forums/viewt ... 91&t=69816
Honestly, I did not try out. Changed the boot sequence to scratch, and managed to changed it back by a remote login to this Pi and start 'sudo raspi-config' from a terminal.
Regards,
Gerhard
Return to “Scratch”
